Author Topic: 78 750F needle seats  (Read 589 times)
Offline cmonSTART
« on: January 10, 2012, 05:18:27 PM »
Ok folks.  Are the needle seats on this bike pressed in, or do they come out?  Mine need to be cleaned very very badly and I cannot tell under all the varnish.
If they are pressed, is there anything in the seat area which shouldn't be thrown in carb dip?
Thanks again folks!
1981 GL1100 Interstate
1978 CB750F Project
Offline Ernest T
Re: 78 750F needle seats
« Reply #1 on: January 10, 2012, 06:20:47 PM »
I don't know if the CB750s specifically, but normally if they are pressed in there is no slot for a screwdriver and if they are screwed in there is a slot.
Offline Trav-i
  • Has finally become an
« Reply #2 on: January 10, 2012, 06:37:29 PM »
If your your refering to the small brass piece in the middle of the carb throat, at the bottom yes they are just a light press fit.  Just be sure to remove the emulsion tube first (the piece in the float bowl with the hex on it), then use something like soft wood and lightly down it should come out with very little effort.
Travis
Forum member #9962
1992 GL1500 Interstate
Offline cmonSTART
« Reply #3 on: January 10, 2012, 06:39:21 PM »
Ah, sorry for he confusion.  I'm actually referring to the float needle seat.
Like I said, it's hard to see below the varnish.
1978 CB750F Project
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: January 10, 2012, 06:57:28 PM »
I don't think the float needle seats are removeable. The float needles are rubber-tipped and should not wear the seats too badly. New float needles are definitly worthwhile, and relatively inexpensive.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
