Author Topic: 78 750F Rear Hub Disassembly?  (Read 1386 times)
Offline SOHC Digger
  • I'm not an
« on: May 10, 2011, 04:44:01 PM »
How does the bearing/seal retainer come out of the rear hub on the sprocket side?  Is it pressed in or screwed in somehow?
Offline Kanticoy
  • Mad Science!
Re: 78 750F Rear Hub Disassembly?
« Reply #1 on: May 10, 2011, 05:59:56 PM »
Screwed in,  I made a tool to remove it using an old socket.  I think motion pro makes one too.  Also has a small rubber seal in there on the back side.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: May 10, 2011, 06:29:00 PM »
Also, VERY IMPORTANT... you see those four little punch marks around the perimeter? A sharp punch or awl was used to "stake" the retainer into position. Use a small drill bit (I used a 3/16", 1/8" would probably work) and drill a shallow hole (maybe 1/8" deep) to relieve the "staked" portion of the threads. The staking process has imparted a slight deformity in the threads at the stake point to prevent the retainer from backing out. If you do not relieve this deformity you will likely destroy the retainer trying to remove it. If you don't damage it beyond reuse you will at least have exerted a great deal more effort to remove it than if you had drilled out the stake points to begin with. I drilled out the "stakes" and was able to unthread my retainer by tapping with a punch, spun right out. The right tool would make it even easier.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline brandEn
« Reply #3 on: May 10, 2011, 07:23:43 PM »
also 2 drill bits held in a vice works pretty good. Just space them the same width as two of the holes in the retainer and spin the whole hub.
Offline SOHC Digger
  • I'm not an
« Reply #4 on: May 10, 2011, 08:18:33 PM »
Thanks to all for the input!  I thought it was pressed in until I saw those "stake marks" and then figured it might be screwed in, so I asked.  THE BOARD NEVER FAILS!!!  Thanks!!!
