Author Topic: 1972 CB350 For the Daughter  (Read 77432 times)
Re: 1972 CB350 For the Daughter
« Reply #400 on: May 06, 2017, 10:19:05 AM »
It never hurts to ask him about it to start that dialog.  I would suggest you ask the question in another thread to see if anyone else has ideas on this.  Drop calj a pm ask him about it...he is a smart guy.
I wonder if TwoTired could lend any expertise?  He is back briefly before heading out with the next load to AZ ( moving and has not estabished internet service in AZ.)
« Reply #401 on: May 06, 2017, 10:25:12 AM »
Does cam chain have any effect on the timing pulses?  I don't know how Pamcos are installed, can they be advanced or retarded by rotating the pickups? Do you align them with the T or F mark?  How are they indexed for installation?
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #402 on: May 06, 2017, 10:45:34 AM »
Swapped the PAMCO's.  Starts up easily, but idle is a few hundred rpm's lower.  Tweak the scews a tiny bit to get the idle a bit more stable.  Purring at 1000.  Check the timing and both cylinders are still a bit advanced, but not as bad as before.  Adjust the plate and it gets a bit better, but still off.  Adjust both boards and it gets a tiny bit better.  I am now about 7 degrees advanced.  Run the engine up to about 4000 rpm's and the right cylinder is on the left of the two full advance marks.  Check the left cylinder and it is a tiny bit on the advanced side.
Not sure what to do next.  I don't know if somehow during the high idle starts the cam chain stretched.  Maybe the CCT moved a tiny bit.  I lock tighted them, but maybe the cam bolts loosened up a bit.  When I originally took the engine apart they were loose.
I don't know if I can pull the top off of the engine without pulling it from the bike?  How much does being one tooth off affect the timing degree wise?  5, 7, 10, 20 degrees?
« Last Edit: May 09, 2017, 06:59:29 AM by Harsh »
Offline Harsh
« Reply #403 on: May 06, 2017, 10:49:54 AM »
Sort of.  It doesn't affect the timing pulses, but it does affect the relationship of the crank and cam shafts.
They are adjusted by rotating the backing plate.  You align them with a strobe light at the LF and F marks.  They install just like a normal points except they have some oblong hokes cut out of the sides to allow for some adjustments.
Offline Harsh
« Reply #404 on: May 09, 2017, 08:21:44 AM »
Still dealing with the timing issues, but hopefully substantial progress will be made today.  While I have been working on that a buddy has been working on a set of rearset riser plates.  However, the packaging left a little bit to be desired.  I mean, who needs enemies when you have friends like this.
The center part never fully cured and was still gooey.
My face, well I was laughing my ass off.
All the trouble was well worth it.
« Reply #405 on: May 09, 2017, 10:12:56 AM »
Nice!
Must have went through a couple cans unless he worked somewhere that used the foam to pack things, he definitely created some work for you to get it out.
Nice to have disposable gloves on when you open something like that...but Murphy's law reigns during those times...  greasing the mower yesterday I did it without gloves  when a pair of gloves were less than 15 feet away...  I guess I can't help being dumb sometimes.
You would expect your friend having done this and the center still be a goey mess.
But, well worth that customized set of kit, he has access or did them on CNC...cannot imagine someone doing that script by hand.  Are they anodized?
That would make their upkeep be far less maintenance intensive and less work the few dollars it would require.
That will look very trick.  Are you putting Tarozzi rear sets on?  They are inexpensive and commonly available.
You probably already documented it but I am too lazy to go look it up.
How is the paint work coming along?...another week or two?
How is your daughter liking it?  She still working day shift....
Hopefully she will be able to enjoy it for the summer before she pulls sea duty again...
The area/place you mentioned that you stay at/or have a place at is a nice area.
Lived in Boone for a year and one half after clege in 1 st compay I worked for...the back side of Grandfather mountain between Blowing Rock and Linville was a very nice curvy rooad... there were tons of fun roads in that area.  221 is the road I refer to...
The Viaduct for the Blue Ridge Parkway was constructed while I lived there, climbed up and explored inside it on a weekend when no one was around, it is a pretty cool cave like inside, hollow sections bolted together between pylons.
