Author Topic: Clutch slipping after Valvoline SAE 10W-40 4-Stroke Motorcycle Oil  (Read 9383 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Clutch slipping after Valvoline SAE 10W-40 4-Stroke Motorcycle Oil
« Reply #25 on: November 06, 2015, 03:35:22 AM »
Should there be a small gap left after I bolt up and tighten the clutch?
Are you saying that you are left with a gap between the friction plates and the hub after assembly? After assembly, is there any free play in the stack of plates?
Just trying to clarify. I'm not at all familiar with the 550's.
« Last Edit: November 06, 2015, 03:43:30 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline jonda500
« Reply #26 on: November 06, 2015, 03:40:24 AM »
I think I have the older version clutch. It does not have the large tab clutch pad. Should there be a small gap left after I bolt up and tighten the clutch?
Yes, at the bottom of the basket there should be a gap left after tightening the 4 bolts - so there's clearance for when the clutch is pulled in.
 I guess the no longer available friction disc B has been replaced with a standard small tab disc in yours - should work ok?, that's what aftermarket replacement sets have after all, 7 the same.
John
A starter clutch thread:
