Author Topic: OPERATION BIRTH KONTROL  (Read 27908 times)
Offline HedNut
  • Underwater Basket Weaving
Re: OPERATION BIRTH KONTROL
« Reply #75 on: August 24, 2009, 10:11:24 AM »
Wicked Bike! Love the flat black/red look, all your custom details (specially that switch pod!)...and the engine scheme is sik! Can't wait to see her rolling.
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
« Reply #76 on: August 24, 2009, 03:36:17 PM »
thanks hednut ! i am still waiting on some parts and I run into a couple of set backs. Somehow the cables i ordered are like 3 inches longer than the stock ones. Which is not going to work especialy since I have clibman bars. I still have to get some jets and sync the carbs. front brakes needs lines run and bled. Plus other lil things.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline HedNut
« Reply #77 on: August 25, 2009, 09:00:10 AM »
Sweet! Can't wait to see her man..... it'd look damn good with this guitar that I did-up strapped to your back while riding down the hotn'sticky!  Woohooo
  • Mad Fabricator
« Reply #78 on: August 31, 2009, 06:10:21 PM »
Well I got a little bit further this weekend on my project. I am still waiting on some parts. But we are almost there.
I made a plate to mount where the tool tray was for my headlight relays.
And also a fuse for the relays.
And it all fits nicely under my cafe seat.
Then I took a 40 break!
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Zaipai
    • My Home page
« Reply #79 on: August 31, 2009, 08:18:06 PM »
Dude, you have to be so stoked, I would be chomping at the bit wanting to start and ride that thing. It's looking damn nice!
Its my Avatar..
75 CB550F  |
Offline turninwheels
« Reply #80 on: September 01, 2009, 07:56:31 AM »
nice work so far keep it up...
"high powered suicide machine."
  • Mad Fabricator
« Reply #81 on: September 01, 2009, 09:26:00 AM »
The bike does run but i am waiting on carb jets and some other small parts. Also the clutch is stuck. ANYONE KNOW A TRICK FOR UNSTICKING A CLUTCH THAT HAS BEEN SITTING FOR AWHILE? ?
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline HedNut
« Reply #82 on: September 01, 2009, 10:48:09 AM »
Looks fantastic my man!  Good work
  As for the clutch....I would pull the basket and plates....clean and re-install.
I think there was also somebody on here who mentioned putting the bike in gear... and rock it back'n forth "somewhat gently" on the ground with the clutch pulled in.  Eventually released for them.
Offline Operator
  • Someday I will live up to being a
« Reply #83 on: September 01, 2009, 11:03:09 AM »
Nice thread....keep it coming
If ever there was a creator of bastard sons, it is the open road, for she has claimed so many young men yearning for freedom......
1973 CB750 K3
1976 CB400F (Cafe Project)
1979 Yamaha XS400 (Currently up for Sale)
Offline Roach Carver
« Reply #84 on: September 01, 2009, 11:12:26 AM »
all depends on how stuck it is. I unstuck mine by pushing it in gear in the drive way with the clutch in. when it seemed ok I pulled the clutch with it in gear and started it. It had a bit of drag at first. seems fine now.
  • Mad Fabricator
« Reply #85 on: September 01, 2009, 11:45:13 AM »
Thanks again guys ! I went and got insurance today, got the title notarized, waitin on parts. I should have plates and registration tommorow. i am realy trying to get this thing together for saturdays RIDE TO THE MOVING WALL in East Liverpool, Ohio. I don't want to make the entire run just goto to the park and wait for all the other bikes to arrive. Its only a few miles from the garage so we are keeping our fingers crossed.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Toxic
« Reply #86 on: September 01, 2009, 12:14:13 PM »
So i started checking out the harness and looks pretty good everything seems to be ok. When i hook a battery to it the headlight, horn, turns, and brake light all work. I have power everywhere i should.
It's starting to look like a motorcycle again. I can't wait to get the motor back in and get it all wired up.
Is that the whole harness laid out like that?
Are you starting to get the idea you should be mass producing that switch.  ;D
It looks great.  I'd buy one.  Hint... Hint.
Awesome idea since electricity is not my forte.
