Author Topic: Japauto 1000vx build  (Read 1493 times)
Offline sanchezorr123
« on: September 02, 2020, 03:37:38 AM »
Hi, i am building a Japauto 1000vx, thats a french modified cb750 bored up to 1000 cc with special JPX cylinder block.
I had to order custom made pistons 70mm diameter and now i am not sure the correct orientation of the piston. They have an arrow on the top that it is suposed to point to the exhaust but i am not sure, because the shape of the valve gap on the piston head.
So i apreciate any help.
Sorry for my poor english, its dificult to express my self. Hope it can be understood.
« Last Edit: September 02, 2020, 06:56:43 AM by sanchezorr123 »
Re: Japauto 1000vx build
« Reply #1 on: September 02, 2020, 03:42:59 AM »
Sorry, this is the right picture of my engine.
Online MRieck
« Reply #2 on: September 02, 2020, 08:02:06 AM »
Those pistons can go in any cylinder
« Reply #3 on: September 02, 2020, 08:50:29 AM »
I know that the piston can go in any  cylinder. My dubut is if it goes with the arrow pointing to the ex side or the intake side.
And i also know that the arrow is suposed to point to the EX side of the engine but the gap inn the piston head is what is confusing me. It seems that the intake gap wich clear the intake valves is smaller than the EX gap as i have mounted them with that arrow pointing to the front.
Thank you.
Online MRieck
« Reply #4 on: September 02, 2020, 11:24:27 AM »
 Sorry about misunderstanding. The arrow does look like it is pointing to the intake valve relief. For reference here are JE piston instructions
http://www.dynoman.net/engine/pistons/piston-install/68-70mmF2.pdf
It doesn't matter that the instructions are for the F2.....same valve placement.
 And yes.....the arrow should point to the exhaust side.
« Last Edit: September 02, 2020, 11:27:12 AM by MRieck »
« Reply #5 on: September 04, 2020, 12:10:20 AM »
Ok, so looking that JE instructions seems like my pistons are mounted backwards and the manufacturer did put that arrow in the wrong side.
Lets see if anybody else have other sugestion before i turn those pistons 180º
Thanks a lot for your help
Offline jgger
« Reply #6 on: September 04, 2020, 05:34:07 AM »
My guess, and only a guess is that the exhaust relief would be deeper because that valve is open as the piston approaches TDC. While on the intake side the valve is just beginning to open  after TDC. I base this on my feeble understand of how valve timing is related to stroke and Piston position. THIS IS ONLY MY $0.02.
« Last Edit: September 04, 2020, 05:35:39 AM by jgger »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: September 04, 2020, 05:43:21 AM »
Can you contact the custom piston manufacturer for clarification? If anyone would know, they should know for sure.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Old Scrambler
« Reply #8 on: September 04, 2020, 11:21:16 AM »
I'm with jggr..............measure the width of the intake valve-pocket.....it appears to be wider to accommodate a larger valve.......Yes, on the overlap the rising piston is literally chasing the exhaust valve when a long-duration cam is installed with narrow lobe-centers.......wide centers tend to bring the piston 'real close' to the intake valve.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Scott S
« Reply #9 on: September 04, 2020, 12:01:52 PM »
 Why does the one relief have that little notch in the middle? Won't a valve hit that? Almost reminds me of a dual intake valve set up.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #10 on: September 04, 2020, 06:49:28 PM »
I pulled these out of a CB750 engine I rebuilt, though I deemed them unusable because of the scoring I uncovered after cleaning them. Similar looking reliefs but the arrow was pointing to them and were installed pointing to the exhaust side.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
« Reply #11 on: September 07, 2020, 01:02:06 PM »
Ok, it seems to me that the relieve on your piston is in the opposite side than mines. But what is supossed to be the exhaust relieve in my piston, the one is pointing the Arrow looks deeper  wich should be for the ex.
I also should say that my pistons are made so it fit the F2 larger valves.
Sorry,  i am so confused And very hard to express my self in english
Thanks fot your help
« Reply #12 on: September 07, 2020, 01:07:46 PM »
In the Honda workshop manual you can find the pistons mounted either the arrow pointing to the EX and also pointing to the IN in different ilustrations.
« Reply #13 on: September 07, 2020, 01:23:49 PM »
I like to share those pictures of my engine.
« Reply #14 on: September 07, 2020, 08:45:54 PM »
Don't worry about the middle of the double notch it works like this.
 The valve will centre over one side... OR the other. .
 If they did not have the double notch, they would then be right side and left side and it would matter where they went..
