I just picked up a 75 750f for a project, I've been driving it around a bit to get a feel for its overall condition before I tear her down this coming winter. I found that when coming to a stop and using the rear disc brake I feel it pulling a bit to the right, as if the axle is loose and and going out of alignment, that is not the problem as everything is all tight , is it possible a worn swing arm bushing is worn? Maybe the rear brake stabilizing arm is worn? Any suggestions?
