Author Topic: First Honda  (Read 1437 times)
Offline terrorshark
First Honda
« on: June 17, 2013, 07:23:26 AM »
Just picked up my first one. Traded a '72 Yamaha DS7 for a '74 CB550.
Bike looks incredibly clean for sitting in a garage for 20 years. Don't know when it was last ridden but the tank is rust free with no corrosion anywhere on the bike.
It looks like the original owner removed the ignition and installed some goofy on off switch as well as cut off the hump on the rear of the frame.
I figure since the frame has already been cut I should probably just turn it into a cafe racer.
Problems I've found so far...
Wiring is screwy due to the rewired ignition.
Carbs slides are completely seized.
Read some tricks for unsticking the carbs so hopefully an overnight soak will work.
'68 MV Agusta Tevere Motocarro
'72 Yamaha LS2
'74 MV Agusta 350b
'74 Honda CB550
'77 MV Agusta 350 Ipotesi
'00 MV Agusta F4
Offline toytuff
  • "watching the pinheads"
Re: First Honda
« Reply #1 on: June 17, 2013, 07:27:52 AM »
Welcome.
Try a heat gun on the slides. Sometimes it's just enough.
tt
Re: First Honda
« Reply #2 on: June 17, 2013, 07:54:15 AM »
+1 on the heat gun.  softens the varnish.
welcome to the forum.
its your bike, make it what you want it to be  8)
good resources available here.  download the shop manual from this site.
the google custom search at upper left is a great help at finding threads for everything you are working on.
get in the habit of using it first as it can get you the most info the fastest, then post to the forum if you're stuck.
we like pictures  8) ;D
Offline Bankerdanny
  • Endeavor to persevere
Re: First Honda
« Reply #3 on: June 17, 2013, 08:48:46 AM »
Welcome, this is by far one of the best vehicle forums on the web (I belong to half a dozen).
Sounds like the PO (prior owner) was planning a cafe or bobber conversion.
Our montra here is "pictures or it didn't happen', so include them as often as you can
Offline terrorshark
Re: First Honda
« Reply #4 on: June 17, 2013, 11:12:14 PM »
Will post pictures tomorrow!
I do have a question
While pulling apart the bike last night I found something I've never seen before.
It was mounted under and behind the headlight and looked almost like a speaker.
Small about an inch or so in diameter.
Any ideas...?
'72 Yamaha LS2
'74 MV Agusta 350b
'74 Honda CB550
'00 MV Agusta F4
Offline stewonepot
Re: First Honda
« Reply #5 on: June 17, 2013, 11:40:33 PM »
Its a turn signal beeper it will get on your nerves!
Offline kghost
Re: First Honda
« Reply #6 on: June 17, 2013, 11:53:17 PM »
It will also keep you from looking like a complete tool .....driving around with the blinker on.
Stranger in a strange land
Offline stewonepot
Re: First Honda
« Reply #7 on: June 18, 2013, 01:41:05 AM »
Very true been there done that!
Re: First Honda
« Reply #8 on: June 18, 2013, 05:14:45 AM »
Welcome.  I believe you'll need 5 posts before you post pics
Offline terrorshark
Re: First Honda
« Reply #9 on: June 18, 2013, 06:55:01 PM »
I would love to post pictures but cant quite yet...
Freed up my carbs today and scored an whole set for backup for 30 bucks!
Waiting on my rebuild kits to put them back on
Cut off my seat bracket so I can mount a flat Brat style seat.  Now I just need to grind down all the ugly leftovers.
Sprayed engine down with degreaser and gave it a clean
And I ordered all my parts to get her back on the road.
I want to take out the battery box and remount all the electrical goodies.  Anyone have any pictures of what they have done?  Definitely going to an antigravity battery but have no idea which one I should get.
Does anyone have any ideas for battery mount and electrical boxes
'72 Yamaha LS2
'74 MV Agusta 350b
'74 Honda CB550
'00 MV Agusta F4
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: First Honda
« Reply #10 on: June 18, 2013, 07:06:55 PM »
Any ideas...?
That's the flux capacitor! Careful with that!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline reddyvv
Re: First Honda
« Reply #11 on: June 18, 2013, 07:28:16 PM »
HA HA,  didn't those 74's have the 1.21 gigawatt capacitors?!!  ;D ;D
Offline goldarrow
  • one day, i'll be an
Re: First Honda
« Reply #12 on: June 18, 2013, 07:55:21 PM »
carbs rebuild kit......all you need are rubber pieces, clean off your hardware bits and reuse those, if they were original.
CB550 K0
