Author Topic: sohc f2 head  (Read 7112 times)
Offline tony sawyer
sohc f2 head
« on: December 11, 2012, 11:51:26 AM »
hi any problems with the f2 head on f1 or k barrels ,i take it i have to use f2 pistons or higher comp than stock  any other issuse rgds tony
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: sohc f2 head
« Reply #1 on: December 11, 2012, 12:23:46 PM »
Here's one post: http://forums.sohc4.net/index.php?topic=369.msg42059#msg42059
and there are numerous threads devoted to this, still filtering through the search results.
http://forums.sohc4.net/index.php?topic=17622.0;nowap
http://forums.sohc4.net/index.php?topic=49659.msg547619#msg547619
 The later F2 heads require the ability to address the exposed studs that happen to serve as oil returns on the earlier heads and cylinders. You either need to combine the F2 head with F2 cylinders (and the FOUR additional o-rings at the base of the cylinders) or the F2 head can be sleeved (AND sealed) at these stud locations to eliminate their exposure to the atmosphere in order to use the F2 head with earlier cylinders. I just spent two months chasing the source of the four hot oil fountains at the head because the P.O. left out the four o-rings at the base of the cylinders on my recently aquired F2/F3 (78 CB750F)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: sohc f2 head
« Reply #2 on: December 11, 2012, 12:26:35 PM »
Yeah, it's pretty much as cases-up swap BUT if can be done otherwise BUT it ain't worth the trouble to do otherwise
Offline tony sawyer
Re: sohc f2 head
« Reply #3 on: December 11, 2012, 12:55:11 PM »
hi have  another  option of f2 head and barrels 836 or f1 head and barrels 836 both pistons 10.25
wot cam any prefrences
  • Moderator
Re: sohc f2 head
« Reply #4 on: December 11, 2012, 01:17:36 PM »
I take it it's for the side car :-\ if so, depends on where you're racing.
Megacycle 125-70/75 for IOM, gives more top end.
Megacycle 125-60/65 or Dynoman DP295 for short circuits, lots of low down and mid range grunt with 836 pistons.
Sam. :)
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
Re: sohc f2 head
« Reply #5 on: December 11, 2012, 01:18:15 PM »
Difference K and F2:
You meet the nicest people on a Honda
Offline bear
  • Leeton in Australia
Re: sohc f2 head
« Reply #6 on: December 11, 2012, 05:12:10 PM »
We have found that the F2 head is the best option for us.
We use comp. S/S valves from an EVO8.
35mm in. and 30mm exh.
Some machining is required but nothing a good head man can't handle.
The Mega 125-70/75 is the go with the head mods mentioned above, it has good lift and short duration.
We set the timing with 5deg. more advance than suggested on the timing card, this brings the curve down to a more usable rev range for the chairs.
PM if you would like more details.
Brian
« Last Edit: December 11, 2012, 05:15:20 PM by bear »
Re: sohc f2 head
« Reply #7 on: December 11, 2012, 08:02:17 PM »
If you have the complete F2 top end I'd go with that. The larger valves will breathe better.
Howell, great compilation of info! What is the source for that?
Offline cbr954
Re: sohc f2 head
« Reply #8 on: December 11, 2012, 08:07:07 PM »
Cycle X has that sheet up on there website but I think that is from Action Fours???  I am not sure of that though.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline dragracer
  • CB750F Dragbike
Re: sohc f2 head
« Reply #9 on: December 12, 2012, 06:14:42 AM »
Stupid question, whats an EVO8?????
Brian
Offline Tintop
Re: sohc f2 head
« Reply #10 on: December 12, 2012, 07:21:44 AM »
My quess would be a Mitsubishi EVO.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline johno
Re: sohc f2 head
« Reply #11 on: December 12, 2012, 11:48:32 AM »
 Mitsubishi  it is , I used the same valves on the hi port head.
johno
Offline dragracer
  • CB750F Dragbike
Re: sohc f2 head
« Reply #12 on: December 12, 2012, 08:10:19 PM »
johno
Can i assume that the stem size on the EVO valve is the same as stock F2 stems???
Offline dragracer
  • CB750F Dragbike
Re: sohc f2 head
« Reply #13 on: December 12, 2012, 08:52:06 PM »
I researched a few sites and confirmed the stem diameter is close. I have not measured the length of the stock F2 valve yet. Hopefully its a lot shorter than the EVO valve so theres room for a new keeper groove.
http://www.racecomponentsinc.com/Evolution-Evo_VII_IX_Intake_and_Exhaust_valves_1mm.html
Offline johno
Re: sohc f2 head
« Reply #14 on: December 14, 2012, 04:43:12 AM »
captain dragracer  :D
I will be back home on Monday, I'll take some pics of them and specs to fit etc and send to you if your interested. Stems a touch bigger but For the larger bore brigade they allow you to run an average port diam of around 31.5mm with good air velocity up from 30.6mm with a 34mm valve.    Still why worry ! just put evan bigger valves in and run a sprocket as big as the wheel ;D ;D ;D
 Begs the question! whats the biggest inlet valve anyone has run or heard of being run ?  ( apart from captain Ken at Cycle x new beast) ;)
johno
Re: sohc f2 head
« Reply #15 on: December 14, 2012, 03:46:53 PM »
Have we told anyone the secret intake size of the NEW CycleX head?!?!
Offline cbr954
Re: sohc f2 head
« Reply #16 on: December 14, 2012, 05:21:18 PM »
website says 38mm intake  32mm exhaust.
Re: sohc f2 head
« Reply #17 on: December 14, 2012, 05:44:00 PM »
And it's true. Does it say the intake runners are set up for 40mm carbs?
Offline dragracer
  • CB750F Dragbike
Re: sohc f2 head
« Reply #18 on: December 14, 2012, 06:10:57 PM »
Heck, i even got to touch it in person. I'm still dreaming about that head!!
Offline dragracer
  • CB750F Dragbike
Re: sohc f2 head
« Reply #19 on: December 14, 2012, 06:18:15 PM »
johno
Sir Johno.
I would be most honored if you would kindly share the information on using the EVO valves in an "F" head. My email address is; NEXTPLAIN@aol.com. I cannot afford to buy or duplicate one of those CycleX heads but if there is a chance to do some affordable mods to mine like the use of the larger EVO stainless valves, I will surely pursue that option to the best of my financial ability. The only drawback is the need for stiffer springs to keep those heavier valves from bouncing off the seat and the impact to my current cam tower set up. But then, CycleX already has a fix for that one too.
Re: sohc f2 head
« Reply #20 on: December 15, 2012, 05:26:52 AM »
Not to be a buzzkill but those valves are real heavy. I have had the stock size F2 valves made up with 5mm stems (with the stock tulip)....they are still heavy. One problem I found was valve to valve clearance with a real big cam with a lot of overlap. Another problem was getting enough spring with Kibblewhite 5mm guides. That was for an LSR engine but drag racing is the same. If anything I'd go to a 36mm intake (changing the seat) and shrink the exhaust valve (changing the seat again). The F2 port could handle the 36 intake. But where do you get new F2 carb manifolds???????? ;D ;D ;D
Offline dragracer
  • CB750F Dragbike
Re: sohc f2 head
« Reply #21 on: December 15, 2012, 07:35:22 AM »
Die grinder????
Offline dragracer
  • CB750F Dragbike
Re: sohc f2 head
« Reply #22 on: December 15, 2012, 07:43:28 AM »
Mike,
I felt that weight would be a big issue so the correct seat pressure is extremely important. Finding the right springs could be an issue.  Good point on the valve to valve problem.
Lots to think about and experiment with at this point. It could be time to invest in some equipment and find a few old heads to play with.
Re: sohc f2 head
« Reply #23 on: December 15, 2012, 08:56:55 AM »
Die grinder????
Yes....that would work Frank. ;D ;D
Re: sohc f2 head
« Reply #24 on: December 15, 2012, 10:09:31 AM »
Mike,
I agree THOUGH you could use Ti. ;) ;D
