Author Topic: 1972 CB750 Engine Ticking Sound  (Read 1974 times)
Offline TheWiredNinja
« on: April 26, 2022, 07:58:47 AM »
I took the bike out of hibernation and all was well during my ride until I noticed a ticking / tapping sound that was louder than usual.  Consistent with engine RPM.  Clutch, gears, and speed have no effect on sound.
It seems like its coming primarily on the left to middle side of engine case (cylinders 1-2).  I have checked all valve clearances, timing chain reset (including full dismantling, cleaning, checking spring tension, and lubricating the plunger,), and also a carb sync out of precaution.  Issue remains.  Bike has good power and vibrations are nothing out of the ordinary.  Ticking does get slightly louder at higher RPM and when blipping throttle.
Again, the bike previous to hibernation was working just find without these issues, so my ability to check timing and valves is not the issue.  I would really like to have an idea of what it could be even if I have to pull the motor - this one is a strange issue as performance is top notch and the vibrations aren't something that's very noticeable...
Here are two YouTube video's of the bike:
Re: 1972 CB750 Engine Ticking Sound
« Reply #1 on: April 26, 2022, 08:19:33 AM »
I would have concern if it was my bike making that noise after the checks that you have done.
Time to pull the motor and head cover and check the cam for excessive wear. Good luck.
« Reply #2 on: April 26, 2022, 12:16:41 PM »
try pulling valve inspection cover on exhaust side with engine running, you should have oil splashing out, check both ends of engine.  If there is little oil at either end of the engine, oil is not getting to the cam and the cam is probably shot.
« Reply #3 on: April 26, 2022, 01:49:36 PM »
Top end has oil and both sides are good!  I forgot to mention I pulled the oil pan off to see if there were any interesting bits and pieces in there - it was clean!  Oil looked fairly decent as well (ie. no flakes, or chunks of metal) which means nothing broke internally, or at least it hasn't yet.
If I were to guess it may be a valve rocker that has become loose or perhaps a rod bearing gone bad.  The weather was slightly cooler out... I am just hoping there is perhaps something else I'm missing before it has to be pulled for a complete rebuild :(
Offline desertrefugee
  • Still wanna be a...
  • Phoenix, AZ
« Reply #4 on: April 26, 2022, 03:09:48 PM »
That's definitely concerning.  More so as it appears to be bottom end related - based on its frequency.  If the noise had been focused more on the right side, it could almost sound clutch'ish.  But not in this case.
I also wish you the best of luck.  Always sucks to run into things like this just as riding season is about to start!  That's why one MUST have more than a single viable fun machine!
« Reply #5 on: April 26, 2022, 03:27:22 PM »
That is disconcerting for sure. Well done on your checks.
When was the oil changed last? Just before hibernation or???
What are the temps outside and in your shop when it's happening?
Are all cylinders firing at equal temps on exhaust pipes when started?
« Reply #6 on: April 26, 2022, 04:20:38 PM »
so...how does clean oil in the pan tell you that it has been anywhere near the camshaft?  I have heard that engine sound twice.  Both times resulted in complete destruction of the camshaft and most if not all of it's associated parts in less than 40 miles.  You can hope I am wrong or checking for oil in the top end takes all of 2 minutes.
« Reply #7 on: April 27, 2022, 07:31:20 AM »
This is what happened to my K4 engine the last time I heard a bad noise, it happened so quickly....
  • Phoenix, AZ
« Reply #8 on: April 27, 2022, 10:19:25 AM »
The original Big Bang Honda!
Offline JLeather
« Reply #9 on: April 28, 2022, 12:14:34 PM »
This is what I found in my K1 engine that was making a similar noise.  At least it got me 200 miles back home :)
« Reply #10 on: April 28, 2022, 01:45:12 PM »
JL, look carefully  for all 4 little o-rings that are supposed to go under the cam tower, 2 on the inside around the oil jets, 2 on the outside to seal the ends of the oil passages.  That is about what I have seen if any of these o rings are missing or damaged...the cam will last longer than with a plugged oil jet, but not much.
« Reply #11 on: April 29, 2022, 11:31:21 AM »
Did you find a cause for that?
« Reply #12 on: April 29, 2022, 12:04:35 PM »
It’ll find its way out, if left unattended…👀
Online bryanj
« Reply #13 on: April 29, 2022, 12:07:48 PM »
That would have been caused by a partialy blocked jet so enough oil to stop a sieze but not enough to carry heat away or keep a proper oil film
« Reply #14 on: April 29, 2022, 06:07:37 PM »
I have also heard that noise after a long-ish winter sojourn when the intake valves got a bit of rust on 2 of them (on several bikes) because they sat open in humid climes. This made them rust slightly, and the rust increased the rocker tappet clearances on the 2 valves. The first time, I adjusted the clearance back to the tighter spec (they were more than 0.004" in that case) only to find, 100 miles later, that they were tight and had to be loosened back up. On subsequent bikes that did this, I left the valves alone and after some miles the valves wore the rust away and returned to their normal clearances. Since then I just leave them alone, in similar situations.
That doesn't absolve the above-mentioned problems if the rockers have suddenly developed a LOT of clearance (like 0.005"+) for no apparent reason, when they were previously correctly set at 0.002": that can indicate lack of oil that is wearing out the cam and rocker.
« Reply #15 on: April 29, 2022, 09:00:10 PM »
A bad rod bearing makes more of a knock than a tick. Recheck the valve clearances, doing one cylinder at a time. Also, an exhaust leak at the cylinder head can make a ticking noise; does it sound louder at the front of the engine?