  • Mad Fabricator
« Reply #87 on: September 01, 2009, 12:27:10 PM »
I strung the harness out like that to make sure everything worked as it should before i crammed it back in the frame. I did eliminate some wiring ( idiot lights, handle bar start switch, clutch switch ) but added some also.( headlight relay wiring )
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Toxic
« Reply #88 on: September 01, 2009, 12:53:13 PM »
I think it's brilliant, mind if I use it.
It must be allot easier to test the circuits on the board.
  • Mad Fabricator
« Reply #89 on: September 01, 2009, 01:29:05 PM »
I tested the entire harness. I got some bulbs and sockets and had everything hooked up. I made sure my headlight(high and low beams)were working, the horn ,the key switch, the turn signals, I made sure i had power at the coil wires, the brake light, and a couple other things. I just mounted the center of the harness up with cushion clamps. Then stretched every lil branch off and marked it on the board. Then removed the tape off of it.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Operator
« Reply #90 on: September 02, 2009, 07:14:03 AM »
That is a fantastic idea for the wiring setup!!
For the mechanically and electrically matarded people like myself, this actually makes perfect sense. I could do that in my basement over the winter as I plan on completely rewiring my bike during snow season. I got a gremlin that keeps eating fuses and signal light bulbs
Nice work
1973 CB750 K3
  • Mad Fabricator
« Reply #91 on: September 02, 2009, 08:03:52 AM »
Thanks operator.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #92 on: September 02, 2009, 04:39:59 PM »
Looking good rustrocket.
Question: I'm wanting to wrap my exhaust.  How many rolls did you need to wrap yours?
Also, those air filters look great!   (Everything else does too, of course!)
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
  • Tuck
« Reply #93 on: September 02, 2009, 04:51:08 PM »
So I searched the thread looking for info on those air filters.
What's the story on them?  I love them.  I want them.  I need them.   ;D
1974 CB 750
1966 Black Bomber
  • Mad Fabricator
« Reply #94 on: September 03, 2009, 09:32:29 AM »
I will have to check and see how much wrap i purchased for the pipes and let you know later. As for the filters there unifilters and i got them from Dennis Kirk.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline HedNut
« Reply #95 on: September 03, 2009, 09:40:32 AM »
Killer Stuff Rustrocket92! I hope you don't mind...your build is quite the inspiration to mine.  You do good work dude!
  • Mad Fabricator
« Reply #96 on: September 03, 2009, 03:01:22 PM »
Thanks Hednut!
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #97 on: September 03, 2009, 03:14:19 PM »
You remember the size (in mm) and part numbers for the unifilter pods?
I think I may be able to supply those for you guys but cannot seem to find their complete part listing.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
  • Mad Fabricator
« Reply #98 on: September 03, 2009, 03:23:40 PM »
UNI High Flow Chrome Filter Kit
Dennis Kirk Part #: 303269
Manufacturer Part #: PK22
I think this is it .
•Part 303269 fits the following machines:
•1969 Honda CB750K
•1970 Honda CB750K
•1971 Honda CB750K
•1972 Honda CB750K
•1973 Honda CB750K
•1974 Honda CB750K
•1975 Honda CB750K
•1976 Honda CB750K
•1983 Kawasaki KZ550A
•1984 Kawasaki KZ550F Ltd
•1983 Kawasaki KZ550F Spectre
•1983 Kawasaki KZ550M Ltd
•1982 Kawasaki KZ650H CSR
•1983 Kawasaki KZ650H CSR
•1977 Suzuki GS550
•1978 Suzuki GS550
•1979 Suzuki GS550
•1978 Suzuki GS550E
•1979 Suzuki GS550E
•I.D. 1 1/2 in./38mm - Installed Height 3 in. - 2 Filters
•Enhance appearance as well as performance
•Stainless clamps, chrome caps
•Includes one clamp-on filter for each carburetor
•May require jetting changes
•EPA regulations may prohibit stock carb adjustments for post-1978 street motorcycles
•2 kits required on most motorcycles
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline HavocTurbo
  • Can you tell?
« Reply #99 on: September 03, 2009, 08:29:24 PM »
TY sir.... I'll go look it up.
09 XL883L - No Name
