Author Topic: my CB750F build into a CR750 cafe  (Read 60746 times)
Offline jaguar
Re: my CB750F build into a CR750 cafe
« Reply #50 on: August 11, 2010, 09:17:22 PM »
to be 100% honest i have no idea
i would bet that wire wheels with and alloy rim would be lighter
Offline jaguar
« Reply #51 on: September 03, 2010, 04:23:09 AM »
got the brakes back!
they are beautiful
ill get some pics up
i need to order pads to that the brakes are 100% done.
thinking about the EBC HH pads
traveler
« Reply #52 on: September 03, 2010, 07:52:32 AM »
Looks very nice.
~Joe
Offline jaguar
« Reply #53 on: September 13, 2010, 05:34:56 PM »
work has been alittle slow as im back at school and starting a CB350 race bike.
but still some work is going on
freshly coated parts and new OEM parts
brand new OEM pistons and seals.  masters where coated too.
CBR600F3 front master.
needed a new sight so im replacing the original one with a new crystal lens
Offline hapakev
  • Your Standard
« Reply #54 on: September 13, 2010, 07:44:21 PM »
Sweet Build! A great inspiration for my build.
Smoking Jack
1978 CB750F(ish)
Offline HedNut
  • Underwater Basket Weaving
« Reply #55 on: September 15, 2010, 06:01:30 AM »
Looking slick!....Keep it up!
Offline jaguar
« Reply #56 on: October 05, 2010, 04:43:56 PM »
thanks very much for the kind words
got the masters rebuilt today.
need a few more OEM brake parts in order to install everything.
Offline jaguar
« Reply #57 on: November 12, 2010, 04:10:17 AM »
Goals for to finish before the end of the year
-finish brakes
-headlight HID
-find a good way to mount the glass fender
-better mount for the digital dash
-figure out a tail light
-mount a plate mount
-start wiring the bike
then comes the motor!
Offline g_lightning
« Reply #58 on: November 15, 2010, 02:03:43 PM »
I apologize if I am asking a question that has already been answered, but do those calipers bolt directly to the 750f front end?
« Reply #59 on: November 15, 2010, 02:44:10 PM »
jaguar: Can you furnish some details on how you removed the site glass from the master cylinder and how you will put the new one in? And from where did you get the new one?
Offline jaguar
« Reply #60 on: November 15, 2010, 06:21:55 PM »
im using a CBR600F3 master so im not 100% about other masters....
i got the info from a old honda Magna board.
the site "glass" is in fact not glass. its a plastic.
i used a pick and broke the lens and pulled it out.
you need to be careful when removing the seal and plate.  if you are careful its easy to get back together.
i was not careful.....but really no big deal
im replacing the lens with a crystal from a watch.  and clear RTV to seal it back together.
http://wiki.sabmagfaq.org/Site_glass_replacement
there is a link to the place to buy the crystal
they have a min order so i bought a few sizes for down the road
i removed everything and had the master powercoated
plan is to reinstall the "glass" this week
yes the front brakes will bolt on.
use the brakets off a 1982 CB900F.  they use the brackets for a few different bikes.
they bolt right on to the 77-78 F legs.
the cb900F use twin 30mm pistons.  i used V65 calipers.  they have are twin 32mm pistons.  but have the same size calipers so they bolt onto the 82 brackets
« Reply #61 on: November 15, 2010, 07:47:45 PM »
SNIP
SNIP
I'm using a MC from a VF500, similar. Thanks for the comments and tips. What is the "seal and plate" you speak of?  I'll review the link you've provided.
Nice looking work!
Offline jaguar
« Reply #62 on: November 15, 2010, 09:08:38 PM »
There is an o ring type seal in the master
When I say plate I mean the thing in the window that helps you see the level
Offline jaguar
« Reply #63 on: December 08, 2010, 06:08:46 AM »
Not a whole lot has been going on.
Im a full time engineering student so been studying.....
Still need to order some more OEM brake parts to finish up that as a system.
going to really start thinking about what to do as far as motor for this bike.
been doing alot of reading on what i call a OEM+ motor.  the guys that use the DOHC CB900 cranks and such to make 1000+cc.
i really like the idea of doing that type of build.
anyone have some good links to parts lists or info on builds like that?  would love to do some research and see if that will suit my needs for this bike.
also thinking about running a hydraulic clutch.
started collecting parts.
so far i have a CBR1000F clutch master and slave.
Im going to start there because the master will match my F2/3 brake master and the slave is the thinnest looking that i could find OEM honda
i used bikebandit to cross the OEM part numbers to a few bikes that have the same parts and bought a nice set up on eBay cheap.
goal is to install the slave in the factory cover and hide the slave under the "tin" cover.  I really want that OEM hidden look.
Offline jaguar
« Reply #64 on: December 14, 2010, 01:03:54 PM »
placing an order for the rest of the OEM parts i need for the brakes today.
there were a few bolts that I couldnt get OEM replacements for so i had an idea to use gun blue on them as a refinish
i think it worked well.  im happy with the way they look.
so happy i had a nice beer and watched all of the Indiana Jones movies with the girl....
Offline jaguar
« Reply #65 on: January 05, 2011, 09:25:42 PM »
boiled a few parts in a simplegreen and water mix while the girl was at work.....came out GREAT.
saw that dresda NOS F swing arm......not sure if i want if for this bike or if i want a K one for a different build.
been reading up on different engine builds
i like the idea oh what i call and OEM+ build.  Like that guy that used a CB900F crank and other OEM parts to build a sick stroker
Thats really what i want to do with this bike.  Im still trying to find out what parts are needed so I can start trolling Ebay.
heard a latter F case is better because they have different trans bearings?
K head
cb900f crank
not really sure about rods.  some say DOHC rods but i cant see them as strong enough.
Offline jaguar
« Reply #66 on: January 13, 2011, 09:12:07 AM »
laying out a few wires on the bike.
need to mount the resister packs
Offline Elan
    • Vital Motor Parts
« Reply #67 on: January 13, 2011, 12:45:01 PM »
looking great! subscribed
76 750k
Offline bluesmoke69
« Reply #68 on: January 13, 2011, 07:15:35 PM »
Great build, nice pictures. I am using dual piston calipers on my F1 with F2 forks. Calipers are from 1981 CB750F.
Offline jaguar
« Reply #69 on: January 14, 2011, 10:07:08 AM »
thanks for the kind words
i really like the way that the twin piston brakes look
mine are 32mm V65 calipers with CB900F brackets, still bolt on
Offline HedNut
« Reply #70 on: January 18, 2011, 05:18:40 AM »
Hey Jag!  Where'd you get those resistors... I likem'  :)
Offline jaguar
« Reply #71 on: January 18, 2011, 07:33:38 AM »
Those are a hondaman part.
I got a set to use with my 2.2ohm coils
Offline jaguar
« Reply #72 on: January 18, 2011, 12:00:03 PM »
new pingel petcock
« Last Edit: January 19, 2011, 08:56:20 AM by jaguar »
Offline jaguar
« Reply #73 on: January 25, 2011, 10:23:27 AM »
cb900F crank.
trying to read and learn about strokers and high HP builds.
Offline jaguar
« Reply #74 on: January 30, 2011, 05:15:43 PM »
trying to decide if i want to run this bracket that holds the lines or not
i kinda like it
