Author Topic: '78 CB750 PD carbs, "clear tube test" before installing question  (Read 945 times)
Offline denward17
« on: February 23, 2023, 12:08:52 PM »
If I wanted to pre-check bowl level before installing carbs, I connect a clear tube to each bowl drain and just loosen the drain screw?
Offline newday777
Re: '78 CB750 PD carbs, "clear tube test" before installing question
« Reply #1 on: February 23, 2023, 02:05:49 PM »
Nope.
You need to have bowl drain plugs with a bung on each.
Stu
My current rides
Prior bikes....
Offline newday777
Stu
My current rides
Prior bikes....
Offline Geoff Hastings
« Reply #3 on: February 23, 2023, 03:18:37 PM »
I did exactly that, just connected clear tubes to the carb drains, turned the tubes up right and then opened the drain screws. Clearly showed the difference in fuel level. The bike idles so much better.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: February 23, 2023, 04:55:34 PM »
That’s not correct. The float bowls overflow is the tube in the middle. It is too high in the floatbowl.
Offline denward17
« Reply #5 on: February 23, 2023, 05:48:39 PM »
^But on this carb type, doesn't the drain let fuel out of the bottom of the bowl when the drain screw is loosened?
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: February 23, 2023, 06:01:47 PM »
You are absolutely correct! I’m confused again!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: February 23, 2023, 07:58:34 PM »
Yep. The PD "abominations" (I haven't had any issues with them) do indeed drain out the bottom and the clear tube can be connected there, then loosen the drain screw.
EZPZ
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #8 on: February 24, 2023, 08:35:10 AM »
 I'm also a fan of the bench test. I suspend the carbs over a paint roller pan and give them a day to soak.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: February 24, 2023, 01:35:11 PM »
Clear tube is great, it gave me more confidence that I had them right.
1973 CB 750 K3
10/72 build Z1 Kawasaki
