Author Topic: name that doohickey!  (Read 1572 times)
Offline fivestring
  • not 1/4, not 1/2, not 3/4, but a
« on: February 27, 2013, 08:42:08 AM »
This little thing is mounted in rubber just above the regulator on a K8.
So what is it? Two wires go to it. One is dark green with red stripe. Second wire is light green with red stripe.
destroying classic metrics one bike at a time
'78 KZ1000A2A hardtail, '78 CB750K, '81 XJ650, '83 XJ650
Offline knowsnothing
Re: name that doohickey!
« Reply #1 on: February 27, 2013, 08:43:57 AM »
Its the flasher relay
1978 CB750k Blue - for sale
Offline fivestring
« Reply #2 on: February 27, 2013, 08:45:48 AM »
No. That is behind this thing and I just replaced the old flasher with a new one.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: February 27, 2013, 08:46:48 AM »
BUZZZZZZZZZZZZZZZZ!
Nope, the little square one is the starter safety. You can see the round flasher relay beyond.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Deltarider
« Reply #4 on: February 27, 2013, 08:47:13 AM »
It's the diode.
CB500K2-ED Excel black
« Reply #5 on: February 27, 2013, 09:15:43 AM »
BUZZZZZZZZZZZZZZZZ!
 ;D
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: February 27, 2013, 09:41:23 AM »
Yep, starter safety diode.
Offline aggiepike
    • Compare and Save on Electric Rates in TX
« Reply #7 on: February 27, 2013, 11:05:11 AM »
yup it's that doohickey. good eye, good eye.  ;)
K1 CB750 (836)
Offline fivestring
« Reply #8 on: February 27, 2013, 11:46:00 AM »
OK a starter safety diode. So a diode has one-way continuity,  right? This thing allows flow in both direction per my dmm.  What is it's purpose?
Offline metalhead0283
  • speed on brother hell aint half full
« Reply #9 on: February 27, 2013, 02:31:47 PM »
id like to know its purpose too...if it aint needed its gone!
77 xs650  81 xs650  76 cb550f  2010 triumph street triple
  • 1977 CB550F2
« Reply #10 on: February 27, 2013, 03:16:10 PM »
To prevent the starter operating whilst in gear without first pulling the clutch.
Sent from my GT-S5363 using Tapatalk 2
« Reply #11 on: February 27, 2013, 03:27:48 PM »
sweet its gone then!
Offline Patrick
« Reply #12 on: February 27, 2013, 04:44:24 PM »
Only if you plan to kick start only. The diode completes the ground on the starter circuit. You can take it out, but you have to supply an alternate ground.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
  • 1977 CB550F2
« Reply #13 on: February 27, 2013, 04:53:40 PM »
I think you can just remove it and bridge it with a wire loop. I had mine bypassed at one stage but can't remember exactly how I did it.
« Reply #14 on: February 27, 2013, 06:07:41 PM »
im rewiring my bike...gutting everything out not needed...starter is being removed n no blinkers so anything that goes with that is going
« Reply #15 on: February 27, 2013, 06:17:18 PM »
The diode keeps the neutral light from illuminating when the clutch is pulled in, and allows the engine to electric start when either the trans is in neutral or anytime the clutch is pulled in.
Offline bjbuchanan
« Reply #16 on: February 27, 2013, 06:19:58 PM »
You can delete it by grounding dark green/red wire. The diode is used as a way to make the neutral sensor and clutch safety switch play nicely together
Ground the green/red off the starter solenoid. You can now delete the clutch perch switch and have no ill effects
It is more a redundancy to make a bike more safe for people who don't ride or don't know basics of safe riding. Always check to see if in gear before starting, or pull in clutch. Without it someone inexperienced could really get hurt
Offline fivestring
« Reply #17 on: February 27, 2013, 09:05:46 PM »
Great answers, thanks gents. I'm leaving mine alone for now, just familiarizing myself to the details of this bike should I find myself roadside with an electrical issue.
