Author Topic: 78 750f headlight problem  (Read 1198 times)
Offline Greaser Greg
  • I'm a liquor in the front and poker in the rear
  • Motorcycles needed = # owned +1
« on: October 21, 2020, 06:20:04 PM »
Anybody ever have their low beam go out, then about 20 short rides later, the high  beam goes from working all the time, to only at idle up to 2000 or so rpm then fades out with a little smoke from the bucket?
Nothin matters, if ya don't mind.
74 CB550
78 CB750F
71 R5
71 R5 in progress
97 XL1200S
08 XL1200N
78 Hobbit
02 4trax 350
? Chinese 49cc mini rat/lightweight
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 78 750f headlight problem
« Reply #1 on: October 21, 2020, 06:28:02 PM »
Sounds like the "seal" portion of the "sealed beam" has failed, possibly a rock chip punched a hole in the lens? Tungsten filaments burn up when exposed to oxygen.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #2 on: October 21, 2020, 06:39:31 PM »
Why would it still work at idle then fade with revs?  I'm gonna look at the switch and in the bucket once I get a minute.
74 CB550
78 CB750F
71 R5
71 R5 in progress
97 XL1200S
08 XL1200N
78 Hobbit
02 4trax 350
« Reply #3 on: October 21, 2020, 06:54:47 PM »
"Smoke from the bucket" could be a failed bulb or a short in the wiring. Remove the headlight and test with jumper wires to a battery to check the bulb. If the bulb works then I'd say you are looking for a short or failed/melted wires and or connections.
TAMTF...
Wilbur
Projects:
« Reply #4 on: October 21, 2020, 07:09:08 PM »
Thanks for the input. I agree. Seems kinda weird with the fade out though.
74 CB550
78 CB750F
71 R5
71 R5 in progress
97 XL1200S
08 XL1200N
78 Hobbit
02 4trax 350
« Reply #5 on: October 22, 2020, 03:55:32 AM »
Seems kinda weird
Yeah, things get weird fast when you let out the "magic smoke"!  ;)
TAMTF...
Wilbur
Projects:
« Reply #6 on: October 22, 2020, 05:04:12 PM »
Yeah, and I can't find any for sale anywhere! Guess I'll have to whip up a batch.
74 CB550
78 CB750F
71 R5
71 R5 in progress
97 XL1200S
08 XL1200N
78 Hobbit
02 4trax 350
Offline 72 yellow
« Reply #7 on: October 22, 2020, 05:19:12 PM »
Found this..Don't know if it comes in negative ground.
Online bryanj
« Reply #8 on: October 22, 2020, 08:42:34 PM »
Ah good old St Joseph Lucas Prince of Darkness and his intermittenr electron.
Costs more in tins you know
« Reply #9 on: October 23, 2020, 08:26:36 PM »
And the winner is; broken 40 year old solder on the ground wire female to the headlight bulb! Must've gotten hot when the low beam went out, as the epoxy is black and powdered near the headlight spade. Also have a few scorch and toasted insulation marks on the back of the headlight where the smoke leaked out of the bare ground wire. :-\
« Last Edit: October 23, 2020, 08:50:46 PM by Greaser Greg »
74 CB550
78 CB750F
71 R5
71 R5 in progress
97 XL1200S
08 XL1200N
78 Hobbit
02 4trax 350
