Author Topic: turn signals that beep?  (Read 2470 times)
Offline J-Dawg
« on: October 12, 2014, 07:17:18 PM »
Stock 77 750a,  put new ignition and battery in and discovered my bike has audible turn signals....how do I make that go away please??  Is that stock feature?
Offline J-Dawg
Re: turn signals that beep?
« Reply #1 on: October 12, 2014, 08:23:33 PM »
Solution found...guess there is a buzzer below the headlight that ill be disconnecting
Offline xntrik
« Reply #2 on: October 13, 2014, 03:30:38 AM »
Don't recall exactly at 530am with little sleep.... But I'm not sure if your signals will function correctly with that removed...
« Reply #3 on: October 13, 2014, 01:01:31 PM »
Ohhhh, THAT'S a turn signal indicator?! I always thought it was a low voltage indicator.....  ;) (kidding) hey, at least it can be used for something useful.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: October 13, 2014, 02:10:14 PM »
Just follow the wires and unplug it if it annoys you. Most of them are removed at some point or another. Of the six I have I don't think any of them have the beeper. Turn signal function is not affected unless you inadvertently unplug the turn signal too.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline J-Dawg
« Reply #5 on: October 13, 2014, 04:13:40 PM »
With mine being so rare haha. Is the beeper worth money to someone?   Was it on all 77s or only hondamatic
« Reply #6 on: October 13, 2014, 07:25:19 PM »
Pretty sure all the SOHC 750's had them.
TAMTF...
Wilbur
Projects:
Offline J-Dawg
« Reply #7 on: October 14, 2014, 04:35:09 AM »
Ok...thx
Offline birdmannn101
  • My Fixerupper 73 CB750K3
« Reply #8 on: October 14, 2014, 06:27:47 AM »
It was only a turn signal beeper on the 76 and would beep after the turn if you forgot to turn off your turn signals.  On the 77 and 78 it was also connected to the speed warning mechanism which would warn you if the high idle failed to disconnect at either 17 or 27 mph.
CB110
CB160
CB750K
CB750A
S90
CB350Four
CT200
C100
C102
VTX1300
« Reply #9 on: October 14, 2014, 07:18:01 AM »
Starting with K2.
Offline spfldpianist
  • Riding again on a classic
« Reply #10 on: October 14, 2014, 09:43:08 PM »
My 76. Cb550 has them
