SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Owners Club Forums
USA
Topic:
REALLY dumb question. You guys will probably laugh.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: REALLY dumb question. You guys will probably laugh. (Read 3763 times)
Pielz
Hot Shot
on:
November 04, 2019, 07:05:26 PM »
1977 CB750K. I've been thinking about this for a while and figured I'd finally ask. I got my bike and the rear tank rubber was missing. I used a folded up rag as a cushion for the tank so it didn't rattle while I worked on it/test drove. I finally bought the rear rubber and this might sound really dumb I have NO idea how this is supposed to work. There are little hooks on the frame that slip in to slots on the rubber and the rubber has a slot that slips over the piece of metal that sticks out under the tank but they seem mutually exclusive. Like while one is attached, you cant get the other attached. Am I missing something? Shop manual is of no use. Feel free to laugh haha.
Sent from my LG-G710 using Tapatalk
Logged
seanbarney41
not really that much younger than an
Really Old Timer ...
Re: REALLY dumb question. You guys will probably laugh.
Reply #1 on:
November 04, 2019, 07:12:03 PM »
you need a pic lol...no seriously that thing is kinda confusing. Make sure you dont have it backwards or upside down
Logged
Pielz
Hot Shot
Reply #2 on:
November 04, 2019, 07:18:50 PM »
Whyyyy couldn't they have just used a bolt or two and some rubber bushings? Haha. That's the only thing I dislike about this bike honestly.
Logged
seanbarney41
Reply #3 on:
November 04, 2019, 07:22:12 PM »
you will figure it out...then you will get used to how super nice it is to have the tank come off and stay secure with no tools required
Logged
Pielz
Hot Shot
Reply #4 on:
November 04, 2019, 07:23:54 PM »
I guarantee you're right lol
Logged
madmtnmotors
When did I get to be a
Sunny Central Florida
Reply #5 on:
November 05, 2019, 05:46:45 AM »
Slide the rear tank support onto the frame tabs with the triangular "pull tab" facing to the rear. Set the tank in place with the forward tank supports engaged and the rear resting on the rear tank support. Grab the "pull tab" on the rear support and stretch it over the rear flange on the tank. I usually work one side in and then the other.
EZPZ
Logged
TAMTF...
Wilbur
Projects:
"Evolution":
http://forums.sohc4.net/index.php?topic=100352.0
"P.O. Debacle":
http://forums.sohc4.net/index.php/topic,126692.msg1441661.html#msg1441661
F2/F3 O-rings:
http://forums.sohc4.net/index.php?topic=113672.msg1300721#msg1300721
Cam Tower Studs:
https://www.mcmaster.com/#93210a017/=t19sgp
Clean up that nasty harness:
http://forums.sohc4.net/index.php?topic=137351.msg1549191#msg1549191
Charging system diagnosis:
http://forums.sohc4.net/index.php?topic=1012.msg8345#msg8345
Get the manuals:
http://manuals.sohc4.net/cb750k/
The Dragon:
http://forums.sohc4.net/index.php?topic=45183.msg1571675#msg1571675
Headlight Switch:
http://forums.sohc4.net/index.php?topic=113986.msg1283236#msg1283236
Branden's leak free top end thread:
http://forums.sohc4.net/index.php?topic=107040.0
Engine Lifting Made Easy:
http://forums.sohc4.net/index.php/topic,58210.msg1684742.html#msg1684742
Static and Dynamic Timing:
http://www.hondachopper.com/garage/carb_info/timing/timing1.html
Airbox Gasket Replacement:
http://forums.sohc4.net/index.php/topic,114485.msg1290000.html#msg1290000
"Café" :
http://forums.sohc4.net/index.php/topic,84697.msg953814.html#msg953814
PD Carb Choke Linkage:
http://forums.sohc4.net/index.php/topic,100352.msg1669248.html#msg1669248
Follow up on your damn posts:
http://forums.sohc4.net/index.php/topic,144305.msg1791605.html#msg1791605
Taiwanese Cam Chain Tensioners:
http://forums.sohc4.net/index.php/topic,155043.msg1774841.html#msg1774841
Gumtwo Seat Cover:
http://forums.sohc4.net/index.php/topic,164440.msg1897366.html#msg1897366
Primary Drive:
http://forums.sohc4.net/index.php/topic,166063.msg1919278.html#msg1919278
Tank Latch:
http://forums.sohc4.net/index.php/topic,165975.msg1919495.html#msg1919495
Shorten your forks:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-shorten-forks-td4042465.html
DO NOT CUT THE SPRINGS!
Clutch How To:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-change-and-adjust-a-clutch-SOHC-td4040391.html
Late model K7/K8/F2/F3 front sprocket cover removal:
http://forums.sohc4.net/index.php/topic,178428.msg2072279.html#msg2072279
630 to 530 conversion:
http://forums.sohc4.net/index.php/topic,180710.msg2094423.html#msg2094423
Sent from my Tandy TRS-80!
Pielz
Hot Shot
Reply #6 on:
November 05, 2019, 05:56:45 AM »
Oh my gosh I had that pull tab facing forward so I had no way to pull on it lol. I had it on the tank and then was pushing it back until it slipped on to the frame mounts and it was a huge pain. Hahaha! Thank you for explaining that.
Logged
Stev-o
Ain't no
Central Texas
Reply #7 on:
November 05, 2019, 06:42:01 AM »
I'll admit it, there was a time when I scratched my head trying to install it too!
As you found found out, if it is backwards, it will not work.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Owners Club Forums
USA
Topic:
