Author Topic: Blown head gasket *  (Read 610 times)
Offline josherr
Blown head gasket *
« on: June 01, 2016, 01:51:18 PM »
Hi i got a 75 CB 550 about a year ago and finally had the time to put it together and even did a top end rebuild with new gaskets and valve guides and I took it to a shop to finish the electrical and get it running and he calls me back and tells me I have a blown head gasket and will cost upwards of 1500 to fix
So I just wanted to get some feedback on different opinions on what I could do
I was really looking forwards to riding this summer went ahead and got my license and my gear but now that's on hold .... What a bummer
Offline Swoop
Re: Blown head gasket *
« Reply #1 on: June 01, 2016, 03:49:59 PM »
"Blown head gasket" is generally a reference to a water-cooled engine. These are air-cooled. So, exactly what does "blown" mean in his vocabulary?
If the bike is not running, how has he discovered or determined there is an oil leak necessitating replacement? And honestly, I would not pay a shop $1,500 to replace a head gasket when it is likely not the issue (if there is a legitimate issue) anyway.
Under your valve cover, there are 8 rubber "pucks" that need to be installed above the head stud nuts. Did you get and install new ones? Did you install the head, torque the head properly (with a torque wrench) and repeat the process after 24 hours? If not, its very possible the head needs simply to be re-torqued.
So, lets get some more details before you authorize $1,500!!!!
+1
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: June 01, 2016, 04:04:18 PM »
Get your bike out of that shop ASAP. Obviously the guy is looking for cash from some poor sucker.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: June 01, 2016, 06:31:36 PM »
Shyster alert! Take your bike back pronto! Pay for the work that has been done and get your bike back.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline josherr
« Reply #4 on: June 01, 2016, 06:48:24 PM »
Alright I did a top end rebuild with the following
And I installed these rubber seals
And bought this video and followed the dudes instructions
I can't remember what I I exactly torqued it too but I did not do it twice
And when I got it back in the frame and added oil it started leaking oil from the top
