Author Topic: STEEL DRAGON AIR BOX ?  (Read 9367 times)
Offline FlyingLowStevo
« on: January 07, 2017, 08:36:45 PM »
Anybody have experience with Steel Dragon Performance's sweet looking single airbox ?
http://www.steeldragonperformance.com/air_boxes_7.html
I scrapped the stock one from my 78 CB550K barnfind (I know, I know, they work great...)
Sending out the carbs to Harisuluv for rebuild & need to make some decisions about jetting...
Just read the long thread on Velocity Stacks & Pod filters......
Perhaps this airbox would be a better & less problematic option for my Cafe Racer build.
Any advice on this setup?  tips for optimum Carb Jetting, etc ?
Much appreciated & Happy New Year from this Newbee in Poughkeepsie  :o
Offline Jkstull
Re: STEEL DRAGON AIR BOX ?
« Reply #1 on: January 07, 2017, 09:57:18 PM »
I don't know anything about it, but the 2 into 4 boxes look great. I'd try emailing the company and see what jetting would be required. Post what you find and keep us updated. I'm curious to learn more.
Sent from my SM-G935V using Tapatalk
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: January 07, 2017, 11:49:55 PM »
It is a gorgeous and functional filter.
You might end up with 105 jets, depends on your exhaust pipes
Offline Scott S
« Reply #3 on: January 08, 2017, 03:38:25 AM »
 Should have saved it.... ;)
 Someone here would have bought it. And you'll be looking for it later on, more than likely.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
« Reply #4 on: January 08, 2017, 06:46:06 AM »
I have one on my 1976 CB550.  Very good quality.
I did have to go to the next larger main jet... and I got much better results when I covered the top holes with a black plastic material.  It was running much too lean without covering the top of the 4 into 1 air filter.
All in all the bike runs great with my current 'setup'!
Offline Scott S
« Reply #5 on: January 08, 2017, 06:49:08 AM »
 I never understood the guys that run pods and such "for better breathing" and then tape up or otherwise restrict them. To each his own, I guess.
'71 CB500 K0
'81 Yamaha XS650
Offline gwallis
« Reply #6 on: January 08, 2017, 07:04:44 AM »
Tapping the top of the Steel Dragon was just a quick fix as opposed to removing the carbs (again) to add larger mains.  I had to find out if the 4 into 1 air filter was going to work... or return it.
I am sure if I had went one more size larger on the jets it would have corrected the lean condition.  However, covering the the top holes made the bike run so much better I decided to leave it alone for the rest of the season.  Planning on pulling the carbs and adjusting the jets some time soon.
I mentioned the using the tape only to confirm that anyone using this air filter will need to rework the main jets.
« Last Edit: January 08, 2017, 07:06:40 AM by gwallis »
« Reply #7 on: January 08, 2017, 08:54:03 AM »
Looks from your photo that I have the same 4 into 1 exhaust.
So what size Main jets would you be using without covering the top of the air filter?
Also mine is a '78 so the carbs are not the same I think.  Maybe 2 sizes up on the main jets ?
Offline Scott S
« Reply #8 on: January 08, 2017, 09:02:05 AM »
The only TRUE way to answer that question is to do proper plug chops.
 Don't even try to tune the carbs until the 3K mile tune up is done, though. And anything he did on his carbs won't directly relate to the PD series carbs.
 Short answer: stock up on jets and spark plugs and be prepared to R&R the carbs a few times.
 I will say that in my experience the PD carbs don't run as lean as everyone thinks. But I was using the stock air box (but with other engine mods: P&P head, CB650 cam, 4-1 exhaust, UNI filter in stock air box).
'71 CB500 K0
'81 Yamaha XS650
Offline garyS-NJ
« Reply #9 on: January 08, 2017, 09:05:18 AM »
Don't listen to the fearmongers.  Its not that hard to jet a carb.  Pods, jetting, and exhaust wakes up a bike.  Stacks work too but are less streetable.  That dragon box looks nice
Sent from my VS987 using Tapatalk
76 harley stroker FL
83 Yamaha XJ550 Maxim
78 CB750F3
« Reply #10 on: January 08, 2017, 09:16:51 AM »
Actually have the stock plastic air box but trashed the rubber stacks going into it cause they were so dry and rigid, got frustrated trying to get the box out so cut them out (My bad!) Anyone know of a source for replacements?
Still like the clean look of Steel Dragon unit, but wondering about performance. Their integral stacks seem kind of short in order to fit the air box in front of the diagonal frame member & not behind it as the stock air box/filter is positioned.
Thoughts?
« Reply #11 on: January 08, 2017, 09:25:16 AM »
Thanks Bro... I guess I'm just trying to figger out what jets to start out with since Harisuluv is doing the rebuild with new jets and I'm leaning in the direction of that new fancy air box...  get her up running, then trial & error over time.
« Reply #12 on: January 08, 2017, 09:28:24 AM »
Thanks for the encouragement Bro!
Got a long way to go, but having fun : )
Living out my boyhood dreams now that I'm a senior...
« Reply #13 on: January 08, 2017, 09:36:08 AM »
Hey Scott,
Assuming the stock stacks are engineered as optimum length (between stock airbox & carbs) could anyone measure that length  to compare to the Steel Dragon setup?
Am I even making sense here?
Offline Scott S
« Reply #14 on: January 08, 2017, 09:37:54 AM »
 Didn't say it couldn't be done. Just said there's no cheat sheet for it. Jets-R-Us, Sirius Consolidated or 4into1.com all have jets. Stick with genuine Keihin when possible and order up a few sizes up and down.
'71 CB500 K0
'81 Yamaha XS650
« Reply #15 on: January 08, 2017, 09:39:18 AM »
Will do
Offline Scott S
« Reply #16 on: January 08, 2017, 09:39:54 AM »
Hey Scott,
 I don't have a bike with PD carbs anymore. And it's not as much about the length of the velocity stacks as it is the chamber of still air that the stock air box/plenum has to pull from. You lose that plenum AND you're introducing changes that may (or may not) make the bike leaner or richer.
'71 CB500 K0
'81 Yamaha XS650
« Reply #17 on: January 08, 2017, 09:58:08 AM »
You can try everything including sticking a tuba on your carbs, but nothing is going to make more power than the stock air box...Until you modify the cylinder head internally.  The airflow obstruction is in the head.  The stock air box provides ample still, laminar air for well beyond stock airflow and power level s
Offline flatlander
« Reply #18 on: January 08, 2017, 10:18:03 AM »
that sounds over complicated. you don't need to remove the carbs to change jets, just drop the bowls.
Offline Scott S
« Reply #19 on: January 08, 2017, 10:25:11 AM »
 I got to where I could R&R the carbs quicker than I could pull the bowls on the bike!
 But....that said....with pods or an air box like this, you could have the carbs off in about two minutes.
'71 CB500 K0
'81 Yamaha XS650
Offline flatlander
« Reply #20 on: January 08, 2017, 11:37:05 AM »
ah yes, didn't consider pods etc (i'm still in good old airbox land) in which case removing would be as quick or quicker than fiddling a piece of plastic to the right size and sticking it inside that filter box!
Offline sixthwisconsin
« Reply #21 on: January 08, 2017, 11:40:23 AM »
I'm running the same air box on a 1974 cb550k0 with 022A carbs. I switched from a "TinTop" filter which I had problems with fitment but loved the design.
I have a 550f header a 12" cone engineering reverse megaphone.
Jets are 125 main and 40 pilot with the needle third up from full rich and air screws at 1.5. I think I'm pretty close but I was fat on the idle circuit and just went back to 40.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #22 on: January 08, 2017, 11:51:02 AM »
Then why do so many struggle with it and so few get it right?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline garyS-NJ
« Reply #23 on: January 08, 2017, 11:55:56 AM »
Factory pro has rule of thumb stuff to get you in the area, perhaps right on.  I like what sean barney said about the tuba and I hear him a little but i think factory tunes for emissions and quietness and all around rideability for your average Joe and everything is a compromise.  I kinda remember air intake restricts before exhaust, but opening up your exhaust will make it run leaner (because more air).  And more air is more horsepower.  And so after intake, jetting, and exhaust, the next improvement (still a compromise, you might loose some idle or low end torque), is a cam change..  Then you could start flowing your head and changing valves but that's out there with higher compression pistons, bigger bore, stroke...  Cheapest hp gains are bigger displacement bike to start with.
78 CB750F3
Offline garyS-NJ
« Reply #24 on: January 08, 2017, 11:57:45 AM »
Maybe people struggle because they don't think or research.  And for whatever reason, a lot of folks don't share their results
78 CB750F3
