Author Topic: Fuel filter replacement '78 CB750  (Read 1903 times)
Offline tommychains
« on: April 26, 2015, 10:48:40 AM »
Hi guys, I believe I am looking for a replacement fuel filter (it's just behind the petcock?). The one I have (which has outlet and inlet at 90 degrees to each other) snapped where the inlet meets the cone. I am contemplating gluing it back on but would rather get a new one. I search but couldn't find any particular sites or brands recommended. I've seen a few online ranging from $3-$12..most are linear in orientation unlike the one I have. Any particular recommendations for a good fuel filter?
Re: Fuel filter replacement '78 CB750
« Reply #1 on: April 26, 2015, 11:11:47 AM »
The CB750 did not come stock with an inline fuel filter.  The PO must have added it.
There have been reports that these filters can slow fuel flow, I personally will not run one.  If your tank has rust issues, it would be best to address it.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #2 on: April 26, 2015, 11:50:22 AM »
Stev-o is entirely correct of course, you should not need an in-line filter if your tank and petcock are clean. Personally though, I do use them (mixture of OCD and peace of mind ::))and would recommend a Visu-filter if you are still planning on getting one. I haven't noticed any discernible effect on flow, but can only speak for myself of course.
http://www.power-barn.com/visu-filter-1-4-inline-fuel-filter-90-degree-angle-type/
Forget gluing your old one, unless you like the thought of a fire under your ass ;D
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: April 26, 2015, 01:42:41 PM »
The in-tank filter works for me. The new one comes with the petcock gasket, Honda part number 16952-388-015.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
