Author Topic: Custom Seat - Epoxy Glue, Rivet or...  (Read 1234 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: May 07, 2022, 04:26:18 PM »
About halfway through fabricating my custom seat for my '77 K7 and thought I'd hop on here and get some personal and/or professional opinions on how I should go about attaching the leather to the underside of the seat pan: Epoxy glue, rivet, another method I can't think of?
What're your thoughts?
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Re: Custom Seat - Epoxy Glue, Rivet or...
« Reply #1 on: May 07, 2022, 04:34:51 PM »
 I see a few of them with short rivets, A combo of contact adhesive and rivets would probably work.
Offline Ellz10
  • ZZ
« Reply #2 on: May 08, 2022, 09:31:02 AM »
I was thinking of doing both as well. Couldn't hurt anything, only help I would imagine.
Offline tourmax
« Reply #3 on: May 08, 2022, 10:33:54 AM »
What i used to do with steel pans was knock a little "triangle" out with the point facing inward. Then I could pull the material over it, through it and then hammer the triangle "point" back down and the cover is pinned in place.
Have to be careful with your material though, if it rips or tears easily, pushing it over the sharp point can cause it to get a running tear that will ruin your material.
1989 FJ1200, 1983 Yamaha Venture (Vmax conversion), 1985 VF 750F Interceptor, 1982 CB650SC, 1988 Corvette convertible (Z52), 1983 Mustang GT, 2009 Mini Cooper Clubman.Couple more lying around but this is long enough already!
Offline Shopdog
« Reply #4 on: May 08, 2022, 04:57:48 PM »
I bought a set of upholstery tack strips and jb welded them around the bottom inner lip. I tried just tacking them with mig, but they're either some type of alloy or coated with something. Anyway, I stripped the underside down to bare metal and the bond is great. Everything got a coat of black paint before the vinyl was put on.
Offline carnivorous chicken
« Reply #5 on: May 08, 2022, 08:13:10 PM »
I've used epoxy and the litte triangles that are at the front of stock seat pans. One thing that helps is a dozen or so binder clips to hold it into place, although you want to make sure that there's no epoxy under the cover on the outside of the pan otherwise you'll get an indentation from the clip.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: May 09, 2022, 04:59:27 AM »
I have used these with excellent results. I placed them around the inside of the seat pan and riveted them in place from the outside (so the extended part of the rivet is to the inside):
New gator teeth upholstery strips riveted to the seat pan to hold the new seat cover:
New skin stretched into place:
All that work just for this:
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Ellz10
  • ZZ
« Reply #7 on: May 09, 2022, 12:29:04 PM »
I'm going to have to give these a try! Not sure if I'll like it or if it'll work for the pan I'm using but we'll see and it's good to know in the future for other projects!