If both were off consistently on timing I would think they were having a install issue as plate was retarded too much...
the cam can be retarded or advanced relative to the crank  because of the chain allowing it to be stepped  forward or backwards off the marks for zero timing, having no advance or retard from the reference marks.
I don't know how the two sides can vary that much when properly installed.
Anyone else offer suggections or thoughts on why the trigger is different  between sides?
If it were even it would point to an issue with the trigger plate.
Or trigger magnet or what ever the trigger for the pickups use.
Look forward to more photos in the next update...
David
Offline Harsh
« Reply #406 on: May 09, 2017, 10:31:39 AM »
My buddy works in the R&D machine shop at Chrysler so he has access to all kinds of nice equipment.  They are not anodized, just raw aluminum. I forget which number but he wouldn't use something that wouldn't hold up.
Paint is done, but I have to get the front fender fixed since it fell off of the work bench.  I am using a set of rearsets from slipstream cycle.  While they look nice the claim that they are 100% bolt on and functional for a CB350 isn't true.  There is no way you could use them if you run an exhaust in the stock location, which is why I had to get the risers made.  For a scrambler they will work perfectly fine though.
She is still working day shift, but will be getting out soon.  I guess the military just wasn't right for her.
Both (left and right) are off by the same amount at idle, but slightly off at full advance.  However, there is a big difference between the two units.  We will see how using the old points goes today.  If I can get the timing set with those I will be making a call to Pete to see about swapping out the new unit.  It is weird though because the first time I went to set the timing I had to advance the plate because the timing was a little retarded.  Then the high idle starts started and everything went crazy.  Now I am too far advanced even with everything adjusted to fully retard the firing.  However, the engine sounds beautiful.
« Last Edit: May 09, 2017, 10:34:35 AM by Harsh »
Offline Harsh
« Reply #407 on: May 09, 2017, 01:48:45 PM »
OK...I got the points adjusted.  Just like the PAMCO I had to adjust the plate fully ccw, see first pic.  Fire up the bike and I had to adjust the idle set screws because the idle was way too low.  The bike does not sound nearly as smooth and there is a tiny bit more ticking from the left cylinder.  Fire up the strobe light and the left cylinder is still off.  I placed it where it is firing at idle, see second pic.  It is off by the same amount at 3500 rpm.  This is pretty much spot on where I was able to get the PAMCO to fire the other day.   The right side fires right on the mark and on the left of the two advance marks anywhere above 3500 rpm.
Is it engine pulling time?
« Reply #408 on: May 09, 2017, 10:54:09 PM »
With it running well statically I am thinking when you load the motor it is likely to fall on its face.  The advance curve/behavior seems to be rather wonky.  Your strobe/timing light is not lying...is the 2nd mark something like 20 degrees of advance or is it 10 degrees.  If 20 then you are going to have issues with that cylinder when you wind it up to 10k ...actually long before that if the advance is maxing out at 4800, right?
Surely it os not a carb problem.
The adage of 90% of electrical problems are carb problems.
I don't think It would be nice to pull the rack of carbs offf your wife's bike to install on this bike...but that would rule out a carb problem.    It makes no sense for the curves to be screwy between sides and it running well.
Anyone on the Honda Twins site offer a suggestion?  Or, have you asked anyone there?
If your rotor/ flywheel was keyed and key had sheered and rotor slipped on the shaft would you be able to adjust the carbs and it run well statically?  But, it does not make sense for it to be fine on one side but pushing the second mark on the other side.
For both units to exhibit the same kind of behavior is it pointing to a bike problem because it should be fixed if the Pamco unit were bad.
 You do not have an advancer in the circuit with the Pamco as it handles that electronically if I recall your earlier post, but with points you have to reinstall it.  The advancer mechanism does not discriminate and only advance one side...it would be across both, so the advancer is fine in all likelihood.    That kinda points the finger in another direction, right?
Could it really be a carb problem with the advance on the bike pointing to something wierd on this bike?  The advance curve on the Pamco would not be screwed up on both would it?
Two coils or one coil? You are switching leads on the timing light to see the second cylinder firing pulse if it is two outputs or two coils, right?
