Author Topic: Salt Racer CB 750 OZ style  (Read 190096 times)
Offline johno
Re: Salt Racer CB 750 OZ style
« Reply #325 on: September 03, 2013, 04:49:55 AM »
This Mikes latest update where he is in the hogging out stage, Mike has a dry sense of humour  ;D
lucky he has plenty of epoxy he said. ;)
Cheers Johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline Jim F
  • go baby go
« Reply #326 on: September 03, 2013, 05:25:12 AM »
you mean the holes are not for the Nox foggers?
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #327 on: September 03, 2013, 03:28:21 PM »
TPI..?    8)
Offline johno
« Reply #328 on: October 11, 2013, 09:48:00 PM »
Got the ignition back from Cycle x , they swapped it over for the non wasted ignition ie 4 coils.
Just have to mount the big suckers.
Offline johno
« Reply #329 on: October 11, 2013, 10:08:46 PM »
Starting to get the old girl together, am doing a dummy build now to get the bracketry and rear wheel mounted ( honda 19 inch front)
Offline johno
« Reply #330 on: October 11, 2013, 10:11:02 PM »
View backside.
Offline johno
« Reply #331 on: October 11, 2013, 10:15:06 PM »
Well Pete, we might evan make it this time  ;D ;D ;D   hoping to have the engine finished and bike running by xmas, see how we go.   Just plodding along slow and steady for the time being.
ciao johno
« Reply #332 on: October 12, 2013, 01:53:54 AM »
That will stand out in the crowd Johno, looking good mate... ;)
« Reply #333 on: October 12, 2013, 06:06:42 AM »
ciao johno
The head will be picked up from the machine shop this Tuesday.
Offline ogsmakdade
  • bike newb
« Reply #334 on: October 12, 2013, 07:26:22 AM »
good stuff here, just read through the whole thread.
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either.  Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
My "build" http://forums.sohc4.net/index.php?topic=126537.0
  • Moderator
« Reply #335 on: October 12, 2013, 08:31:04 AM »
Looking good mate, are you going to give it a name ? I could think of a few.  ;D ;D ;D ;D ;D ;D
Only joking, at least the rims are not BLACK. ;D ;D ;D ;D ;D
Sam. ;)
Offline johno
« Reply #336 on: October 12, 2013, 03:36:02 PM »
Didnt surprise me Sam you picked up on the rims  ;D    yes the bike will be yellow, all yellow, Ferrari prancing horse type yellow.........those Italians know their fast colours.
NAME for the old girl...........YES, great idea .  All you witty smart ars# out there get your thinking caps on.
I thought of a couple  ;)
Old Technology
Yestertech
onecam man ...or woncam
keep em comong you blokes. ;)
Offline Old Scrambler
« Reply #337 on: October 12, 2013, 04:39:20 PM »
Looks more like school-bus yellow to me :D :D :D
Single-Cam Sally
Single-Cam-4 Sally
Johno............you know I am watching closely. I have my A-frame in the shop and measuring where to cut and strengthen a few areas. I will use a slightly lengthened K swingarm with K cases to keep things narrow. Right now it looks like a 19" front and 18' rear aluminum comstars with a rear drum brake will work with the narrowest treads I can get. So far have located a set of 110/90s. Will use 520 chain.  My seat / tail is from an RS125 so a slight frame mod is in order.  I plan to use a short gas-tank to allow for taller carbs. My shortened 35mm fork tubes will be in the F3 trees for a slight bit of added rake. Clip-ons are fabricated from Yamaha Virago units for reliability on the indexed adjustments.
The head and barrels are from an F3.  Lots of gears, clutch shaft and chains to sort.  I am most curious about the ignition as I plan to cut-off the crank-tail and use a total loss system.  I use a very small NI battery on my Triumph and lacked a strong spark to burn the mixture under maximum load. Could have been a miss-matched ohm resistance through the coil. It worked but not as good as I hoped.
Valves, guides, springs, keepers, cam, and a strengthened valve cover are on my shopping list with Kenny. I'll start my own build thread when I can actually bolt something together.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
  • Moderator
« Reply #338 on: October 12, 2013, 06:16:29 PM »
How about Bananas and custard.  ;D ;D ;D ;D ;D ;D only joking.  ::)
There was a very fast sprint bike in England in the 60s, it was called Yellow Peril, sounds about right for the job as I think it took some British land speed records as well.
 https://www.google.com/search?hl=en&site=imghp&tbm=isch&source=hp&biw=1280&bih=523&q=yellow+peril&oq=yellow+per&gs_l=img.1.1.0l10.2435.9704.0.12999.10.8.0.2.2.0.102.484.7j1.8.0....0...1ac.1.28.img..0.10.524.Jyv1LOT9HDU#hl=en&q=yellow+peril+sprint+bike&tbm=isch
Sam. ;)
« Reply #339 on: October 12, 2013, 06:29:26 PM »
"non wasted ignition"??? Doesn't that system fire all four coils every 180 degrees of crankshaft rotation?
Offline johno
« Reply #340 on: October 12, 2013, 07:03:19 PM »
Scottly,
This brand supply two types of ignition , I ordered the non wasted version but was sent the wasted version with two coils.  I thought about returning the two coils only and keep the light pick up sensors and wiring but when I looked the pick up outputs only had two wires to the coils so I sent the lot back for exchange, I checked the new pickups and they were indeed different with four output wires for four coils.
They were sold to me as individual spark per cylinder not 180 like the dual coil version, they are supposed to have a RPM limiter as well. The key features of this ignition are light sensor pick ups,  not magnetic and the spark is controlled to provide 3 short hard sparks from the firing point rather than a single spark.
I purchased seperately a laptop connection to allow reprogramming of the advance curves and RPM limiter as well.
I know the wasted spark systems are well proven and they work well at over 200mph on big momma Hyabusa's but feeling a bit old school about having a spark happening somewhere else.  You have to remember Scottly being an old fart  I was influenced by the RC Engineering days and there maggies having one spark one cylinder , they had a lot of success and I guess I'm hoping it rubs off.  For nostalgia I was planning to run a maggie but aerodynamically on the salt it would suck.
Cheers
Offline johno
« Reply #341 on: October 12, 2013, 07:06:51 PM »
ciao johno
Dont worry Mike , I cant wait to see it.  Never thought I would own a Honda epoxy cylinder head !
cheers johno
« Reply #342 on: October 12, 2013, 07:09:48 PM »
Are the pickups referenced to the cam? If referenced to the crank, this system will still waste sparks. ;) Not saying it's a problem; just wanted to be clear.
Offline johno
« Reply #343 on: October 12, 2013, 08:13:53 PM »
Hi Scottly,
It is referenced from the crank.
I know your a bit of electrical wizz so you may be able to help me.    Maybe my terminology is wrong. I am using wasted and non wasted spark  in reference to dual coils creating a spark on two plugs at once, non wasted sparking on one plug at a time.   The people from PA are claiming the module is programmed to deliver one spark at a time, they reference the trigger to no 1 on the crank and the light sensor on the crank has 360 degree triggers ( one per degree on the light wheel on the crank) to which the module must recognise when 720 degrees is up and time to spark again.  ( rather than 360 deg)
The system is Power Arc
If it sparks two coils at once I will be not happy and use it for ars# paper and back to a maggie.
Whats the best way to test it Scottly, ....hold two plugs 1 & 4 at once , crank it over and see if it hurts both hands at once ???? just joking ;D
Cheers johno
« Reply #344 on: October 12, 2013, 08:47:00 PM »
If the trigger(s) are on the crank, then it is a wasted spark; there is no way to tell the difference between the #1 firing point and the #4. This can only be determined at the cam...
Offline johno
« Reply #345 on: October 12, 2013, 09:29:15 PM »
Captain webber. ;D
I'm onto their web site now..... will let you know their responce, sounding like I'm heading up a creek in a barbed wire canoe.
ciao johno
Offline johno
« Reply #346 on: October 12, 2013, 11:38:56 PM »
Mr current world champion....Dennis  ( has it got a nice sound to it Den ?) ;D ;D ;D
re the tyres Den:
first up I will use 19 inch front and back...........either Bridgestone Battlax 110/80  ZR-19   or Dunlop Sportmax 110/80 ZR-19
Any handling issues I will then try 18 inch rear  tyre  in matching brand.  Den I have a skinny swingarm 45mm narrower for the 19 inch but a spare std K swing arm for the 18 inch mag I have ..............so if the rad set up is a problem I just swap over the complete swingarm and 18 inch wheel.
Will have both rigid struts and shockers depending on how it all pans out.    Once on a previous thread you talked aerodynamics and I thought what you said made sense so I have been trying to create those numbers by using a over the top engine exhaust and narrower swing arm, trying to use the exhaust pipe over the engine to act as an aerodynamic aid.  Not sure if it will achieve anything but a mans gotta try. ;)
cheers johno
Offline sohc boy
« Reply #347 on: October 13, 2013, 04:41:01 AM »
... it'll stand out on that big white lake allrigh,......lookin good Johno ,progressing well
« Last Edit: October 13, 2013, 04:43:01 AM by sohc boy »
i live by the voice inside my head
Offline Bill/BentON Racing
    • BentON Racing
« Reply #348 on: October 13, 2013, 06:20:58 AM »
Very nice, Good Luck, ...."One Big Stick!!" ;D Bill
BentON Racing Website
BentON Racing Facebook
Offline sohc boy
« Reply #349 on: October 13, 2013, 03:28:09 PM »
...i allways carry a BIG STICK ..Bill
