Author Topic: What did you do to your bike today ?  (Read 3653983 times)
0 Members and 9 Guests are viewing this topic.
Offline goldarrow
  • one day, i'll be an
« Reply #17075 on: April 04, 2014, 02:41:57 PM »
Dang. Now I just need to figure out what fork oil I was t.
ATF
CB550 K0
Offline mcswny
« Reply #17076 on: April 04, 2014, 02:45:07 PM »
Going to my garage tonight to prep my bike for a small camping trip upstate ny this weekend.
Also, bought myself some new, stock length fork tubes. I was sick of my 4" extended tubes and crappy handling. That combined with my tapered race bearings, my handling is going to be spot on (swing arm bushings next)!
With that much length, you can install clipon bars on top of triple tree, and still have space to add fork brace up top of forks :)
hahahah NOOOOOOOO thank you.
the 4 inch extended tubes were on the bike when i got it. Never bothered me until I road my friends bone stock 750, road it for 10 miles or so and the second I got back the garage I was googling where to buy new stock tubes!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline WhyNot2
  • I'm finally an
« Reply #17077 on: April 04, 2014, 03:32:28 PM »
2 days in a row of riding the CB750 to work.........................
Will probly ride it again tomorrow..........................................
Life is good............................................................................
« Reply #17078 on: April 04, 2014, 04:36:01 PM »
.020" brass shims
« Reply #17079 on: April 04, 2014, 04:45:58 PM »
how did you cut those so clean, Flybox?
Nic
« Reply #17080 on: April 04, 2014, 04:48:55 PM »
+1
« Reply #17081 on: April 04, 2014, 05:22:43 PM »
« Reply #17082 on: April 04, 2014, 05:39:50 PM »
Had to make a template, first.
The puck recess ID is ~1.01"  A Liberty $ coin OD is ~1.04"
Pin scored and cut w heavy scissors. Dremel down to fit.
Used the first to make the rest.  Cleaned up w emory paper and then 1000 wet.
« Last Edit: April 04, 2014, 05:42:43 PM by flybox1 »
« Reply #17083 on: April 04, 2014, 05:41:08 PM »
George would be proud
Nic
« Reply #17084 on: April 04, 2014, 05:57:24 PM »
Ah, hand finished, a man after my own heart :)
Offline Jerilee
« Reply #17085 on: April 04, 2014, 06:04:47 PM »
I'd love to know your packing list for a trip on the CB. I want to have a trip myself as soon as my bike's finished.
Do you still happen to remember where you got your new stock-like handlebars from? I need a new set for mine too.
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline Dimitri13
  • 1974 CB550K
« Reply #17086 on: April 04, 2014, 07:39:35 PM »
Got my forks together. Putting the caps on was a bear. Dropped the left one twice :'( I'll eventually replace them with a billet piece or maybe a recessed piece.
Unintentional colors.
Offline fire113
« Reply #17087 on: April 05, 2014, 03:48:18 AM »
...K0 parts arrived and I did some special tools.
Offline fire113
« Reply #17088 on: April 05, 2014, 06:09:08 AM »
...bend the Honda tank emblems and put a K0 gas cap
Offline fire113
« Reply #17089 on: April 05, 2014, 08:11:31 AM »
...finished the K1 gauge.
« Last Edit: April 05, 2014, 08:13:26 AM by fire113 »
Offline Schnell
« Reply #17090 on: April 05, 2014, 09:42:47 AM »
I moved the CB to the front of the garage and moved the snowblower to the back. It's still only 3C this afternoon. I need >10C to ride.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline MoMo
  • Ride like you're invisible
« Reply #17091 on: April 05, 2014, 10:54:12 AM »
Pulled my nohc 2-smoke Suzuki S-32 out of the shed, turned the reserve on, key on, choke on,  one kick and wing, ding, ding.  Nothing like the smell of Blendzall in the morning ;).   Little maintenance and off to ride  ;D ...Larry
Offline fire113
« Reply #17092 on: April 05, 2014, 03:45:11 PM »
...did the next K1 gauge but this time I used repainted covers and the original Honda closing ring, left gauge at the picture. After it I mounted the closing mechanism at the K0 gas tank.
Time for a drink...Georg
« Reply #17093 on: April 05, 2014, 04:04:11 PM »
Nice Work
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #17094 on: April 05, 2014, 04:08:22 PM »
Lowering blocks...did install them backwards?
Getting ready tonight to see if she will start. New gas and plugs, if she runs I will ride this week. Upper 50s, 60s? Then when its cold the following week, oil change, valve adjustment and enjoy another SOHC sunny summer.
Sent from my PC36100 using Tapatalk 2
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
« Reply #17095 on: April 05, 2014, 04:15:55 PM »
I think they are oriented properly. It appears they are missing the loonger holddown bolt that does dbl duty holding the tail of the block down and fixing the chainadjuster blocks in place.
It appears to me to be an unsafe condition.
« Reply #17096 on: April 05, 2014, 04:18:30 PM »
Are they on a 500/550? They should be layinig right on top of the swingarm with no daylight showing.
Appears it may be a 750 part on a 500/550.
Offline Tintop
« Reply #17097 on: April 05, 2014, 04:33:43 PM »
maybe they are upside down??
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline fire113
« Reply #17098 on: April 05, 2014, 04:40:54 PM »
...I just kicked em out, here is a picture before and after.
« Reply #17099 on: April 05, 2014, 04:45:29 PM »
Those blocks would be best on a 750. As MC noted those holes in the back has a bolt that goes through and attaches to this on a 750 swingarm, an axle stop.