Installing the Pamco from your daughters bike on the wife's 350 should cause wierd running and timing strobe there if it were the Pamco unit. It is a mystery why it is being strange like this.
It isn't like it is going to be a ton of work to pop the Pamco on the wife's bike to test it there.
If the running problem is non-existant there it is an issue with the bike.  A carb problem should cause it to run crappy with the advance screwy, no?
Just thinking out loud considering things with this puzzle.
Offline Harsh
« Reply #409 on: May 10, 2017, 05:30:57 AM »
Going through the revs it acts fine.  No stumbles or having to feather it up.  Not sure which second mark you are referring to.  If it is the one to the right of the LF mark, that is the LT mark which is very close to 10 degrees.  If you are referring to the two marks to the left of the LF mark, those are the full advance marks which I am pretty sure are 30 degrees.
I do not believe it is a carb problem.  It guess it could be possible that the keyed sheared or twisted during the high rpm starts.  I did have some starter chain slap when starting with the high idle starts.
I have a running thread on Honda Twins and have spoken with a member (outobie) on the phone to go through things.  There is a pin on the cam that is supposed to be at 12 o'clock when I put everything together and the crank at the LT mark.  However, the difference between the LF and LT marks being very close to 10 degrees  it is possible I either lined it up on the LF vice LT mark or it moved when I was trying to get the cam gear installed on the cam.  There isn't a whole lot of room to work when you are putting those parts together and it is easy to move the chain and crank and not notice it.
I can't check to see if it is off a tooth with the engine in the bike since I can't remove the top cover while in the frame.  One tooth equals 13.846 degrees.  I am really leaning towards it being a tooth off.  If you factor in how much I have to retard the timing, with the amount of adjustment available, and how far I am still off moving it one tooth would probably put it somewhere near the middle of the adjustment range.
I think out loud all the time.  My wife just shakes he head approvingly, but I know she doesn't have a clue about what is going on.
« Reply #410 on: May 10, 2017, 11:12:56 AM »
VJMC email list brought this up...thought you would like to see it...
photo is maybe worth the price of admission...
Fox News >  Hagerty info source
CLASSICS
The most-popular motorcycles among millennials
By Andrew Newton  Published May 05, 2017  Hagerty
There are many reasons why classic motorcycles are increasingly popular among younger folks, aka Millennials. Aside from the sheer excitement of riding a fast bike—something Hunter S. Thompson called “a bloodcurdling kind of fun”—most motorcycles are pretty easy for the home mechanic to work on.
There’s no tightly packed engine bay that requires you to do contortions or remove other car parts before finally reaching what you actually want to work on. And they take up a fraction of the space needed to store a car, even a small one. There are also a dizzying number of choices, from mopeds to superbikes and enduros to cruisers. Most importantly, vintage bikes tend to be cheap, which is something that younger folks, saddled with student debt and high rent, appreciate.
According to long-time motorcycle rider and writer Paul Duchene, “What you often see among younger people is the Japanese stuff. The Japanese really cracked reliability in the 1970s. You’re also going to see the bikes that people bought, kept, and cared for, rather than the really racy stuff that people took to the track or crashed. And you’re also going to see a lot of 500-, 600- and 750-cc bikes, since anything over one liter represents a hike in insurance premiums.”
Below are the five most popular makes for riders born 1982-2002, as measured by insurance quotes over the last five years. These brands make up 75 percent of the quotes measured, and 78 percent of them are valued under $10,000. Bikes from the 1970s are also particularly popular among millennials; 41 percent of the motorcycles quoted hail from that decade.
Honda
If this was a list of the most popular bikes by model, all five spots would be 1970-74 Hondas. They account for 29 percent of the buyer interest among millennials over the last five years. Between CB350 twins and the ubiquitous CB750 fours, there are oodles of vintage Hondas on the market at any given time. Honda is also credited with finally bringing electric starters and reliability to performance motorcycles, a mostly foreign concept for European bikes at the time. High-production volume, great parts availability, low price, and the fact that you can always count on your Honda starting are the reasons why younger buyers find them so appealing.
