Author Topic: Carbs  (Read 1168 times)
Offline commander60
Carbs
« on: July 16, 2022, 04:42:53 PM »
What would be the best carb setup say new replacement , what about a dual setup. Recommendations please. Would like to use stock airbox
Stock CB750K7 Kerker exhaust Not looking for more power, just smooth running, good gas milage .
Re: Carbs
« Reply #1 on: July 16, 2022, 05:10:36 PM »
Why do you think the hundreds of man hours Honda spent on the stock carbs is inadequate?
Online newday777
Re: Carbs
« Reply #2 on: July 16, 2022, 07:10:28 PM »
Then it's stock carbs to go with the stock airbox.
My K6 back in the day had the stock carbs and airbox(opened up a little bit for more flow intake which worked great with the Kerker, 811, big cam, 3 angle valve cuts
Offline Airborne 82nd
Re: Carbs
« Reply #3 on: July 16, 2022, 08:46:40 PM »
What sort of trouble do you have with the stock ones? When clean and set up right they are great carbs. they came a little lean but that is a easy fix.
Re: Carbs
« Reply #4 on: July 16, 2022, 11:17:22 PM »
The stock K7-K8/F2 & F3 carbs have that 'touchy',easy to clog accelerator pump system,which is great and they run excellent when those tiny passages/brass jets are clear.. owners leave their bikes sit and..  ::) :D
I think the first step to do is get the tank completely,100% rust and dirt free  ;)
I paid a place to do surgery on a Honda fuel tank and they're called gas tank renu(gastankrenu.com)and now the tank is guaranteed to never rust again:for the life of the bike.I won't have anymore little particles gravity-feeding down into my carbs.
« Last Edit: July 16, 2022, 11:25:53 PM by grcamna2 »
Re: Carbs
« Reply #5 on: July 17, 2022, 03:34:16 PM »
Never have any trouble with my 78 750K. I do keep a clean filter in my tank. I also keep a old stocking under the fuel door for when I fill it. I did have to clean the entire system when I got it after it sat for four years. I think most people just don't take the time to learn how to clean and set them up the first time then want to blame it on the carbs. A few years back they did give me a fit learning how set everything up took about three tries but all the help I needed was right here Thanks to TwoTired and others Damn that's been 8 years of fun
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Carbs
« Reply #6 on: July 17, 2022, 04:29:59 PM »
The stock K8 carbs work pretty well for me:
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Carbs
« Reply #7 on: July 18, 2022, 09:33:03 PM »
Most people know about 1/16th about there carbs and engine than you do 8)
 Last time I saw you was at a rest area on I40 in NC passing off Godzilla
Re: Carbs
« Reply #8 on: July 19, 2022, 04:03:59 AM »
I remember that. Hope you are doing well. I did about 3,000 miles that trip!  8)
TAMTF...
Wilbur
Projects:
