Author Topic: Fuel gauge for CB750  (Read 12944 times)
Online madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Fuel gauge for CB750
« Reply #25 on: October 04, 2013, 11:33:19 AM »
But, correct me if I'm wrong, you would have to stop take the key out and open the door covering the gas cap and guage?
We are only talking about the sending unit here. The "A" tanks route the wire from the sender to the gauge (gauge is separate from the sending unit) down through the "tunnel".
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #26 on: October 04, 2013, 03:12:19 PM »
Unless the fuel door was removed
Offline Stoli
« Reply #27 on: October 04, 2013, 11:35:45 PM »
I was thinking along the same lines as Wilbur. It looks like there are 3 possible positions for the rheostat. Pick the lowest one possible, cut off the rest of the post, adjust the float arm as necessary and route the wire down through the drain hole to the gauge. The sending unit will read 33 ohms at empty and 240 full. Piece of cake.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
« Reply #28 on: October 04, 2013, 11:38:44 PM »
or just buy gas every 135 miles (or so)...bigger piece of cake
Offline Stoli
« Reply #29 on: October 05, 2013, 06:02:18 AM »
I respectively disagree. You are right of course, but I see this as a $25 upgrade that will take less than an hour to install and probably another two hours of coding to add a low-pass filter into the software that will dampen out the faulty readings during acceleration and cornering. While Geeto is removing his gas cap at the stop light I'll be glancing down at a functioning fuel gauge and nodding at the girls (who are ignoring me).
The bike I am working on has an old rusty frame which works very well, but I think I'll powdercoat it even though it would be easier and much more practical to leave it as is. Call me crazy but I don't see the difference between that and trying to get a fuel gauge working. It's a long winter, and if I can't ride the bike I might as well tinker with it.  ;D
« Last Edit: October 05, 2013, 06:34:57 AM by Stoli »
My Project Threads:
Online Killer Canary
  • Typical Bran Muffin
« Reply #30 on: October 05, 2013, 08:09:15 AM »
I wish that the fuel gauge in the old Mazda was as good as the one the GPz has.
Kawi GPz900, H1
« Reply #31 on: October 17, 2013, 08:23:55 PM »
There is a new one for sale in the for sale thread.....