Harley-Davidson
Harley-Davidson’s status an American icon has been talked about ad nauseam, but there is no denying Harley’s appeal among all generations. Interestingly enough, while Harleys are twice as likely as Hondas to be quoted overall, they make up only 24 percent of buyer interest among millennials, as opposed to 29 percent for Hondas. According to Duchene, this may be because “Harleys are generally quite expensive for what they are, and people tend to keep them forever or trade them in on new models.”
Yamaha
Yamahas make up 11 percent of buyer interest, and for millennials it’s much the same story as Honda. They’re appealing because they’re generally cheap and reliable, and ample parts are readily available.
Kawasaki
Kawasakis, with 6 percent of buyer interest, are among the wave of reliable and affordable Japanese bikes that came on strong in the 1970s and ’80s. “Just about the best affordable all-purpose bike out there is the Kawasaki KLR 650,” Duchene says.
Triumph
If Harley is an American icon, then Triumph is a British icon, and it accounts for 5 percent of buyer interest. Bonnevilles didn’t change much at all during the 1960s, and Duchene notes, “Lots of them are being restored. People have fixed up so many of them that they’re cheap, and owners tend to just ride them around town on the weekends, which these bikes are quite good for.” Triumphs generally aren’t going to be as reliable as their later Japanese counterparts, but parts availability is good, and they appeal to younger buyers who want not only a usable classic bike but something a bit different and more interesting than the more common Hondas.
RETURN OF THE DUCATI SCRAMBLER:
http://video.foxnews.com/v/4491469525001
Offline Harsh
« Reply #411 on: May 10, 2017, 05:03:11 PM »
Did you just call me a millennial?  Damn, I thought we were friends 😉
Decided to just go for it and pull the engine.  Not wanting to scratch the frame I rigged up my chain fall and was able to lift the engine and manipulate it around the frame.  Worked like a champ
Took one of the upper mounts and spun it around so it pointed away from the frame.
I think I may have goobered up the initial assembly.  The parallel line on the cam sprocket is pretty damn close when the crank is at the LF mark and not so much when on the LT mark like it is supposed to be.  Unfortunately, I can't put everything back together because the left rocker box gasket tore when I took it off.  At least I now know what was wrong and can fix it.
Thank you to everybody who provided input and assistance trying to figure this out.
At LT mark.
At LF mark.
« Last Edit: May 11, 2017, 05:43:26 AM by Harsh »
« Reply #412 on: May 10, 2017, 06:19:26 PM »
Not   a chance, you are probably an old fart like me, but probably younger than I...
My nephews & neices are Millennials, as are my son and daughter, my daughter turns 29(1988) this Nov. and my son turned 25 (1991) last month. (3 yrs 7.5 months between them...)  most of Gen Y/Millennials do not view themselves a "Gen ?" Or Millennial...they don't adopt that nomenclature.  Baby Boomers or Gen X will use those terms far more readily.
To really insult you I would call you a hipster...
never would those words cross my lips concerning yourself.
I just thought you would appreciate that you chose a couple desirable bikes for those buying vintage/classic bikes.
Got any gasket material that works in oily locations, cut cut your own if you want to do that and not wait for a replacement.
The Yahoo S90 group had copied/scanned the multiple versions of the gaskets for the motor for identification or to cut your own if you need one or two.  That kind of thing would be handy if you need a gasket and in a hurry.  I may carry a scan of the 550 gaskets so when traveling on the bike I could cut new ones for some of the gaskets you could "roll your own."
So, glad you found the source of the issue...retarded a bit too much could nick a valve possibly if cam design was long duration and lift with overlap...right?
Hope you are doing better, nice motor removal technique.
Imagine you are eager to test it now.
David
Offline Harsh
« Reply #413 on: May 11, 2017, 05:43:08 AM »
Yah I was just messing with you a bit.  I am certainly a few years younger than you, but I am no spring chicken.  You would be correct though if you had called me a hipster, now those would have been fighting words.  I did appreciate the article though.  If I were to ever sell one it would be nice to get back what I have put into them, but that will never happen.
