Author Topic: New project for a first timer CB550 build - Slowly getting back to it!  (Read 167578 times)
Re: New project for a first timer CB550 build - BMW Forks Ahoy
« Reply #450 on: March 15, 2018, 11:41:02 AM »
Indeed, the Sachs S1000RR front forks are a common upgrade for the RNineT -- for those who don't want to spring for the Ohlins replacements!
Offline bambuhiphop
« Reply #451 on: March 15, 2018, 12:42:19 PM »
Glad you didn't pilfer them from the R in the background  :o
Ha, no. Only problem with that bike is it isn't ridden enough!
Offline bambuhiphop
« Reply #452 on: March 15, 2018, 12:44:46 PM »
Ya, I looked at those for a hot minute until I saw the $2,500 price tag! Don't get me wrong, I've spent some quality money on this bike but that was just a little to much right now. Found these for a much more respectable number.
« Reply #453 on: March 15, 2018, 04:05:18 PM »
The Sach adjustable forks are quality units.  If you try them out and feel like you need "something more," you can always opt for the Ohlins cartridge kits, which will essentially convert the internals of the forks to the Ohlins units.
Offline Scramps
  • Luke Warm, maybe. Not quite a
« Reply #454 on: March 15, 2018, 08:16:11 PM »
I thought I was pretty meticulous with my first-timer engine refurbishing job, but WHOA.
I love the color scheme you've got going here, too, especially the color on the tank.
All in all, very nice work
Offline bambuhiphop
« Reply #455 on: March 15, 2018, 09:15:56 PM »
Very kind. Thanks!
Offline Restoration Fan
  • My wife will never call me
« Reply #456 on: March 20, 2018, 02:13:50 PM »
Just finished going through the entire thread.  Outstanding work on this bike.  Definite BOTM material when you get this beauty finished.
« Last Edit: March 21, 2018, 06:22:29 AM by Restoration Fan »
Offline bambuhiphop
« Reply #457 on: March 20, 2018, 02:24:00 PM »
Just finished going through the entire thread.  Outstanding work on this book.  Definite BOTM material when you get this beauty finished.
Thank you kindly. It's been a long process with a bit left to go but it has been an awesome learning experience.
Offline Godffery
  • Godffery's Garage
« Reply #458 on: March 20, 2018, 02:50:28 PM »
I'd say BOTY me thinks!    ;)
« Reply #459 on: March 20, 2018, 04:42:49 PM »
Yeah, this bike is pretty damn outstanding.  I'm looking forward to seeing it completed along with a ride report.
Offline bambuhiphop
« Reply #460 on: March 20, 2018, 10:25:53 PM »
Geez guys. You sure do know how to make a girl blush.
Few little updates. Getting the front back together and getting the wiring back to where I had it. I was able to get about 80% of the 12v wiring back together and rough test some of the new pieces. Needed to get a few more little odds and ends before I button the electrical up though so those are in the mail.
I also repainted my bucket to match the frame a little better and found I nice sized grommet to fit the hole decently so the loom is protected a little better.
And still working out the heights and positions of everything. I will tighten everything down once the bike is back on the ground.
« Last Edit: March 20, 2018, 10:36:30 PM by bambuhiphop »
« Reply #461 on: March 21, 2018, 09:05:02 AM »
That motoscope is nice! I opted for the Chronoclassic for a more vintage look and because I tend to ride more in daylight (since LEDs can sometimes be harder to read with sunlight glare), but this looks really clean.
« Reply #462 on: March 21, 2018, 10:30:28 AM »
A "budget" hydraulic clutch set up.  No mods to the cover.  Approximately $110.
Offline bambuhiphop
« Reply #463 on: March 21, 2018, 10:38:19 AM »
That's pretty darn nifty. Is that yours?
« Reply #464 on: March 21, 2018, 11:11:25 AM »
No. Dave Hargreaves at Cerberus in San Diego. The bike is called the Devil #$%*.  http://www.inazumacafe.com/2013/04/daves-devil-#$%*.html
The bike is supposed to make approximately 100 hp.
Offline bambuhiphop
« Reply #465 on: March 21, 2018, 11:28:40 AM »
100hp! Great googly. Great looking bike.
« Reply #466 on: March 21, 2018, 02:08:09 PM »
Correction.  Dyno read 98 hp at the wheel.  That sounds like a LOT, but the owner has some skills (he was part of the 1st iteration of Confederate Motorcycles when they built the Hellcat and Wraith.
« Last Edit: March 21, 2018, 02:10:22 PM by SOHC4 Cafe Racer Fan »
Offline zeffcat
« Reply #467 on: March 23, 2018, 11:29:43 PM »
Do you have any more info on the parts required for this? I'm interested for my K8 750. Thanks!
CB750 K8
Offline Godffery
  • Godffery's Garage
« Reply #468 on: March 24, 2018, 07:02:45 AM »
That looks like a Magura, but they are intended for modern motocross clutches so I'm not sure how they would hold up on a larger vintage street bike?
Here is a link:
http://www.cross-center.com/en/magura/slave-cylinder/
Offline zeffcat
« Reply #469 on: March 24, 2018, 08:01:28 PM »
Here is a link:
Oh okay, probably better just play it safe (and cheaper) and stick to my cables.
Sent from my Pixel using Tapatalk
CB750 K8
Offline boaf
« Reply #470 on: March 24, 2018, 08:44:46 PM »
Motoscope looks great.  What’s your plan for the speed sensor?
Build Thread '78 CB550K Four 'Phoenix' - http://forums.sohc4.net/index.php/topic,171255.0.html
« Reply #471 on: March 26, 2018, 08:06:24 AM »
No, I don't.  The guy who built it built Hellcats and Wraiths for Confederate.  It's not nearly as sophisticated a solution as Goddfery's but he says it's reliable.  He's running a 1000cc Russ Collins motor.
Offline Godffery
  • Godffery's Garage
« Reply #472 on: March 26, 2018, 09:50:15 AM »
Zeffcat, I could make you a slave kit for the 750.  Making and installing an adapter plate for those are not as complex as the 550's are.
If your on a tight budget, I could design it to use a stock slave cylinder from another model Honda.  They are not nearly as sexy or warranted for life like the Oberon but can be had pretty cheep.
Offline zeffcat
« Reply #473 on: March 26, 2018, 10:08:24 AM »
Got an estimate of what cost I'd be looking at?
CB750 K8
« Reply #474 on: March 26, 2018, 03:57:02 PM »
Jeff's hydraulic clutch unit is the business.  I will have to find some kidneys to sell!
