Author Topic: What did you do to your bike today ?  (Read 3911351 times)
0 Members and 12 Guests are viewing this topic.
Offline maduncle
  • Don't confuse me with a
« Reply #23375 on: January 24, 2017, 01:21:24 PM »
Ha ha, Cliff's bike is slowly evolving into a stocker! When are you gonna paint it candy ruby red and strap on some HM341's mate? ;D
Soon ...
And I prefer Bacchus Olive Green, even if it wasn't a CB750 colour.
CB750K2 (only slightly modified)
Offline Gene
  • Chat enuf you too can be a
« Reply #23376 on: January 24, 2017, 04:00:32 PM »
Crank up the traditional irish punk music and rock my little corner of the garage.
The new Dropkick CD is pretty good
My loyalties still lie to the Pogues. If you want to check out someone "new" (been around a while, but not well known) Look up the Tossers out of Chicago.
*1973 CB750K3 (Bow)
Offline USMC5811
« Reply #23377 on: January 24, 2017, 04:32:35 PM »
Love The Pogues too
« Reply #23378 on: January 24, 2017, 04:50:33 PM »
Got the "Park Racer" back on the road!  It had been setting for 2 years since I owned it and many more before then. After a 10 month restoration, it is finally done.
Before........
After...
Offline MoMo
  • Ride like you're invisible
« Reply #23379 on: January 24, 2017, 05:07:15 PM »
nice work Steve 8)...Larry
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #23380 on: January 24, 2017, 05:15:43 PM »
Put 150 miles on her today.
« Reply #23381 on: January 24, 2017, 05:33:42 PM »
 Did not know you were working on the Park Racer Steve. Got a thread on that in the project section ?, be curious what all you did to her.
« Reply #23382 on: January 24, 2017, 05:48:17 PM »
Sure do, Eric. I didn't document every little detail, but nearly every part got powdered, painted, polished or replaced.  Motor only needed a valve job....
http://forums.sohc4.net/index.php/topic,156311.0.html
« Reply #23383 on: January 24, 2017, 05:57:08 PM »
  Cool -  I will give it a read Steve. I was wondering what might be in the engine etc so will make an interesting thread to look at.  Congrats for saving it and getting it back on the road !
« Reply #23384 on: January 24, 2017, 06:09:48 PM »
Although I was tempted to build a high performance engine, once it as determined that the pistons/bores were good, I decided a reliable runner would be just fine.
When I want a high speed thrill ride, I just jump on the Z1!
Offline lawlshane
    • Twitter
« Reply #23385 on: January 25, 2017, 01:43:30 PM »
Didn't do anything to the bike...but bought it a nice gift. Mother Nature needs to hurry up and get warmer :'(
Offline USMC5811
« Reply #23386 on: January 25, 2017, 04:01:20 PM »
Continued the winterizing process by cycling fresh gas through the carbs and warming up the tires.
Offline maduncle
« Reply #23387 on: January 26, 2017, 12:03:13 AM »
Removed the DCC billet top triple and clip on's and fitted a CB450 top triple and drag bars.
Made all the more fun by the fact I had been a good boy and previously routed the switch block wiring through the clip on bars to hide it all - never again!
Of course, muggins here puts it all back together and tries to start the bike - no start.
Ah yes, CB450 triples have rubber isolated bar risers and you do need to fit that little earth wire with a washer on each end from one of the riser posts to a gauge mount. All good now, took it for a ride through the local twisties and realised how much better I am on nice wide drag bars as opposed to clip on's.
Meanwhile the RFID chip under the skin of my left hand is turning the ignition on and off with ease.
« Last Edit: January 26, 2017, 12:06:16 AM by maduncle »
Offline Asbjoorn
« Reply #23388 on: January 26, 2017, 12:35:26 AM »
Creating a rain cover for my pod filters!
« Reply #23389 on: January 26, 2017, 05:33:41 AM »
kleaned up the calipers NeXT is sealing and dust seals..and the new made pistons
« Last Edit: January 26, 2017, 05:36:11 AM by strynboen »
Offline Tintop
« Reply #23390 on: January 26, 2017, 07:25:47 AM »
It you feel the flat bars are an improvement in saving your back, you'll like Super Bike bars even more.  I did. ;) :)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #23391 on: January 26, 2017, 07:30:02 AM »
Nice!
Offline Radam
  • taco racer
« Reply #23392 on: January 26, 2017, 09:02:41 AM »
+1
I did a 600 mile ride with drag bars once. Bought super bike bars afterwards and never looked back.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #23393 on: January 26, 2017, 10:36:35 AM »
Finished my seat re-cover!
It is slightly off-center at the front, I know... It was straight when I started clamping. Oh well! Still pretty good, I'd say. I'm still really happy with it! I used the original chrome trim, I just used a razor-blade to remove it from the cover. The lumpyness on the rear end is from the plastic sheet I put under it, since the pattern is stitched, not pressed.
--Evan
1975 CB750K "Rhonda"
Offline Gene
« Reply #23394 on: January 26, 2017, 12:23:26 PM »
Seat looks great. Love Gumtwo's covers - and you did a fine job.
*1973 CB750K3 (Bow)
« Reply #23395 on: January 26, 2017, 01:23:46 PM »
+1 well done!   A nice seat is a must in my book...
« Reply #23396 on: January 26, 2017, 02:45:54 PM »
Did you do a tack strip in the seat pan to hold it on or do I remember seeing a picture where you stole all of your wives clothes pins and glued it on ? Any link to that seat cover, I should be redoing some this winter also.
« Reply #23397 on: January 26, 2017, 03:02:01 PM »
Here's the Gumtwo cover on my 74'550K.  Chrome trim and strap hardware is NOT included, but a new strap is.
Chrome trim came off the bike with a little effort, and I reused it.
Strap hardware- I assumed it was NLA.   Reuse what you have.
I had a sheet of .5mm rubber, and cut a pad for under the sewn in seat top
Use plenty of upholsterers cement, and let it cure well before taking clamps off.  If you use a chrome trim ring, this will also help keep the cover in place if a tooth is broken/missing.
http://stores.ebay.com/gumtwo32
« Reply #23398 on: January 26, 2017, 03:32:28 PM »
I use the existing "shark teeth", even was the one who stole all of his wives clothes pins!  [Does anyone actually use them for hanging clothes any more??]
« Reply #23399 on: January 26, 2017, 03:56:10 PM »
+1
Yep, I was never a fan of drag bars, probably an improvement over clip ons, but not a patch on superbike bars. It's nice to be able to look in front of you without your neck being at 90 degrees to your spine........... ;D
