Author Topic: 78 K8 sidestand question  (Read 1229 times)
Offline bfitz241
« on: October 18, 2020, 12:39:25 PM »
I finally got my 750 running again after 10 yrs.  I noticed the sidestand is directly rubbing on the #1 pipe and the rubber pad is on #2 pipe.  HM405 pipes.  Are these the correct pipes for this bike? Is it possible to install pipes on the wrong cylinder? Or do you think I have the wrong sidestand
Thanks
1978 CB750K
Hondaman ignition, Ray's regulator rectifier and Dyna 5 ohm coils
Offline 69cb750
Re: 78 K8 sidestand question
« Reply #1 on: October 18, 2020, 01:05:54 PM »
Side stand bumper is on #2 pipe.
Offline bfitz241
« Reply #2 on: October 18, 2020, 01:16:01 PM »
so I am going to guess that sometime ago my sidestand got bent. Going to look for another.  OK thanks
1978 CB750K
« Reply #3 on: October 18, 2020, 01:29:35 PM »
Or straighten it . We don't know what you even have, there are at least 4 kinds.
Offline bfitz241
« Reply #4 on: October 18, 2020, 01:43:50 PM »
Didn't know that.  I'll try to get a clear picture of it
1978 CB750K
Offline Erny
« Reply #5 on: October 18, 2020, 02:41:41 PM »
Thanks
Pipes are correct ones
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline bfitz241
« Reply #6 on: October 19, 2020, 07:26:38 AM »
I'm no expert but that looks bent to me
1978 CB750K
Offline kerryb
  • Not a very
« Reply #7 on: October 19, 2020, 07:33:48 AM »
yup, it's bent.  Got a torch?
« Reply #8 on: October 19, 2020, 08:10:48 AM »
Just hold on, the foot on bottom looks like made for that angle, so straighten may not fix everything. Did the bike have other pipes on it when you got it ? I think it may be worth checking what it should have come with to compare.
Offline bfitz241
« Reply #9 on: October 19, 2020, 10:00:16 AM »
Those pipes and stand were on it.  Don't have a torch big enough to heat this up.  I looked online at the part designated for this model and it looks straight
1978 CB750K
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10 on: October 19, 2020, 10:46:19 AM »
I'm pretty sure it's bent. I've got K8's in the garage that I can confirm later. Could be a sidestand from another make/model that someone repurposed or the stock one may have been modified for a lowered suspension. Got to verify everything else is stock before trying to revert the sidestand back to stock...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #11 on: October 19, 2020, 06:47:09 PM »
This is what one of my K8 sidestands looks like:
Pretty sure yours is bent.
TAMTF...
Wilbur
Projects:
Offline JimsCB750
« Reply #12 on: October 25, 2020, 02:06:02 PM »
Here is a picture of my 1978 CB750K kickstand.
Offline bfitz241
« Reply #13 on: October 26, 2020, 07:18:48 PM »
Just to close this out.   I got another stand and it was straight like everyone else. Put it on and all is good. Doesn't hit the pipe anymore
Thanks everyone for the input
1978 CB750K
