Author Topic: Drilling Rotors  (Read 77075 times)
Re: Drilling Rotors
« Reply #275 on: June 23, 2009, 03:35:44 AM »
Is Tom (Anubis) still doing them? You better check with him, I had a feeling that he wasn't? Cheers, Terry. ;D
Offline Dave-and-his-550
  • I know the pieces fit...
Re: Drilling Rotors
« Reply #276 on: June 23, 2009, 03:20:21 PM »
Ya, I got an email from him saying it'll cost me $35 + $11 shipping. I asked about different templates, and he said he only used one :(
I'll have to ask him if he could use a template that I send him.
Offline SKTP
Re: Drilling Rotors
« Reply #277 on: July 20, 2009, 02:47:15 PM »
It's probably been covered many times before but after searching for the last half hour I come up with so many different opinions that I'm confused.
I drilled out my K6 rotor tonight.
The edges of the holes are puckered slightly above and below.  I've read differing opinions on whether to chamfer the holes or not.  I can't imagine why it would be good for the brake pads to leave the holes as they are...
I have a chamfer drill bit should I remove enough material with this 45 degree bevel bit to leave a smooth surface?   That seems logical to me, but would love some expert opinion.
Thanks!
Lookign throught the 19 pages of rotors....do you have the template for this pattern?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline UnCrash
  • Pass
    • My Blog
Re: Drilling Rotors
« Reply #278 on: July 21, 2009, 04:50:44 AM »
Hi SKTP,
I didn't use a template.
I got a little plastic protractor from the art store like this:
I centered it and started by marking 0, 90, 180, and 270 with a Sharpie.  Then I kept halving the marked distances until I got the interior row marked out.  It was surprisingly quick and simple, and much quicker than making my own paper template...
Much earlier in this thread you may spot my drill press jig for these.  Here's a picture I snapped of another pattern I drilled just for fun on an old rotor I had laying around.
[/img]
Luckily this drill press has a round drilling platform with a 1" hole in the center.  I rummaged around the plumbing section of the hardware store for the bits that you see and used electrical tape to pack out "bearings" between the parts to keep it all solid.  The unit is bolted through this 1" hole from top to bottom.
A rotor will rotate freely on this jig with less than 1mm of runout.  I didn't center-punch any of the holes, but did use really good bits.  I've used the same bit on 2 rotors now and it still is fine.  Based on Terry's recommendations I've used undiluted dish liquid  mmmm lemony...  and cleaned the press up with  water then a spray down of WD-40.
Good luck!
Offline SKTP
Re: Drilling Rotors
« Reply #279 on: July 22, 2009, 04:24:04 PM »
5/16" holes, 40 hole pattern...I think i am going to go with this - what do you think?
« Last Edit: July 22, 2009, 04:28:51 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline ev0lve
Re: Drilling Rotors
« Reply #280 on: July 22, 2009, 04:39:51 PM »
Some of Tom's (Anubis) handiwork.
Very happy.  ;D
« Last Edit: July 22, 2009, 04:43:14 PM by Iggy »
Offline SKTP
Re: Drilling Rotors
« Reply #281 on: July 22, 2009, 06:04:15 PM »
I think I like this one better (than the one I previously posted)...45 holes, they'd be 5/16"
« Last Edit: July 22, 2009, 06:13:26 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
deuce_454
Re: Drilling Rotors
« Reply #282 on: September 16, 2009, 10:19:39 PM »
ive looked into pattern as well and i decided on a shamless copy of cyclex....
180 holes, rows alternating 3 and 2 holes seperated by 5 deg. hole diameter 8mm. holes layed out on concentric circles 9mm appart.. rows of 3 holes are 9, 27 and 45mm from inner edge... rows or 2 are 18 and 36.. (see pic)
I decided to clock them to match the rivets.. and make 3 "dummy"/lightning holes in between the rivets.. still 8mm in dia, but just sunk 3mm into the disc, not thru it
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Drilling Rotors
« Reply #283 on: April 24, 2010, 11:53:40 AM »
I'm dragging up an old one here, cause I still can't sort myself/
These 2 jpgs have been offered up as 750 templets. When printed they are to small?
What am I missing?
Re: Drilling Rotors
« Reply #284 on: April 24, 2010, 03:24:31 PM »
Hey pal,
This is what yer missin. 120 holes.  ;)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: Drilling Rotors
« Reply #285 on: April 24, 2010, 06:36:06 PM »
I used this one today. Blew it up 150% and it worked. ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: Drilling Rotors
« Reply #286 on: April 26, 2010, 08:07:12 PM »
I found this thread a week ago. It seemed to be the most definative yet confused thread on the subject ;D
 It took a while to realize some of the links to templets are broken, and some of the jps. when printed didn't really fit on my rotors that well. With no written sizing instructions, I got tired of wasting paper and carried forward on the thread.
I used the jpg above and as I stated when moved around and blown up 150% on a printer you get 3 pieces of paper and they fit like a dream ;D
My tools.
No fancy rotating drill press. Just a small "sit on the counter press" with 4 $7.00 Titanium bits that I got at the hardware store.
I punched the start of all holes while paper templet was on and then removed it.
I used dish soap about 4 squirts per hole, in, out etc.  I just held rotor in place with my hand.
Very happy with my new skill and the end result.
Here's a photo. 8)
Perhaps a FAQ.    I may have missed it but I found it a long search to locate on "drilled rotor pattern/templet".
I still couln't have even have done it without this forum though ;)
Offline SKTP
Re: Drilling Rotors
« Reply #287 on: April 26, 2010, 08:50:12 PM »
So cool! I made that template...I have a bunch more if you guys want them. I can upload them as PDFs so you can scale them up...they are made in Adobe Illustrator by the numbers and are mathematically sound...but please note; I'm a graphic designer not a rotor engineer.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: Drilling Rotors
« Reply #288 on: April 26, 2010, 08:57:54 PM »
Nows the time to put them up here ;D
Re: Drilling Rotors
« Reply #289 on: April 27, 2010, 04:32:54 AM »
Nice work Seaweb!
I agree this should be in the FAQ.
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
Re: Drilling Rotors
« Reply #290 on: April 27, 2010, 05:43:01 AM »
Mr Goon has some drawn up for Adobe, a while back..for the 400,550,750
http://forums.sohc4.net/index.php?topic=45389.0
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline SKTP
Re: Drilling Rotors
« Reply #291 on: April 27, 2010, 10:20:08 AM »
I made a PDF with 11 rotor patterns...Photobucket will not allow me to host it there...anybody have a good place to upload it to?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline MaaseyRacer
    • Fuelist
Re: Drilling Rotors
« Reply #292 on: April 27, 2010, 10:31:24 AM »
Media Fire:
http://www.mediafire.com
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Re: Drilling Rotors
« Reply #293 on: April 27, 2010, 11:09:45 AM »
Nice work Seaweb!
Good point Andy. The site is so big at this point it is hard to find things. A lot of wisdom gets lost in the noise.
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Drilling Rotors
« Reply #294 on: April 27, 2010, 11:26:06 PM »
I wonder if this software has an add-in that will allow us to use tags?
I'll ask...
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: Drilling Rotors
« Reply #295 on: April 27, 2010, 11:36:11 PM »
I just did a search for "drilled rotor pattern" and "drilled rotor templet" it comes up now that I typed that in here. ;D ;)
Offline UnCrash
  • Pass
    • My Blog
Re: Drilling Rotors
« Reply #296 on: May 04, 2010, 08:29:09 AM »
Nice job SeaWeb!
I agree with adding the good elements of this thread as a FAQ.
Offline Laminar
  • Retsam
Re: Drilling Rotors
« Reply #297 on: May 04, 2010, 08:58:24 AM »
Autodesk Inventor:
Drill press, 1/4" bit. Northern Tool brand drill bit couldn't manage one hole. DeWalt drill bit did 10. Milwaukee drill bit did the other 26 and it's still sharp. Chamfered with a 1/2" drill bit.
Offline SKTP
Re: Drilling Rotors
« Reply #298 on: May 04, 2010, 09:43:25 AM »
That rim pin-stripe looks awesome
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
