Author Topic: 1976 CB550F - making it good, one step at a time  (Read 144622 times)
Re: 1976 CB550F - making it good, one step at a time
« Reply #250 on: July 21, 2015, 03:41:28 PM »
Congrats...isnt that a good feeling lubing them up and inserting?
You should be up and running in no time.
Offline flatlander
« Reply #251 on: July 21, 2015, 10:59:27 PM »
with that question... am i still on the right forum here? or are you testing my dirty mind??
but yes, feels good to have come this far. getting really close now  :)
« Reply #252 on: July 22, 2015, 07:14:03 AM »
Everything is bigger in Texas
Offline flatlander
« Reply #253 on: July 22, 2015, 01:54:12 PM »
all my exes live in texas
« Reply #254 on: July 22, 2015, 07:47:26 PM »
Offline flatlander
Re: 1976 CB550F - mixed messages
« Reply #255 on: July 23, 2015, 02:20:44 PM »
there's good news and bad news. the good news first:
i connected all the cables and wires. filled up the oil. put on the tank.
spark on all plugs - check.
oil going into head - check.
fuel running - check.
FIRE!
 - and she runs!
only run it very briefly but she fires up promptly with choke, then gets steady on a little bit of throttle and half-choke. for a cold 550 that's how i'm used to it. after so many months this sounds like music ;D
now the bad news:
there's fuel pissing from the carbs. seems to come from that T-shaped connection piece between no.1 and 2 carbs, that the fuel line is attached to.
i fear there is no option but to pull the carbs again  :'(
« Reply #256 on: July 23, 2015, 05:09:13 PM »
Unfortunately, I think you are right.  But congrats, she runs!
Offline flatlander
« Reply #257 on: July 24, 2015, 01:10:35 AM »
yes at least i have the peace of mind that everything i did and wired up actually works.
still, sucks having to wrestle with the carbs again. oh well, if it has to be done...
i could beat myself up for not having tested them with some fuel before installing. i replaced all the old fuel lines on the carbs and must have disturbed something in the process. i guess if you're stupid you have to learn the hard way, ha ha!
« Reply #258 on: July 24, 2015, 06:09:29 AM »
Don't be so harsh on yourself, it happens.  If it makes you fell any better, I'm in the same boat fighting a fuel leak.
« Reply #259 on: July 24, 2015, 10:32:10 AM »
Take some solace in the fact that you've narrowed your issues to a fuel delivery issue and more specifically just a leak at a connection point.
Offline flatlander
Re: 1976 CB550F - fuel o.k. / clutch k.o.
« Reply #260 on: July 24, 2015, 02:40:36 PM »
guys it's all good - the leak is fixed. it was indeed that T-connection. i don't know why i didn't think of testing the carbs after reassembling them, it would have saved my quite some carb-wrestling.
now here's the next thing: i can't get the clutch to disengage. i've adjusted it with the screw on the clutch cover, and it's definitely pushing in up to a certain point and no further - but doesn't go free.
i did this clutch mod described by bwaller: http://forums.sohc4.net/index.php/topic,145565.0.html
could be that i need to remove the shim under the circlip that he's talking about. i re-used the one i had before the mod as the measurements seemed right, although quite tight. taking it out may create enough space for the plates to move.
Offline flatlander
Re: 1976 CB550F - clutch carnage
« Reply #261 on: July 25, 2015, 10:12:17 AM »
opened the clutch cover to get to the bottom of this. already when i drained the oil it looked very suspicious. this is what greeted me:
some material shaved off the hub cover, and most of the "pegs" of the outermost plate broken off.
it had contact with this lever, which also explains why i could not get it to release:
not sure yet where the cause lies: either after the mod, the whole basket is too tall and some more space needs to be created - or maybe something was wrong with the position of the lever.
i also put up some more pictures in the thread about the clutch mod: http://forums.sohc4.net/index.php/topic,145565.msg1711685.html#msg1711685
hope someone who has done this mod can comment if they had similar trouble, or did some additional work that i missed?
« Last Edit: January 01, 2016, 04:20:39 AM by flatlander »
Offline flatlander
Re: 1976 CB550F - clutch o.k.
« Reply #262 on: July 31, 2015, 03:58:32 PM »
i reverted the clutch back to the stock setup - with all new OEM parts. as this is the last thing stopping me from doing break-in, and as i still want to ride the bike this summer this seemed the quickest fix.
to be sure, i test-assembled it. marked the areas on the clutch hub and outer plate that had been previously shaved off, with black sharpie. then put the adjuster screw to max and turned it a few times with the kickstarter. the black marks were all still there so no contact.
adjusted it, and after pushing the bike back and forth a bit it actually broke free so this works now.
i'll leave it with that, the stock clutch will have to do. with all new parts it should be in good enough shape anyway. i can return to the mod during winter.
tomorrow i'll fill up the oil and time the ignition - then we should be good to go!
« Last Edit: July 31, 2015, 04:00:08 PM by flatlander »
Offline flatlander
Re: 1976 CB550F - getting ready
« Reply #263 on: August 01, 2015, 07:00:58 AM »
now that everything is fine a look for a better hiding place for the transistor box. there's a space behind the air filter box where it can be wedged in between the filter box and rear fender. it's fiddly to get it in there even with the filter box loose but it fits well, is secure and out of sight.
then i push the bike around the corner to my local shop to check the ignition timing with the strobe. the guys are busy but they hand me the strobe gun: "you know what to do with this, right?"
having a good, helpful local shop is priceless - gotta support these guys.
then curiousity pulls them away from their work and they do come to check out the bike. they're very interested and like it a lot. "you're a top mechanic" says the boss. as an amateur wrencher i take this as quite the compliment from a pro!
anyway, the strobe shows that the timing is spot on as i set it - good to have that confirmed.
going for a first break-in ride now...
« Last Edit: January 01, 2016, 04:22:08 AM by flatlander »
« Reply #264 on: August 01, 2015, 07:16:33 AM »
Alright...good luck!
That VIN tag is interesting, diff than the US model.
Was that bike originally imported to Sweden?
Offline flatlander
Re: 1976 CB550F - break-in rounds 1 and 2
« Reply #265 on: August 02, 2015, 01:18:15 PM »
strange... i typed an answer yesterday but it didn't get posted:
the text on the vin tag is english and german, not swedish. not sure if this was normal for the european bikes, or if it means that it was originally meant for the german market?
yesterday i did a round of about 50km on a winding local road. that worked the engine through its range really well.
ass dyno report: it spins easily and freely, revs up very promptly and pulls like a really strong little devil. definitely has more punch, and delivers it quicker.
it also works nice and smooth, no hickups of any kind. the clutch is both easy and holds well.
back home i did a quick check and found no funny stuff. no oil leaks a at all - phew!
then i changed the oil and filter.
there was some fine debris in the oil. could be left over from when the clutch got chewed up? anyway, i decided not to worry as it was very tiny particles.
the engine also got quite hot, i think that's because the jetting is on the lean side. after the ride i checked the plugs and they don't look too far off - but this was not a plug chop at a certain rpm range, so not necessarily representative.
today - round 2.
i picked a route around the ijsselmeer. that's a body of water that used to be part of the north sea before it got closed off with a dam, in 1952. you can see it here in the picture, that big blue thing in the middle:
always along the coast, on small roads, is about 300km. riding hard pretty much non-stop this takes almost a full day. after this the bulk of the break-in would be done. a friend with his VFR was masochist enough to accompany me  ;D
as yesterday, the bike behaved very well but i noticed a few tings.
past about 8500rpm it doesn't really get stronger. i think this is an indication that the main jets may need to go up one or two numbers. i'm making a dyno appointment so this will get sorted soon.
then when we were almost half-way i couldn't rev past about 4500rpm in any gear. stopped for a quick check, found nothing weird so let it cool down a bit then continue - still the same. idle was steady, carbs got fuel... maybe the ignition timing went out of adjustent?
after stopping for a quick lunch and letting the engine cool down i looked under the ingition cover, but all looked good. so what could this mystery rev limiter be?
