Author Topic: 1975 Supersport, performance cafe  (Read 156072 times)
Offline Doctor_D
Re: 1975 Supersport, performance cafe
« Reply #400 on: June 19, 2013, 08:07:21 AM »
Doc,
I'm doing a GL1000 fork swap too.  Can you share where you got the phenolic pistons and EBC discs and details on the parts?
Here's what I've gotten so far:
Part        Supplier
Replacement Fork Seals        Z1
Fluid   US3 (15wt)        Racetech
Cartridge emulators & adapter FEGV S3301 & FPEV AD3303 P                        Racetech
Fork tubes   -2"        Franks Maintenance and Engineering
Springs   FRSP S2643095        Racetech
Fork Brace (Superbrace)        Randakks
Gators        EBay
Tapered steering bearings  All Balls        EBay
Caliper rebuild   hardware        Bike Bandit
Brake master cylinder  5/8"        Randakks
Brake lines and "T"        Spiegler
Rotors EBC MD1074LS & MD1074RS        Bike Bandit
Brake pads  EBC Semi-sintered        Bike Bandit
Phenolic caliper pistons        Godffrey's Garage (member here)
Top triple tree (CNC)        Dime City Cycles
I still need headlight mounts (ears), front fender, and clip-ons.
« Last Edit: June 19, 2013, 02:22:37 PM by Doctor_D »
Take care,
David
1978 CX500
1971 Norton Commando
Offline Godffery
  • Godffery's Garage
Offline Doctor_D
« Reply #402 on: June 19, 2013, 02:25:52 PM »
Here you go:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/album185/
Sorry about getting your name wrong... corrected it in the above post.  Thanks for posting the link for others.
Take care,
David
1978 CX500
« Reply #403 on: June 19, 2013, 06:31:24 PM »
Offline Godffery
  • Godffery's Garage
« Reply #404 on: June 19, 2013, 09:08:49 PM »
   There going out first thing in the AM:
Your gun'a freak when you feel how light they are!  8 ]
« Reply #405 on: June 25, 2013, 06:28:48 PM »
Holy crap. They are light!  Thanks Godffrey!
Offline Godffery
  • Godffery's Garage
« Reply #406 on: June 25, 2013, 09:37:43 PM »
You bet man!
Offline Doctor_D
« Reply #407 on: July 21, 2013, 09:24:21 AM »
GL1000 forks are nearly done.
Need to order my Woodcraft clip-ons and figure out my headlight ear situation.  Also need to fab a new bracket for my speedo, and mount up my steering damper, but we're getting there.
Take care,
David
1978 CX500
« Reply #408 on: July 21, 2013, 11:01:39 AM »
Doc,
Looking bright and shiny. I'm PC'ing my fork lowers.  I like how the DCC tree looks.  Did you stay stock on the fork tube length or shorten them?
Don
« Reply #409 on: July 21, 2013, 02:01:13 PM »
He is -2..hope its long enough.
Offline Doctor_D
« Reply #410 on: July 21, 2013, 02:38:16 PM »
To do it over, I might go -1.5".  There's 4" below the bottom triple though and almost that much travel.
« Last Edit: July 22, 2013, 09:57:46 PM by Doctor_D »
Take care,
David
1978 CX500
« Reply #411 on: July 22, 2013, 05:38:55 PM »
To do it over, I might go -1.5".  There's 4" below the top triple though and almost that much travel.
I'm between 1.5" and 1.125".
Offline Doctor_D
« Reply #412 on: July 22, 2013, 09:59:03 PM »
Sounds about right.
Take care,
David
1978 CX500
« Reply #413 on: August 01, 2013, 10:35:35 PM »
Hey Dave,
I'm jonesin' to see how the new front end is coming together on the bike.  I am working on getting my GL1000 front together, too, for my Nine Lives project.
I just spoke with Mike Rieck today, and my stage 4 is coming along for my new project.  I think I am going to run Mikunis on that one.  The top end engine specs are modeled on yours.
Offline Doctor_D
« Reply #414 on: August 02, 2013, 10:11:17 AM »
Waiting on a couple of small things, like the 37mm fork-leg, steering-damper clamp, and STILL trying to decide on headlight brackets.
There are some really nice ones out there in 38mm that I can shim, but I'm not sure how they'll look on the bike. Like these: http://store.revivalcycles.com/products/lsl-headlight-brackets  http://www.spi-parts.com/machined-headlight-bracket-long-type-38mm-silver.html
For now, I might just settle on the Tomaselli ones: https://store.bevelheaven.com/body-dress-up-etc/tommaselli-headlight-brackets-38mm/
All in all, should have everything installed and fine tuned in about two weeks.
Take care,
David
1978 CX500
« Reply #415 on: August 02, 2013, 02:57:08 PM »
Get the first ones,shim the clamps ....020 shimstock or cereal box cardboard, then later we can make better looking one piece clamps for 37 mm.
« Reply #416 on: August 02, 2013, 11:19:50 PM »
Dave,
I ended up going with these from MotoLanna:
http://www.motolanna.com/ourshop/prod_2062517-Headlight-Brackets-37mm-Die-Cast-Alloy.html
Aztec8 has some nice ones too:
http://www.aztec8.com/catalog/i39.html
« Reply #417 on: August 04, 2013, 01:48:01 PM »
Those Motolanna ones are nice and the price is OK
« Reply #418 on: August 22, 2013, 03:45:29 PM »
Dave,
How's the front end swap coming along?  Any new pictures to share?
Offline Doctor_D
« Reply #419 on: August 22, 2013, 03:54:46 PM »
It went pretty easily and is mostly done.
I have to pull pics off the camera and resize them for the web, but I should be able to share them this weekend.
Take care,
David
1978 CX500
« Reply #420 on: August 23, 2013, 09:16:10 PM »
The last time I heard a CR750 run was Yoshi Kosaka's bike (www.garagecompany.com) at Corsa Moto Classica.  LOUD AND MEAN!!!  I bet yours sounds equally menacing.
For comparison, I came across this video of Honda's unbelievably bad-ass RC166 6-cylinder (which Mike "The Bike" Hailwood rode to 10 out of 10 wins to completely dominate the 1966 World Championship.  Enjoy.
http://youtu.be/eaRop_ZMwo0
Offline Doctor_D
« Reply #421 on: September 02, 2013, 05:04:48 PM »
OK, GL1000 forks on the bike.  Waiting on my fork brace and steering damper mount.  Need to fab a new bracket for the Vapor speedo, and bracket for the front fender, mount a cable guide for the brake lines, and make a slightly longer axle spacer - but it's all there.
(Yes, I know the Woodcraft clipons are reversed. I never could get those things right the first time...)
Take care,
David
1978 CX500
« Reply #422 on: September 02, 2013, 05:47:15 PM »
Nice graphics on the lift Dave. ;D
Offline Doctor_D
« Reply #423 on: September 02, 2013, 05:50:36 PM »
Not my lift.  I should have cropped the photo.   Isn't so obvious when you're standing there.
Take care,
David
1978 CX500
« Reply #424 on: September 02, 2013, 06:06:36 PM »
I think you'll be happy with your set up Dave, looks good.
