Author Topic: Fuse box  (Read 11273 times)
Offline Canadian
Fuse box
« on: April 11, 2016, 12:31:34 AM »
Here I am, yet again with a question regarding fuses.
In short:
°Main fuse keeps on blowing, nothing changed to the bike, been driving like this for a year
°Checked the wiring, no bad ground, no wire touching another one
°Battery doesn't really charge anymore, only reads max of 13 volts when running
°When she's cold I can drive up to 10 minutes, seems something is getting too hot & fuse blows
°Tried a new regulator , keeps blowing
Any tricks/ideas what might cause this ? No clue anymore , maybe rectifire.. ?
Thanks guys,
Wannes (Belgium, Europe)
Re: Fuse box
« Reply #1 on: April 11, 2016, 07:50:03 AM »
Take a look at your ignition switch.
Offline Canadian
Re: Fuse box
« Reply #2 on: April 11, 2016, 12:56:57 PM »
Sorry forgot to mention.
the box was corroded & changed it to modern fusebox, ALL works fine
What makes you think of the ignition switch ?
Thx!
Offline Canadian
Re: Fuse box
« Reply #3 on: April 12, 2016, 12:34:27 AM »
You are contract these are in contrast to each other. Indeed I've changed this to a modern one with modern fuses. No short or loose connection here.
It is an aftermarket ignition switch. But this one goes for 1 year now so don't understand why all of a sudden it would go ... anyway I'll check
Thanks!
Offline Canadian
Re: Fuse box
« Reply #4 on: April 12, 2016, 03:46:52 AM »
Hi there,
Thanks for replying. I must say i'm good at welding, mocking up stuff, making fibre seat etc but electronics is my worst nightmare.
I do have a multimeter. How do I read if this one is broken or not ? Have 3 stands (off / on / on  + lights).
When I start driving I can do about 10mins, then all of a sudden the fuse blows. The battery only reading max 13.2 volts or so worries me as well (when revving at 6000rpm).
Ofcoure something's heated too much & then I have to wait 30mins to pop another fuse in , to drive home...
Thanks again guys.
Offline Canadian
Re: Fuse box
« Reply #5 on: April 12, 2016, 04:29:28 AM »
Sound a bit Chinese but i'll manage, good explanation thx!
 I'll have a look tonight.
I'll find the 8pin plastic connector. Here I need to check the Ohms on Yellow Yellow Yellow and th White Green whires?
So put my meter on the yellow and each time check with white & green correct? What is 'too high' ?
Suppose my ignition (key) has to be ON ?
Brgds
Wannes
Offline Canadian
Re: Fuse box
« Reply #6 on: April 15, 2016, 10:02:25 AM »
Think i found it!
Measured My rectifier and :
Black of multimeter on green of rectifier
To 3 yellows: ALL around 0.5v , perfect
Black of multimeter on red of rectifier
Tob3 yellows: nothing! Nothing AT ALL
The rectifier was mounted in My seat so not much cooling.
Will Search a New one & advise outcome
Re: Fuse box
« Reply #7 on: April 15, 2016, 11:35:41 AM »
The ignition switch carries an awful lot of current! Great place for a loss.
Rectifier rectifies the AC current to DC by eliminating one of the alternating legs thus DC. Not sure about your test?
Offline Canadian
Re: Fuse box
« Reply #8 on: April 18, 2016, 10:01:17 AM »
Multimeter was broken :D!
Rectifier was good.. Anyway Changed regulator (was also good) en rectifier with New ones, that Come Off a running bike here. MeSured with a good multimeter & they are ok.
Ignition on hit My starter, Goes over a couple of times, fuse blows. First time this happens.
Pop another one in, starts & let it turn idle for 5mins, ALL ok. Measured volts on battery max 13.5 V with almost Full Throthle.
Want to drive, 200 meters and BAMMMM, done, again.
Immediately checked & tried to touch the rectifier, Can bearely touch it...
So Moving On.... Ignition coils shortage or something ? NO wire is hitting another one, ALL already checked!
Thx in advance!
Wannes
Offline Canadian
Re: Fuse box
« Reply #9 on: April 18, 2016, 10:22:01 AM »
Oh & changed the ignition lock to the original one
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Fuse box
« Reply #10 on: April 18, 2016, 10:22:58 AM »
Takes me about two weeks to clean every switch and connector in the harness. As mentioned, focus on the high amp connectors first:
http://forums.sohc4.net/index.php/topic,137351.msg1549191.html#msg1549191
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Fuse box
« Reply #11 on: April 18, 2016, 10:29:58 AM »
Don't forget the alternator connectors under the front sprocket cover. Those connections tend to suffer the most...
