SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
Proven Tricks & Tips / How To's - NOT for Quesions
Carbs
(Moderator:
Gordon
Topic:
PD42B Carb re-assembly for CB750K
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: PD42B Carb re-assembly for CB750K (Read 3126 times)
ansbernais
Full Member
on:
September 13, 2018, 06:59:20 PM »
Looking for a little help with my Keihin PD42B carburetors. They go on my 1977 CB750
Can someone tell me where this little plastic piece goes. It was tagged to Carb #2. Not sure exactly where it goes.
Any help appreciated
Logged
dusterdude
Really Old Timer ...
Re: PD42B Carb re-assembly for CB750K
Reply #1 on:
September 15, 2018, 05:55:08 AM »
Did you figure it out yet?
Sent from my R1 HD using Tapatalk
Logged
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
madmtnmotors
When did I get to be a
Sunny Central Florida
Reply #2 on:
September 15, 2018, 09:16:44 AM »
It fits over the throttle shaft and is located inside the #2 carb body. It is a sort of thrust washer near as I can tell between the #2 throttle arm and the carb body. You will have to pull the throttle shaft to put this piece back where it belongs, or just leave it out in classic "P.O." fashion:
Logged
TAMTF...
Wilbur
Projects:
"Evolution":
http://forums.sohc4.net/index.php?topic=100352.0
"P.O. Debacle":
http://forums.sohc4.net/index.php/topic,126692.msg1441661.html#msg1441661
F2/F3 O-rings:
http://forums.sohc4.net/index.php?topic=113672.msg1300721#msg1300721
Cam Tower Studs:
https://www.mcmaster.com/#93210a017/=t19sgp
Clean up that nasty harness:
http://forums.sohc4.net/index.php?topic=137351.msg1549191#msg1549191
Charging system diagnosis:
http://forums.sohc4.net/index.php?topic=1012.msg8345#msg8345
Get the manuals:
http://manuals.sohc4.net/cb750k/
The Dragon:
http://forums.sohc4.net/index.php?topic=45183.msg1571675#msg1571675
Headlight Switch:
http://forums.sohc4.net/index.php?topic=113986.msg1283236#msg1283236
Branden's leak free top end thread:
http://forums.sohc4.net/index.php?topic=107040.0
Engine Lifting Made Easy:
http://forums.sohc4.net/index.php/topic,58210.msg1684742.html#msg1684742
Static and Dynamic Timing:
http://www.hondachopper.com/garage/carb_info/timing/timing1.html
Airbox Gasket Replacement:
http://forums.sohc4.net/index.php/topic,114485.msg1290000.html#msg1290000
"Café" :
http://forums.sohc4.net/index.php/topic,84697.msg953814.html#msg953814
PD Carb Choke Linkage:
http://forums.sohc4.net/index.php/topic,100352.msg1669248.html#msg1669248
Follow up on your damn posts:
http://forums.sohc4.net/index.php/topic,144305.msg1791605.html#msg1791605
Taiwanese Cam Chain Tensioners:
http://forums.sohc4.net/index.php/topic,155043.msg1774841.html#msg1774841
Gumtwo Seat Cover:
http://forums.sohc4.net/index.php/topic,164440.msg1897366.html#msg1897366
Primary Drive:
http://forums.sohc4.net/index.php/topic,166063.msg1919278.html#msg1919278
Tank Latch:
http://forums.sohc4.net/index.php/topic,165975.msg1919495.html#msg1919495
Shorten your forks:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-shorten-forks-td4042465.html
DO NOT CUT THE SPRINGS!
Clutch How To:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-change-and-adjust-a-clutch-SOHC-td4040391.html
Late model K7/K8/F2/F3 front sprocket cover removal:
http://forums.sohc4.net/index.php/topic,178428.msg2072279.html#msg2072279
630 to 530 conversion:
http://forums.sohc4.net/index.php/topic,180710.msg2094423.html#msg2094423
Sent from my Tandy TRS-80!
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Carbs
(Moderator:
Gordon
Topic:
