Author Topic: 1973 CB750 Four K3 -- Project "Terry's Fault" -- BUILD RESUMED  (Read 68821 times)
Offline edwardmorris
  • Youngish
Re: 1973 CB750 Four K3 -- Project "Terry's Fault" -- RECONDITIONING
« Reply #275 on: March 05, 2016, 08:34:30 PM »
Waiting on replacement rear shocks/dampers and been very busy in general. Been plating little bits here and there but felt like putting something together today. The carb backplate got done, good call on using the blue chromate fellas ;D Sorry for the blurry pic, need to order some mains and idles then I can put the carbs back together. I had a spare set of float bowls and tops that were in much better shape than the ones I had planned on using earlier, so I got them coated paccar black 55% to have a different shade, pix soon.
Offline mashfu
« Reply #276 on: March 05, 2016, 09:13:20 PM »
That looks really nice!  I want it  ::)
  • Youngish
« Reply #277 on: March 06, 2016, 01:41:28 PM »
haha thanks! The backing plate was powder coated recently but the rest of the carb stuff was done a while back. I'm totally loving the look of the clear/blue chromate on the stealthy black powder, but I hate how easily I tend to get it dirty ::) Gonna keep a new pair of gloves handy when I do the linkage and the rest. Right now I'm dealing with cleaning out some overspray on the carb bodies, not fun :(
Offline mashfu
« Reply #278 on: March 06, 2016, 10:03:39 PM »
Definitely eager to see how it all looks after you've gotten it all buttoned up! The little things always give the biggest headaches  >:(
  • Youngish
« Reply #279 on: March 07, 2016, 03:36:07 PM »
How bad does this overflow look? Should I worry about it getting knocked lose and getting into places?
  • Youngish
« Reply #280 on: March 20, 2016, 11:21:35 AM »
After almost two weeks of getting rid of powder overspray from the fuel passages, dealing with a masking plug that had broken off in an airscrew hole, and a million other setbacks, I finally put these back together. LOVE how the blue zinc looks against the two blacks. All new Honda brass and rubbers.
  • Youngish
« Reply #281 on: March 20, 2016, 11:24:05 AM »
All together and bench sync'd
  • Youngish
« Reply #282 on: March 20, 2016, 11:28:55 AM »
Ordered a tail light "assembly", arrived as tail light, some assembly required ::) Spotless insides 8)
  • Youngish
« Reply #283 on: March 22, 2016, 09:12:23 PM »
Oil pump got Elan's super kit and a NOS screen I had from earlier. He makes better than stock ones now, just in case you need one ;) The impellers/end caps/body are all pretty pristine with minimal scratches. Feeler gauge checks put them in the like new/nos range, thanks to Bill Benton 8) 8). It seems like I always manage to make him go digging deeeeep into his batcave :P :P
  • Youngish
« Reply #284 on: March 24, 2016, 06:57:49 PM »
Trying to decide on electrics, was looking around on Rick's stuff and it seems they have a starter solenoid too? Any feedback on that? I'm thinking about
Rick's RR
Rick's Starter Sol
Hondaman fuse unit
Hondaman safety unit bypass plug
Stock winker relay
Offline mystic_1
  • 1970 CB750K
« Reply #285 on: March 24, 2016, 08:42:15 PM »
Wow those carbs look fantastic, but I would never be able to bring myself to pop the clips for fear of damaging the finish!
mystic_1
- John Augustus Shedd
  • Youngish
« Reply #286 on: March 24, 2016, 09:04:34 PM »
mystic_1
Thanks! Powder is actually a lot more resilient than paint, I've popped them on and off a few times now (had the bowls on there in the wrong order) and its holding up fine. I did get the bowls and crowns done at my local shop where they actually cured it at quite hot temps. The bodies were done by James/harisuluv, but I have no idea how they were cured. I'd have to imagine he uses a special powder that doesn't need high temp curing, otherwise all the brass inserts in the bodies will pop right out, but OCICBW.
  • Youngish
« Reply #287 on: March 25, 2016, 04:12:57 PM »
Bump for the electrics question. Also, was looking around for wheel balancing stick on weights and could only find them in shiny silver color with a pack of like 40 or something crazy like that. Stopped by my local motorcycle shop and found some REALLY nice black colored K&L weights still in their old school packaging. The best part is, the owner just ripped open the pack and asked me to just take however many I think I'd need which was super cool. Bought a handful for $3, will try and get the wheels finished up this weekend.
« Reply #288 on: March 25, 2016, 09:56:12 PM »
I didn't know Rick's made a starter solenoid.  I guess it's a good replacement if yours is roached.
