Thanks mad, i already changed the block coming out of the alternator, it was fused together so I had to cut the wires, is there another spot where there are bullet connectors? Do i need to remove the sprocket cover to get to them?
hsas.69
I checked and i'm getting 11.96v at 3k rpm, and 12.06 at 4k, well short of the 14.5v i'm supposed to be getting. I have continuity on all the yellow wires from the alternator, rectifier tests as good and so does the regulator. I used twotired trouble shooting guide and ran a jump wire past the regulator and got the same results. I will check the connections to the fuse box, the main battery connections look fine, no corrosion at all.
Maybe I should ask some other questions, which may lead to where the issue is originating...?
1. What is the wattage of your headlight? Is it stock, or an aftermarket, and if the latter, what wattage is the bulb?
2. What ignition coils are in the bike?
3. What type of ignition does it have: is it points, or Dyna, o something else?
Reasons for asking:
1. If the headlight is more than 65 watts high beam, it is overloading the system.
2. If the coils are 3-ohm type (or even lower), they are dragging down the system: stock coils are 4.3-4.4 ohms in the 750F bikes.
3. If the ignition is a Dyna or Pamco (or similar), they draw a lot more power than the OEM points setup.
All these things add up, and can drop the system voltage greatly.
Also, you will not get 14.5 volts on the battery on these bikes: they are made to peak out at 13.6 volts, at which point the regulator shuts off. This is a "voltage limiting" system, not a "voltage regulator" type system. There are some aftermarket voltage regulators out there that will raise this voltage, but they usually cause dried-out battery problems, or worse, in the long run.
Many times, these bikes accumulate things from previous owners that end up not being a good idea. Just one example: I just "fixed" a beautiful 1976 CB750F1 that had chronically low battery troubles for years. Even at mountain riding speeds, after 15 minutes in heavy (30 MPH) traffic upon his return the battery voltage would drop off until the headlight dimmed, turn signals stopped flashing, and his electric start would not work after he stopped for dinner. This had been going on for YEARS. The problems: someone installed an 80w H4 halogen headlight, 3-ohm Dyna coils, and a Dyna S ignition. Total wattage of just these 3 items was more power than the alternator can even make! The fix: installed a 55/60W H4 bulb, 5-ohm Dyna coils. He is planning on switching back to points and using one of my Transistor Ignitions as soon as he can find a spark advancer, so he can make a trouble-free trip to Florida this summer.
