Author Topic: New Head Gasket leaking BAD...Looking for some help  (Read 4501 times)
Offline Blackhole
« on: May 02, 2014, 01:46:49 PM »
We just replaced the head gasket on my son's 78 CB750k and it now leaks BAD around the back side of #3 and #4 cylinders.  It had a small leak on the right side before but I think that was because of the pucks.  We put a good straight edge to the head and cylinders and they look fine.  You can see in the picture that it is leaking mainly on the right side .... and it looked like it might have been starting on the one place on the left with the o ring.  We had all  8 barrels and 8 barrel seals in as well as the two o rings in place.  The bike was only run for two to three minutes and we had oil everywhere.  The o rings are .050 thick and the barrel seals are .275 tall.
  We have taken apart three times in the last three days and this is getting very old.  The only other think I can think of is that the old gasket was .045 thick and looked to be the one the bike started its life with where our new one was .052...would this matter?  I am just looking for some help so that when we get it back together I don't feel sick to my stomach.
  It just seems to be a oil problem around the o rings and barrel seal as the bike started right up and seemed to be running fine. The gasket came in an NE D&K kit.  Are these the smaller o rings and seals and can you use a form-a-gasket material around them or would that be a temporary fix.
Scott
Offline harisuluv
Re: New Head Gasket leaking BAD...Looking for some help
« Reply #1 on: May 02, 2014, 01:56:27 PM »
Did you replace the pucks?  I don't see that specified in your post.
In any case, there is a very good well put together thread about this sort of thing titled something along the line of "leak free top end" and the member goes through everything quite meticulously.  Might want to check it out.
P.S.  Aftermarket gasket sets are notorious for head gaskets which are the weakest link.  Cycle X has the new MLS type gaskets.
« Reply #2 on: May 02, 2014, 02:11:27 PM »
did you deck the cylinders?
if so, the existing knock pins  now sit too high, and wont allow a seal.
check this ...
http://forums.sohc4.net/index.php?topic=107040.0
« Last Edit: May 02, 2014, 02:13:10 PM by flybox1 »
Offline Bailgang
  • Scott
  • Indiana
« Reply #3 on: May 02, 2014, 02:29:28 PM »
I just put my 77 F2 back together using the same gasket set you're using and so far no leaks at all, however I've only got maybe 70 miles on it since I got it running last weekend but so far so good. The only thing I did different from you is that I used copper spray on the head gasket and didn't use any of the head gasket o-rings (I did use the barrel seals in the kit) that came with the kit. I instead used viton o-rings that I had ordered from oringsusa.com. The only oil leak it has so far is coming from the oil pan drain screw.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #4 on: May 02, 2014, 02:41:46 PM »
I too recently finished my F3 build (0 mi so far).  +1 on the copper spray. +1 on the viton oil passage o-rings.
I left out all of the (barrel) stud packing seals.
Right between 3 & 4 you have an oil return passage.
A thin smear permatex 2 around this cutout on the gasket might do the trick.
Offline bjbuchanan
« Reply #5 on: May 02, 2014, 03:22:20 PM »
I used the exact same gasket kit you did. I was concerned about a cheaper gasket so I dusted it with permatex copper spray like has been suggested.
Shave down the dowels a bit. Doesn't have to be very scientific, the are just locating pins. Their height isn't a big deal until they are too tall from decked surfaces.
You never mentioned what torque values you used? I used 16 ft lbs and mine leaked like a b!tch immediately at the head gasket surface. I was disappointed to say the least. I took it out and over the course of two days worked it up to 18.5 ft lbs. On the second day I checked them again and a couple took a little turn before clicking over.
I took it to the torque with stock studs so yes it CAN be done. You just work slowly up to the threshold is all, you gotta use the torque wrench properly
Offline Blackhole
« Reply #6 on: May 02, 2014, 05:03:34 PM »
Thanks for the replies.
  I did replace the pucks with new Honda ones and the head was torqued to 10 ft/lbs then up to 15 ft/lbs.  I as nervous to go any higher for fear of snapping a stud.  I might order the viton o-rings and put the copper spray on.  Anyone know the size the is called for?  I wasn't sure what if anything to put on the head gasket as it seems it is a 50/50 thing on the forum as to use sealant.  When I did my CB350F I didn't use any and it worked like a charm.
  Are the four barrel holes on each side returns and the o ring holes supplies?  I will get busy and start looking at the threads you posted...thanks again for the help.  I don't want to try it again only to see oil come out again :)  I do have another new gasket I bought for my bike (78CB750F) that didn't end up fitting...but that's another story all together.
Scott
Offline Blackhole
« Reply #7 on: May 02, 2014, 05:42:53 PM »
Sorry I forgot to add that the head was not decked.
Thanks again
Offline Blackhole
« Reply #8 on: May 02, 2014, 06:26:53 PM »
  Well I just read the "Leak free top end thread" and now see what the problem might be... by the way thanks for taking the time to do that brandEn.  My son's Knock pins ( barrels) all sit .030 above the deck of the cylinders.  That might explain why the gasket was GLUED SOLID in that area on the old one to keep it from leaking.  I am starting to feel better about this :)  I guess we shouldn't have assumed the bike was never taken apart and if is was...put back together correctly.
  Could this be the problem?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #9 on: May 02, 2014, 06:29:20 PM »
I just did the top end on a 78 750F AND my 78 750K with aftermarket gaskets, no sealer, and no leaks after 1000 miles on each. Peak torque @15ft-lbs
Did you re-torque? After the initial head torque I will let the engine sit for 24 hours, loosen all the head nuts, then re-torque. This is an effort to avoid taking the engine back out after 500 miles just to re-torque... AIN'T gonna happen!
Yes.
I'm pretty sure the late model F and K head gaskets are the same. I'm also pretty sure the head gasket is asymmetrical and will not fit if it is flipped 180.
The 78 750F was an exercise in engine removal for me due to an oil leak that should have never been. I ended up pulling that engine THREE TIMES chasing a PROFUSE oil leak that left my shin covered in oil on each subsequent "shakedown" run. I started simply, just replacing the "pucks" the first time. Second time I went all the way to the base of the cylinders, where I found that the four abandoned oil returns (specific to the 77/78 750F) were missing the additional fat little O-rings (5.5mmx3mm) that are required to keep oil from being pushed up these abandoned studs and out the openings in the head (again unique to the 77/78 F model). SURELY this must have been the issue, so the engine goes back in, only to be blessed with my shin bathed in hot oil yet again!  :o  >:(
Soooo.... after pulling the engine for the THIRD TIME, with the engine on the stand, after removing the cam and cradles, staring at the top of the head while contemplating removing the head YET AGAIN, I happened to notice that one of the cam bearing bolt holes was not filling up with oil (lots of oil puddles in the top end).
 Now one side of the bearing cap uses a stud, the other side uses the bolt. Interesting thing about those cam bearing caps is that the stud that is used on one side of the cap have "bottomless" holes where they thread into the head (i.e. they go all the way through and are exposed to the atmosphere in the cavity above the spark plug well). These studs typically require thread sealer if they are removed in order to prevent oil from weeping past the threads.
Okay, enough about the studs, we are talking about the bolt side of the bearing cap (towards the rear of the cap). Took me a while to wrap my head around how the oil flows through the cam tower to the bearing. First of all, these bolt holes are not supposed to be bottomless. Apparently a P.O. had used the cam TOWER bolt where the cam BEARING CAP bolt should have been used (the tower bolt is a little longer than the bearing cap bolt). Being a curious sort, I grabbed my little squirt can of oil and squirted oil into this bolt hole, only to see that oil appear in the head cavity below, exposed to the atmosphere, in the vicinity of the head nut under the "coin" rubber puck under the cam tower. Apparently some goob of a P.O. used the cradle bolt in place of the bearing cap bolt punching through the casting! Crank down on it hard enough and it can "punch through" the casting, exposing this bolt hole to the atmosphere as well. Upon closer inspection of the cam tower, where this bolt passes through on its way to the threads down in the head, you will see that the oil feed for this cam bearing passes through this bolt bore. This bolt has oil under pressure behind it!
Pour some oil down these bolt holes and see if these holes will hold oil (i.e. bottom of bolt hole still intact). If any of these holes do not hold oil, then these threads will now require thread sealer, unless you prefer copious amounts of hot oil spewing out onto your shin while you ride, because that's what mine was doing to me. After careful consideration of what I had found I narrowed my options down to two solutions:
1) Gob up the bolt with thread sealer, bolt it back together, and call it done. Two problems with this solution were the possibility of thread sealer getting scraped off the bolt as it passes by the oil feed hole in the cam tower that passes through this bolt bore, potentially packing this oil feed with thread sealer and starving the cam bearing of oil.... not good. The other drawback to this solution (if you can get it bolted back together without plugging the oil feed) was how is the next guy supposed to know that these threads require sealer? They won't, and after some future disassembly/cleaning/reassembly, this new owner is then trying to chase down this inadvertent major oil leak.
2) The solution I finally settled upon was to use a threaded stud with a nut at this location also. This permitted me to use liberal amounts of thread sealer without fear of plugging the oil feed passage by removing the cam and cam tower before installing the stud. This made installation of the cam a little tighter than usual since the bearing cap I was dealing with was the one on the sprocket side of the cam chain tunnel. It was a little tight but far from impossible, there is no need to remove this stud during future teardowns (except for top of head resurfacing), and if the stud were ever removed, hopefully that future owner might think to themselves "why'd they do that" (use a stud in place of a bolt)?
By all means check for this potential condition, especially since it isn't supposed to exist! If I hadn't seen it for myself I never would have believed it.
Best of luck and keep us posted.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Blackhole
« Reply #10 on: May 02, 2014, 08:01:18 PM »
After your post I think I will be taking the top end of my freshly put together 78 F apart just to look things over while it is still in my workshop with the frame still apart.  All of the sudden I am nervous again.  It is kind of nice to know I am not the only one that encounters some strange problems :)
Offline Blackhole
« Reply #11 on: May 02, 2014, 08:49:10 PM »
  I just went out and looked and I do not see any marks indicating that the knock pins were up against the head but I will grind them down before putting this thing back together.
  I did put my dials on the o rings for the oil supply to the head and got .083 of an inch tall.  I do not know where I got the .050 in my original post...darn oily notes.  The gasket we were using is now .050 after being used ( I assume it would not press down much more when torqued in the head) and the recess for the o ring is .040 so it would seem the o rings are .007 of an inch from even touching the head before it is torqued down correct?
  The old o rings we took out look to be the same size maybe a little bigger but the gasket is .045 so would this be as simple as getting larger o rings and if so how big would you go?  The new head gasket we plan on using is .060 thick and has never been used and is the same make as the first one we tried.
Offline bjbuchanan
« Reply #12 on: May 02, 2014, 11:26:10 PM »
The o-rings aren't typically the problem. Obviously undersized rings are suspect and can (should) be remedied to something with a better 'x'by'x' ratio while it is still apart but my bet is still on the weak head gasket torque coupled with slightly too tall dowel pins
« Reply #13 on: May 03, 2014, 05:54:33 AM »
Both the F and the K models are susceptible to the "bottomless" cam bearing bolt hole.
TAMTF...
Wilbur
Projects:
Offline Blackhole
« Reply #14 on: May 03, 2014, 06:22:42 PM »
 I checked the cap bolt holes with a ink syringe and some rubbing alcohol and they are not bottom less.  I went and got some copper spray and will be trying again this week now that I know that I should have re torqued the head.  I will also grind down the knock pins so they sit flush.  Do you think it is safe to go to 16 ft/lbs or should I stay with 15 ?
  Does the head gasket have anything to do with sealing the oil passages ?  I would have guessed that was the job of the rubber seals on the knock pins and the o rings on the supply side...but I have been know to be wrong before.  If my head gasket starts off at .060 of an inch what should it be when it is properly torqued between the head and cylinders?  Thank for putting up with all the questions I know my son and I appreciate the help...just a little gun shy right now.
  I will post a picture of the frame kit me made when we get it back together as it has been a life saver.  Nice thing about it is there is no welding to install it.
  Thanks again
Offline Airborne 82nd
« Reply #15 on: May 03, 2014, 08:39:07 PM »
  Thanks again
I would like to see this 8)
Offline Blackhole
« Reply #16 on: May 04, 2014, 11:30:05 AM »
Here is a picture of the frame kit we made.  It is four pieces of mechanical tubing cut to a three and a half inch lengths.  The tubing has the same ID as the OD of the frame.  We cut the underside of the parts and it springs the steel out to make the ID a little bigger.  Drilled two holes in one side of each of the parts in the drill press to give us a good starting point then drilled through the frame and other side of the part while it was on the bike with a hand drill.  We drilled the support before cutting and then marked out the holes on a 3/16 piece of steel that we then drilled on the press.  We used grade 8 bolts (that still need trimmed) to hold it all together.  I just put it on for a quick picture.  Works great and there is no welding.  Sorry about the poor picture but after I get his bike running again I will post some better pictures of the one on my F in a new thread.
Offline Blackhole
« Reply #17 on: May 07, 2014, 06:34:36 PM »
I started the bike up today after work and had NO LEAKS! Thank you all for your help with this.  The things I changed were grinding the knock pins down so that they were flush with the top of the cylinders, coating the head gasket with copper spray and I went and bought two new Honda o rings.  The o rings were .010 taller and noticeably stiffer then the ones in the kit.  I also retorqued the head after letting it sit for a day.  I just need to do a little work to his carbs and get the hop out of his front wheel and it should be good to go.  I put over thirty miles on the bike today so I feed good about it not leaking.  Thanks again for all your help...I will sleep good tonight :)
« Reply #18 on: May 07, 2014, 06:37:55 PM »
That's why I keep picking up wrenches. Taking a broken lump and making it work like it's supposed to.  8)
TAMTF...
Wilbur
Projects:
« Reply #19 on: May 08, 2014, 12:02:19 PM »
I torqued my head with 28Nm (20,6 ft lbs) several times without snapping any of them. Honda OEM that were flexible.
18-20 ft lbs no problem.
Torque, wait 24 hours. loosen each nut 1/4 turn followed by tighten with same torque as last time. From the middle to the center, the small 6mm bolts, I just torqued them with 12Nm.
I sprayed my gasket with Permatex copper spray last time. Rather thick... I avoided the area closest to the oil holes.
NOTE! Do not forget the small o-rings under the cam towers.. 4 of them
« Last Edit: May 08, 2014, 01:36:21 PM by PeWe »