« Last Edit: March 26, 2016, 07:34:53 AM by CB750 Cafe Racer Fan »
  • Youngish
« Reply #289 on: March 25, 2016, 10:12:42 PM »
A while back I also read about reading a CBR starter solenoid for 836 and higher engines, but can't find that info anymore, just need to finalize this stuff and move on...
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #290 on: March 26, 2016, 03:44:57 PM »
I have the Ricks R/R. It plugs right in, and easily bolts on.
--Evan
1975 CB750K "Rhonda"
  • Youngish
« Reply #291 on: March 27, 2016, 04:48:46 PM »
OK, so it seems like their RR is good, but starter sol is iffy at best. Might just do all stock except for the HM upgrades.
Been crazy busy with work and still waiting on quite a few things. The cyls are back from JMR with a bunch of goodies I bought through him, will post pix when I open up everything. Graveyard shift last night, so had little time to work today. Finished up rebuilding the rear shock dampers. There is a long string of fails associated with this attempt (my attempt only, the rebuild is actually super easy), but I think I finally got it done on the third try. First fail was I ended up with mismatched rear shocks, got that corrected and made the monumental blunder of getting them powder coated. Came out looking fantastic but the inner mechanism had welded itself stuck.
Got another set, sandblasted, painted and baked it at home, then finally did the rebuild following the excellent walkthrough over at the hondatwins forum (link earlier in this thread). Couple things I did differently, I added a small amount of AT-205 seal repair/leak stopper to rejuvenate the old top seals and internal rubber parts. Used Dex3 ATF (had on hand, used on my lil Chevy) and the feel is AMAZINGLY uniform. Used zinced up fork drain bolts with the smaller heads that fit nicely without hitting anything. When I tapped the hole for a 6x1.0mm bolt, it felt a very tiny bit too loose, so just for added sealing, I used a tiny dab of permatex on the threads, and torqued it down tightly using new fork drain crush washers. Hopefully these will work out well.
Why all the headache? This one was purely based on the look I'm after, would have been easier to just throw on a set of hagons or konis.
  • Youngish
« Reply #292 on: March 29, 2016, 07:46:57 PM »
Dealing with a little bit of a discrepancy between a yamiya engine cover kit vs the James Spillane kit. Anyone know a good source for stainless metric #3 pan head screws? Allen's Fasteners only go up to 50mm
Yamiya kit
6x20        3
6x30        18
6x35        6
6x40        7
6x50        3
6x55        2
6x63        10
6x75        2
Spillane kit
6x20        3
6x30        16
6x35        6
6x40        10
6x50        6
6x60        12
6x80        6
Offline evanphi
  • Apparently I'm an
« Reply #293 on: March 30, 2016, 07:44:03 AM »
Fastenal has socket cap stainless in all the sizes you have in your Spillane kit.
--Evan
  • Youngish
« Reply #294 on: March 30, 2016, 07:47:01 AM »
I got the pan head kit, not the socket head kit (I don't like that look). I'm trying to see if he has any extras. The few extra large ones I could cut down and make them work, but I still need a few more for the finned covers that won't work with stock kit sizes...
Offline Restoration Fan
  • My wife will never call me
« Reply #295 on: March 30, 2016, 08:04:27 PM »
Yamiya kit
6x20        3
6x30        18
6x35        6
6x40        7
6x50        3
6x55        2
6x63        10
6x75        2
Spillane kit
6x20        3
6x30        16
6x35        6
6x40        10
6x50        6
6x60        12
6x80        6
Rafi,
Our local Lowes has a very good selection that I would bet contain what you need.  Check the Lowes near your house and see if they have them.  If not, PM me and let me know how many you need, what size, etc and I'll go by and get some and ship them to you.
  • Youngish
« Reply #296 on: March 30, 2016, 09:34:15 PM »
Yamiya kit
6x20        3
6x30        18
6x35        6
6x40        7
6x50        3
6x55        2
6x63        10
6x75        2
Spillane kit
6x20        3
6x30        16
6x35        6
6x40        10
6x50        6
6x60        12
6x80        6
Rafi,
Thanks Ron, I'll check out Lowes next time I'm out that way. Many places have SS metric stuff, but two things don't always match up, long length and the pan head shape (almost looks like a circular cheese thingy). Worst case, I'll make my own kit with whatever style pan heads I can find locally as long as all the long ones are easy to find...
  • Youngish
« Reply #297 on: April 01, 2016, 03:30:24 PM »
Picked up all my chrome today, won't be home for hours, just excited :P :P
« Reply #298 on: April 01, 2016, 03:36:22 PM »
That reminds me of the expression, "Chrome don't get you home."
« Reply #299 on: April 01, 2016, 03:49:30 PM »
Maybe it should be "Cant wait to get home with Chrome!"
