OK.
You'll need to complete a series of plug chops with NEW plugs, beginning with a WOT plug chop to see if your 110 main jets are correct.
Please take the time to read up on how to properly do a plug chop, and make the necessary changes to your main jet, if needed.
Once main jet is correct, then move on to a 2/3 throttle position chop, make needle clip changes as needed.
Then on to 1/4 throttle position chop to check for proper pilot jet sizing, and change as necessary.
Lastly, idle chop for mixture screw setting followed by a vacuum sync.
It'll take 6 +/- sets of plugs....lean (white) plugs can be reused for the next chop.
If you complete the above accurately, your bike should pull hard at all throttle positions and to red line.