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #16 on: April 30, 2022, 11:31:19 AM »
Try the old school method of using a wood dowel up to your ear and probing spots on the motor to locate where the sound is emanating from.
« Reply #17 on: June 25, 2023, 11:17:30 AM »
So it has been awhile since I've posted here and worked on the bike, but as you all know, life happens!  Anyway, I'm determined to get my back on the road and I have in hand some real nice goodies for this rebuild.  In the meantime I've posted pictures of the engine being dismantled and I'm curious if you guys think... I'm trying to yet pinpoint the cause of the ticking sound, despite the problematic area's that I have noticed.
Background:  This bike (1972) has been sitting for around 30 years (based on the last plate renewal) and although I got the bike (surprisingly) started and working perfectly for a good season (good compression and ran great!), unsurprisingly the bike developed issues and the oil burning issues began, specifically in cylinder 4.  This then developed to harder starts, more oil burning, rising engine rpm on its own at idle when the engine warmed up, and finally the distinct "ticking" sound.
I initially thought that something must have clogged the head oil jets causing a lack of lubrication which started to slowly destroy the cam/rockers/valves.  However, after opening her up, everything looked quite good with no obvious signs of problems - in fact, I'd be comfortable reusing everything.  I took off the head and things started to paint a picture what was going on...
Cylinder 4 was covered in oil and as a result, of burning the oil, it was cleaner on the face than the others
Closeup of Cylinders 4 and 3
Closeup of Cylinders 2 and 1
This is the condition of the underside of the head, clear showing alot of carbon buildup, especially #4 (left)
Here are the bores 4 and 3
Bores 2 and 1
Although the bores showed signs of corrosion, they were quite smooth!  I could not feel much roughness or anything too noticeable aside from the slight bore scoring near the bottoms.  This can also be seen on the pistons themselves here:
Pistons 4 and 3
Pistons 2 and 1
This is when I noticed the oil rings on piston 4 were stuck.  All the others pistons and rings were free to move and looked good.  This was clearly the major cause of the oil leak on that piston
So with all that said, I'm curious if that ticking sound could be due to that #4 piston?  I should also mention that I had initial trouble with a stuck valve on #3 that I managed to free up and then seemed to ran fine.  Obviously several things could account for the lean condition at idle including the poor sealing valves etc.  But the ticking on the other hand... I would really like to avoid opening up the cases if I can.  Is there a way to confirm all is well with the crank and bearings without having to do this?  Or is the ticking identifiable here?
« Last Edit: June 25, 2023, 02:10:06 PM by TheWiredNinja »
Online bryanj
« Reply #18 on: June 25, 2023, 11:49:30 AM »
That needs a rebore and oversize piston kits PLUS i would check valve stem to guide clearance, the F2 was notorious for exh valve guide wear but other models can do that
« Reply #19 on: June 25, 2023, 02:03:41 PM »
Oh definitely, the bike is a K2 btw.  I thought ahead and got some nice parts from M.R. - little preview of what is to come is attached.  Any idea on where the ticking issue could be?  Could it just be the worn valvetrain? The stuck oil ring on #4? Again, no indication of major wear on the camshaft, rockers or towers (and related parts) as far as I can tell - granted, I'm not positive if it's the valves themselves as being the source despite them being very crusty looking...
I'm hoping this new head and an 836 JE piston kit with new bored cylinders from CycleX will do the trick.  My major fear is that it's the rods making the noise or something of that sort.
« Last Edit: June 25, 2023, 03:43:55 PM by TheWiredNinja »
« Reply #20 on: June 25, 2023, 02:53:26 PM »
It's come to my attention the pictures above may look too large for some (you can scroll right using the arrow keys to view the full picture) so I've posted them again on here as attachments.
« Last Edit: June 25, 2023, 02:55:04 PM by TheWiredNinja »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #21 on: June 25, 2023, 03:43:44 PM »
I just recently had a ticking noise in the racebike. If I covered each V-stack one by one I was able to determine the noise was in the #1 assembly. I only heard the noise at idle and it would go away as soon as the rpms started to climb. The V-stacks seem to amplify valve train noises and I was able to narrow it down to excessively worn exhaust valve guide. My troubleshooting consisted of pulling the head, checking valve "wiggle", and replacing the head with a used head that had tighter valve guides.
No more ticking.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #22 on: June 25, 2023, 03:47:31 PM »
No more ticking.
Thanks for that.  I am now also leaning to the valve guides as being the issue.  They were rusty to begin with and with one valve actually being stuck, I knew I was on borrowed time.  Looks like the build will continue without having to crack open the cases
Offline rotortiller
« Reply #23 on: June 25, 2023, 04:04:48 PM »
If it were me I'd clean the piston with solvent and carefully scotch-brite clean then hone the rusty cylinder, just enough to remove the rust, then measure, also evaluate pitting. Then I would look for any radial play on the rods, I would suggest check-torque of the rod bolts and main bearings. Sometimes things look worse than they are in pictures. I can see lathe marks still on the pistons under the crud I believe. The cylinder ridge where the rings stop sweeping can offer indications of use. Shop manual has suggested piston to cylinder clearance limitations. While it looks bad, is it really pooched beyond limits?
Offline ofreen
« Reply #24 on: June 25, 2023, 04:18:08 PM »
Can't say for sure if it was the issue of course, but an exhaust leak between head and header can sound all the world like a ticking from the engine.  I've seen it happen enough that it is the first thing I look at.  Usually tightening the nuts/bolts cures it.  If not, new exhaust gaskets are needed.  They will only compress so much.
Greg
'75 CB750F