TAMTF...
Wilbur
Projects:
Offline Canadian
Re: Fuse box
« Reply #12 on: April 18, 2016, 11:15:02 AM »
Checked alternator connector, clean & good connection.
Pls advise on the Next step, dumb regarding electronic etc :)!
Thx
Re: Fuse box
« Reply #13 on: April 18, 2016, 11:25:48 AM »
Thx
Both sets of alternator connections? There is one multi-connector block that is above the rear of the engine, and then there are five individual bullet connectors tucked in behind the transmission cover underneath the front sprocket cover. Those five individual bullet connectors (3-yellow, 1-green, 1-white) tend to be the connectors that suffer the most...
TAMTF...
Wilbur
Projects:
Offline Canadian
Re: Fuse box
« Reply #14 on: April 18, 2016, 11:41:31 AM »
2 rectifiers are now broken, after this fuse blew
Next step? Measuring ohms On...?
Offline Canadian
Re: Fuse box
« Reply #15 on: April 20, 2016, 02:04:14 AM »
Anyone :) ?
Re: Fuse box
« Reply #16 on: April 20, 2016, 03:47:33 AM »
And what leads you to this conclusion?
After this fuse blew
Which fuse?
Everything.
TAMTF...
Wilbur
Projects:
Offline Canadian
Re: Fuse box
« Reply #17 on: April 20, 2016, 09:22:23 AM »
Measured the rectifiers ? The ohms were good First, now not any longer
The Main fuse
Everything... Pls specify on how to read/analyse My spools etc
Re: Fuse box
« Reply #18 on: April 20, 2016, 09:34:11 AM »
The Main fuse
The rectifier is a set of diodes. Current can only flow one direction through the rectifier. Did you check voltage both directions? Your ohmmeter has to push a small amount of voltage (from the battery inside the meter) in order to measure ohms. You will also get false ohm readings if your meter battery is dead.
Check my signature for link(s) to charging system diagnosis, as well as electrical system troubleshooting:
http://forums.sohc4.net/index.php/topic,1012.msg8345.html#msg8345
« Last Edit: April 20, 2016, 09:50:21 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline Canadian
Re: Fuse box
« Reply #19 on: April 20, 2016, 11:40:35 AM »
Thanks for above,
This is pretty much My problem:
http://www.xs650.com/forum/showthread.php?t=19916
Can someone tell me how to measure my alternator rotor , or how to dismount it?
Sorry for my English my mothertongue is Dutch.
The link i gave Seems 200% my problem. Mine does weird stuff around 4000rpm AS Well :D!
Re: Fuse box
« Reply #20 on: April 20, 2016, 02:09:53 PM »
What bike (make, model and year) are we even talking about?
TAMTF...
Wilbur
Projects:
Offline Canadian
Re: Fuse box
« Reply #21 on: April 21, 2016, 12:32:09 AM »
So sorry,
Honda CB550F 1977.
If I read everything in the link I've posted previously this seems 200% my problem. And frankly can't think of anything else anymore.
As told, no wires are touching somewhere, all carefully checked.
I measured the 1st rectifier and it was broken (putting black of multimeter on the red on & red of the multimeter on every yellow one, you need to read 0.5 to 0.6 ohms).
New one that I measured, all good!
Started, main fuse blew, rectifier really hot, measured and broken as well.
Now just would like to know how to measure my ohms on the alternator widings etc & how to get it off the bike...
Thanks in advance!
Brgds,
Wannes
Offline Canadian
Re: Fuse box
« Reply #22 on: April 21, 2016, 07:08:31 AM »
Hi Calj,
Yes stock rectifier & regulator. Altered the stock wiring harness, What do you mean with altered? Sorry as told native tongue Dutch...
Ok pics to follow tonight.
Thx,
Wannes
Offline Canadian
Re: Fuse box
« Reply #23 on: April 21, 2016, 11:11:46 AM »
No i havent, mean i don't Use winkers etc but are all carefully taped. Been driving like this for over a year now.
All wired doublechecked, none Can make contact, is broken,...
Offline Canadian
Re: Fuse box
« Reply #24 on: April 22, 2016, 09:45:55 AM »
Hi guys,
Measured field coil resistance, i read 4.0
Manual says 4.9 +- 10%
Guessing this is broken?
