Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 202273 times)
Offline Camrector
Re: 1974 CB550. Monoshock. Engine Build. "BLAC"
« Reply #800 on: April 02, 2017, 03:58:54 PM »
Sweet!
Offline BLAC
  • An espresso is a
« Reply #801 on: April 03, 2017, 02:57:07 PM »
Engine build details:
Stage 3 Porting
APE Race Balanced Crank
Polished, balanced and Shot Peen Rods
59mm Wiseco Pistons
Kibblewhite Oversized Valves
Serdi Valve Job
OEM Valve Guides
Guide R/R
Guides Honed
OEM Valve Guide O-Rings
Kibblewhite Valve Springs
Portmatched OEM Intake Manifolds
OEM Late Model Rode Bolts/Nuts
Viton Guide Seals
Tapered/Backcut Intake Valves
Milled Head -0.003
Bore Intake Seats 0.9
Cylinder Bored
Cylinder Decked
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline innovativems
    • Innovative MotoSports
« Reply #802 on: April 03, 2017, 03:18:15 PM »
Stage 3 Porting
59mm Wiseco Pistons
Serdi Valve Job
OEM Valve Guides
Guide R/R
Guides Honed
Viton Guide Seals
Milled Head -0.003
Cylinder Bored
Cylinder Decked
That baby will be a runner!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline BLAC
  • An espresso is a
« Reply #803 on: April 03, 2017, 03:41:05 PM »
As long as I put it together correctly  :P
Offline BLAC
  • An espresso is a
« Reply #804 on: April 11, 2017, 12:42:47 PM »
Alright!  It's go time!
Got something in the mail!
via Imgflip GIF Maker
The goods!
Stage 3 JMR Head w/oversized valves
Intake Port
Exhaust port:
Vapor blasted, decked and bored cylinder:
Polished, peen'd and balanced rods (with late model 750 hardware).  I had a gram scale out and each one is 301 on the dot! (not to second guess JMR's work, more to appreciate it  ;D)
Wiseco forged aluminum pistons:
Now it is time to start the assembly! (don't worry, y'all wont miss out on the build... I will have tons of questions as I second guess myself throughout the entire process)   ;D
« Last Edit: April 11, 2017, 01:18:35 PM by BLAC »
« Reply #805 on: April 11, 2017, 01:22:02 PM »
Another stellar port job from JMR!
« Reply #806 on: April 11, 2017, 04:26:54 PM »
Intake Port
Exhaust port:
FYI -- some will refer to this as a Stage 4 JMR head (Stage 3 with oversize valves).
I always love Mike's description of his Stage 3 job:  "This head kicks ass . . .  no disappointments no matter the displacement."
Offline BLAC
  • An espresso is a
Re: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"
« Reply #807 on: April 11, 2017, 04:42:04 PM »
Ah gotcha! I think it is just the oversized intake valves, so maybe that is 3+ :P
Is there any pros/cons to installing the piston/rod in from the top of the cylinder then attaching it to the crank vs attacking the piston/rods to the crank then lowering the cylinder down on top of it and installing the pistons from the bottom? I have seen it done both ways.
To me it makes sense to install them from the top as the rings will scrape the excess oil off the walls (functioning as they would typically) instead of pushing them up from the bottom with oil getting collected on top of them?
Probable doesn't matter too much either way..
« Reply #808 on: April 11, 2017, 04:51:00 PM »
B,
Let me know if you need to borrow a piston ring compressor tool.  I have one.
Offline SF
  • I burn gas very well
« Reply #809 on: April 11, 2017, 05:03:11 PM »
What rods are those? OEM? Dam those parts are beautiful.
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline BLAC
  • An espresso is a
« Reply #810 on: April 11, 2017, 05:04:50 PM »
Yep they are stock rods that Mike worked his magic on (with the upgraded hardware from the late model 750)
Offline slikwilli420
  • Master of Disaster
« Reply #811 on: April 11, 2017, 06:35:31 PM »
Step up and coat your slugs-
Who do you use Cal? I've seen Swaintech mentioned but was curious who you used.
Offline BLAC
  • An espresso is a
« Reply #812 on: April 11, 2017, 06:36:28 PM »
That was my follow up question also. I just sent an email out to Calico as well.
Offline Restoration Fan
  • My wife will never call me
« Reply #813 on: April 11, 2017, 06:57:31 PM »
B,
Bryan,
Take it from me.  You DEFINITELY want to use this piston ring compressor tool.  It saves a ton of time & effort.
Offline BLAC
  • An espresso is a
« Reply #814 on: April 11, 2017, 07:30:23 PM »
B,
Bryan,
Definitely! I'm going to check with my GFs grandpa to see if he has one before I head down to longbeach though ;)
Any thoughts on pistons/rods going top down or up through the bottom?
« Reply #815 on: April 12, 2017, 08:17:54 AM »
Glad everything arrived in good order Bryan. That was a very comprehensive project.
  I PM'd you to remind that the cylinder needs to be thoroughly washed out with hot, soapy water. Dry and wipe the sleeves out with paper towel and WD40 until the towel comes out clean. Cleanliness cannot be over emphasized! ;) ;D
Offline BLAC
  • An espresso is a
« Reply #816 on: April 12, 2017, 11:02:51 AM »
Will Do!  I am considering painting (or some other expensive treatment Cal makes me pay for  ;)) the cylinder and block sanding the fins, either way it will be spotless when I install it  :D
Thanks again for doing all this work for me. I was typing up and email but figured it might just be easier to reply to your comment here. I am beyond excited to get this thing together and making noise. Needless to say, everyone I have shown photos to have been blown away by your work!  Now I just need to sell some body parts and make a call to Megacycle  8)
Offline BLAC
  • An espresso is a
« Reply #817 on: April 12, 2017, 02:33:48 PM »
I was planning on the 126-20.. I will check the pistons when I get home and see if they are cut yet
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #818 on: April 12, 2017, 04:41:25 PM »
Got 2 ring compressors if you want to add to your collection of tools
Offline BLAC
  • An espresso is a
« Reply #819 on: April 12, 2017, 04:54:57 PM »
Offline BLAC
  • An espresso is a
« Reply #820 on: April 12, 2017, 04:57:56 PM »
You are on my roof with the hose turned on.
Offline BLAC
  • An espresso is a
« Reply #821 on: April 12, 2017, 05:05:55 PM »
You just want to finish at the same time so you can eat my lunch in the BOTM voting! you bastard!  :P
Offline Camrector
« Reply #822 on: April 12, 2017, 08:25:41 PM »
Feel the same way when Cal responds on my post too!  ;D ;D
Unfortunately he is almost always correct. You will have to mill those pistons or use a different cam. I have a new 126-00 that I could put in the mail tomorrow for you if you decide to go that route.
I used different pistons to avoid having to mill and get a point or two  more compression to run the 126-20
Offline flatlander
« Reply #823 on: April 14, 2017, 11:45:18 PM »
just confirming what you know already: 126-00 doesn't give such trouble. but i'd measure anyway with clay, to be safe.
Offline BLAC
  • An espresso is a
« Reply #824 on: April 15, 2017, 01:04:40 AM »
Ya I hear ya, but part of me wants to just go for it with the larger -26... we'll see..
So tragity struck. I'm reassembling my transmission and realize on of my case pins (that is at the ends of the transmission shafts) is missing  >:(
Here is a photo I took during the disassembly.  I still have the one closest to the camera, the other one is gonzo.
Do you know if these are both the same part number? If so I will just make another one out of a drill bit in the morning..