looking up i noticed that the counter nut of the clutch push cable had gotten loose, and in a funny spot where it restricted the clutch mechanism as such. so luckily this turned out to be  something simple.
i popped off the tank and tightend it back on really well.
after this it ran well again, for the rest of this round.
changing the oil (and filter, again) the debris i found was much less, and even finer than yesterday. that's a good trend.
that's the good stuff.
then i have a tiny oil leak at the left hand side of the oil pan. not sure yet if it's from the gasket, or from under the shifter cover. it's really more of a sweating than dripping so not too bad but i want to find the source.
also found that the bolt holding the ignition rotor on the crankshaft sticks out a bit further than with the stock setup with points, and now touches the ignition cover. it already ground its way into the cover, here around the "N":
i think i can just push this out a bit with a hammer to give it more space underneath.
another minor thing is that honda log plate on the alternator cover that's coming loose.
i might just stick it on with some heat resistant glue as i see no reason why i would have to remove it.
next is to re-torque all bolts, check tappet clearances and cam chain tension... and get a dyno appointment.
« Last Edit: January 02, 2016, 01:35:10 PM by flatlander »
Offline flatlander
Re: 1976 CB550F - nut case... stupid mistake
« Reply #266 on: August 03, 2015, 01:09:16 PM »
well this is embarassing but here we go...
checking tappet clearances, this is what i found on no. 2 intake:
yes the nut is gone!
i looked with a light but didn't see it. i'll need to take off the cover and hope for the best. i really hope it didn't go far  :-[
« Last Edit: January 02, 2016, 01:37:00 PM by flatlander »
« Reply #267 on: August 03, 2015, 02:55:43 PM »
It can be in the bottom end , via the cam chain path...
hopefully not.
Hopefully no damage and you can get it back on the road after a few gaskets and disassembly and reassembly.
David
« Reply #268 on: August 03, 2015, 04:37:13 PM »
I think if it is not resting on top of the cam/valve train, then you should pull the oil pan and hope it dropped through to the bottom.
« Reply #269 on: August 03, 2015, 08:02:04 PM »
Dont run it till you find that nut!
Was on a ride a few years back and my buddies K5 shot the nut right threw the cap!
Offline flatlander
« Reply #270 on: August 03, 2015, 10:56:46 PM »
thanks guys! yes i certainly won't run it.
i'll take off the rocker cover and hope i can find it, if not then the oil pan. if i can't find it that way then it gets tricky...
it did not come out with the oil change i just did.
the engine still ran well on the last ride so my hope is that it's resting in some "safe" place but not knowing where it went i'm still worried what it may have done!
it's morning here, i'll need to go to work so this has to wait until evening unfortunately.
Offline flatlander
Re: 1976 CB550F - found it!
« Reply #271 on: August 05, 2015, 01:04:17 AM »
got the nut, luckily it didn't go far after all. it was wedged in between the spring and the case. you may be able to make it out in the picture
the valve retainer get nicked as you can also see in the picture. i checked the valve stem and it's straight, and in line with the others (verified with a ruler). then gave it a couple of good blows with a hammer and the retainer seems to be seated well and secure. i think i can run this.
the inside of the tappet cover also got knocked but that's nothing to worry about.
was a bit tight to get out but who can resist the combined efforts of a little allen wrench and a pair of needle nose pliers?
well this was a good occasion to re-torque the head nuts. then it all went back together.
this time i made extra sure to tighten the tappet nuts really well. don't want this to happen again.
« Last Edit: January 02, 2016, 12:29:55 AM by flatlander »
« Reply #272 on: August 05, 2015, 05:08:06 AM »
Good news, crisis averted....
Offline flatlander
« Reply #273 on: August 05, 2015, 05:14:31 AM »
yes i was relieved!
thanks to everyone who chimed in with advice. i was getting worried there starting to imagine what could have gone wrong. you helped me keep a level head.
« Reply #274 on: August 05, 2015, 05:58:12 AM »
Whew! Much easier fix.
