Author Topic: Tach stopped working  (Read 1898 times)
Offline smccloud
    • Shaun's blog
« on: August 20, 2012, 07:06:00 AM »
Ok,
While changing the rear tire on my '72 CB750K2 Friday night the tach decided it would stop working (I know they aren't related).  Pulled the cable off the tach and it will only spin if I push down on it.  My guess is the gear stripped out (since its the hardest to fix :) ) since it has been jumping around a lot (and a new cable didn't fix it).  It will also sometimes show 1000 rpm going down the Interstate when it should read 6000-7000rpm.  Is it just time to order a tach plug from Cycle X and put an electronic tach on my bike?  I don't really want to pull the engine to fix this since my '74 engine doesn't have a drive gear you can remove with the valve cover on the engine.  I suppose I could use this as a good excuse to rebuild the factory engine for my bike, but I doubt I can get approval from my wife for that right now.
CB750 K2
Quote from: Hush
Who needs a mobility scooter when you've got a SOHC4?
Gun/Cars/Motorcycles/Computers/Insert Next Expensive Hobby here
Offline Old Scrambler
Re: Tach stopped working
« Reply #1 on: August 20, 2012, 07:24:20 AM »
The gear-drive inside of the valve cover is STEEL. I have never seen a stripped one. Some of the cables are known to have stripped gear problems because they are not properly mounted....i.e. when the oil seal leaked the old one was not removed and a new one was crammed into the valve cover.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline smccloud
    • Shaun's blog
« Reply #2 on: August 20, 2012, 07:25:48 AM »
I did replace the seal a while ago, although I pulled the old one out before putting the new one in.  Still leaked on me though :(  Could the small neoprene washer I put below the cable have cause the cable/end of the drive gear to break?
CB750 K2
Quote from: Hush
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: August 20, 2012, 07:54:17 AM »
Did you pull the tach cable out of its sheath? It will only come out from one direction (from the connector that mates to the valve cover I believe). Pull the inner cable and check for breakage. Sounds like broken tach cable. The tach usually starts bouncing as the neglected cable starts to dry out and the cable starts catching at the dry spots from the excessive friction until the cable succumbs to the added friction and breaks.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline smccloud
    • Shaun's blog
Re: Re: Tach stopped working
« Reply #4 on: August 20, 2012, 08:23:25 AM »
I have yet, have to find my 8mm wrench or buy a new one. I did check the new cable for lube when I put it on at the beginning of the summer and it was fine (as was my old one?). I'm just confused since I thought it was the cable, wasn't and now it's doing this.
Sent from my Galaxy Nexus using Tapatalk 2
CB750 K2
Quote from: Hush
« Reply #5 on: August 20, 2012, 08:27:47 AM »
Ahhhhh.... I was not aware that we were dealing with a new cable. If you have a spare, or can borrow a tach, maybe hook up a different tach to veryify that the problem is not the tach itself, especially before pulling the motor just to get to the tach drive.  :o
TAMTF...
Wilbur
Projects:
« Reply #6 on: August 20, 2012, 08:37:46 AM »
It might prevent the cable from seating fully, stripping the end?
Offline smccloud
    • Shaun's blog
« Reply #7 on: August 20, 2012, 08:40:31 AM »
I still have the old cable, so I can test that.  However the problem happened with two tachs.  The original one and the one from my '74 parts bike :(
I will find out tonight once I pull the cable from the cylinder head (replaced the factory retention screw with a small bolt hence the need for the 8mm wrench).
CB750 K2
Quote from: Hush