I am going to call my dealer today and hope and pray he has a gasket in stock.  One of the maintenance techs there was working on his 350, but sold it.  I know he had all of the gaskets for it, but I don't think he did anything with them before he sold it.  The only gasket material I have is some cork stuff, but it is pretty thick and certainly would cause fitment issues.
I am not versed enough in the came duration and lift to know if it would nick a valve.  However based on the sound of the engine I don't think it did.  I would think that would be a pretty noticeable sound if the piston and valve were making contact.
I am eager to get it fixed, buttoned up, and back in the bike.  Once that is done I should be able to correctly time the engine and get it on the road.  I just hope I don't run into any more issues.
Offline Harsh
« Reply #414 on: May 11, 2017, 04:13:43 PM »
My luck was strong today.  There is a tech at the dealership that had a 350 that he was going to restore, but he sold it for some quick cash.  He had mentioned that he already had a gasket kit for it, but I didn't know if he used it or sold it with the bike.  I called and he still had it and was willing to sell it for $15.  I picked it up after work.
Decided to pull the head to make sure the valves didn't contact the pistons.  All good there.  It took forever,  but I was able to get the camshaft installed and aligned correctly.   I used the Clymer manual for directions because it is one of the rare cases where it is easier to understand.   However, using their method takes two people.  I had my daughter turn the crank while I lifted the cam to keep pressure on the chain.  I will set the valve lash tomorrow and hopefully get the engine back in the bike.
« Last Edit: May 12, 2017, 04:36:46 AM by Harsh »
Offline Harsh
« Reply #415 on: May 16, 2017, 04:43:35 AM »
Valve lash was set Friday, but evidently I wanted to take the wife and kids to dinner and a movie  ::)  so I couldn't do much else.
Saturday and the engine was re-installed.  Hook up the gas and it dribbles out of the left overflow tube.  A few raps on the carb and it stops.  Thumb the starter and it is slow to turn over.  Check the battery and it is almost dead.  So on the charger it went.  I hope I didn't kill the battery when I was messing with the points.
After the battery charged back up the bike started just fine.  Of course I had to mess with the idle adjustment screws.  It boggles my mind as to why I have to adjust those every time.  The timing is all over the place.  I presume it is because of all the messing around I did with the individual electronic boards.  I could get one side adjusted correctly, but the other side would be off.  Make some adjustments and each side is off.  Make some more adjustments and the original off side is now on, but now the side that was good is now off.   Back and forth like this for a while.  I was getting frustrated and the bike was getting hot so I called it for the day.  Of course there was no working on it Sunday.
There is also a very noticeable tick.  It doesn't sound like the smooth sewing machine it did like the first time I started the bike.  So I am going to revisit setting the CCT and valve lash to make sure something didn't settle in after the bike ran for a bit.  The cam index pin is pointing directly at 12 o'clock when the crank is at the LT mark so I know that is good now.  The engine did rev up to 8000 rpm with no problem, but there was a tiny bit of white smoke coming from the exhaust when I did that.  I definitely have to do a little touch up painting to the engine.  During the removal, installation, and tear down I chipped it in a number of spots.
Monday:  Hopefully it will be a good day and I can finally put the engine work to bed.  I would love to be able to concentrate on finishing everything else.  Managed to get it timed yesterday.  What a pain in the rear that was.  Because I had previously messed with the individual boards it took a while to get them adjusted correctly along with the placement of the main adjustment plate.  The right cylinder is ever so slightly advanced, but I couldn't get it to adjust anymore.  When revved up it is right at the marks showing full advancement.  The bike doesn't get ridden at idle so I don't see an issue with it.
Since that was done I was able to turn my attention to fabbing up the brake reservoir mount, exhaust supports, and I have what I believe is a great and simple plan to keep the kickstand from hitting the exhaust.  All I have to do is make the required bends and bolt it on.  Going to talk to the painter today about fixing the front fender and see if he will weld the mounting tabs on the exhaust.  I haven't heard back from the guy that did the powder coating for me.  I still need to get the rear brake rod from him.  So a text will be going out today to him.  I plan on going to the DMV today to get the plates.  They usually don't have the antique plates there so it will probably be a week before I get them.  I guess it is time to start an actual checklist of what need to be done to complete the bike.
« Reply #416 on: May 17, 2017, 10:03:58 AM »
Congrats getting it to this point, so close you can taste it.  Do they give you a temporary paper plate until the custom ones arrive. What did your daughter use for personalized plate phrase or just a vintage plate with whatever sequence they were at?
So, all these descriptions and you still haven't done the reveal.  Look forward to seeing how it all comes together in the full shots for the centerfold edition...
David
Offline Harsh
« Reply #417 on: May 17, 2017, 11:23:05 AM »
Yah, just lots of little things.  The front fender is back at the painters and they are also going to weld the support tabs onto the exhaust.  They printed a temporary plate, but it is for a car and I doubt I will need them before I get it on the road.  Antique plates here can't be personalized.
I know I haven't shown any pics of the reveal.  To be honest I don't think it will be as grandiose as I originally thought it would be.  It is still cool, unique, and something NOBODY else has though.  Maybe this weekend if I don't have any more snags.
Offline Harsh
« Reply #418 on: May 21, 2017, 06:10:31 AM »
Since I never put up pics of some of the minor stuff I have been doing here you go.
Rotor and wheel caps installed.
Side covers.  I used the original tank emblems and painted the letters to match the powder coat.
And last, but not least the tank.  The design is based on the first time the wings made an appearance.  Since the original inspiration was based on the Greek goddess Nike and since this is my daughters bike I changed the original winged logo to a female.  I wanted it to be a bit sexy, sort of like the old hood ornaments on cars.  I can't thank thrillseeker on Do The Ton for taking what I had envisioned in my head and making something beautiful.
« Reply #419 on: May 21, 2017, 11:25:11 AM »
I like the Winged Victory and the drilling on the front disc (something unique).
Offline riverfever
« Reply #420 on: May 21, 2017, 01:46:50 PM »
That's a very unique color and should look really nice on the frame. Love the logo as well.
« Reply #421 on: May 21, 2017, 04:23:44 PM »
Very cool Harsh!  That came out nice...very nice.
I don't know what it is today but my arthritis is really talking to me, hands & wrists, shoulders, neck, spine,  knees and especially the right hip.  So, no cycle work today... it doesn't correspond to a front coming through as we had quite a bit of rai today, but it came in yesterday.
Guess I should observe a day of rest every Sunday anyway...
Thanks for sharing some of the details.  I love details.
Tomorrow I can return to getting the Cummins 6BT fuel system bled of air and  get it moving. P7100 injection pump and Cummins lift pump with a rubber piston actuated to move the fuel 15-20 feet from tank to the motor.
Up hill of course...
The Navy Seals expression comes to mind, "The only easy day was yesterday."
That is a sexy logo.  What is your daughter thinking of everything coming together?
David
Offline Harsh
« Reply #422 on: May 22, 2017, 04:16:46 AM »
Thanks everybody.  I love the Winged Victory.  It is simple, classic, and has some sex appeal to it.
My daughter hasn't seen it yet.  She saw the front fender in the garage, but that is it.
Plates came in the mail Saturday, but noticed on the registration they put the color as red when I typed sage.  I guess I will be making a trip to the DMV today.  Still waiting on the rear brake rod and hopefully the front fender and exhaust will be finished early this week so I can get them bolted on.  It is getting close to being completed.  I only have one weekend left before I head out to the mountains so hopefully I don't run into any snags with putting the rest of the bike together and what tuning and adjustments I will certainly have to do will be easy and minor.
Offline RuckyOne
« Reply #423 on: May 22, 2017, 04:03:08 PM »
Amazing work! I love the attention to detail and the color scheme!
Current Garage:
1973 Honda CB750 Café/Brat
2013 Honda CB500F
2017 Honda Ridgeline
Past Builds:
2009 Honda Ruckus
2008 Honda Ruckus
1992 Honda EG6 Sir RHD
1990 Honda CRX Sir Glasstop RHD
Offline AlabamaCB750
  • Competent CB750K2 Owner
« Reply #424 on: May 22, 2017, 04:42:12 PM »
Beautiful work! Very original too. If my wife walked into the bedroom and saw one of my tanks on the bed...it would not be good to say the least. Lol!
