Author Topic: Front brake switch needed, 1978 750 four K  (Read 622 times)
Offline Ohio
« on: October 15, 2020, 06:17:19 AM »
I am completely new to bikes. Classic cars are my thing so this is my 1st time working on a bike. I have a 78 with the round reservoir master cylinder. My front brake light switch is missing and from what I have ascertained it would be in the lever. I did not see a hold for mounting one but until a little while ago wasn't even sure where the switch was located on the bike. Can anyone here point me to what switch to buy and if I need anything else to mount it? Many thanks and sorry for such a basic question. The diagrams I have looked at so far are a little confusing
Online bryanj
Re: Front brake switch needed, 1978 750 four K
« Reply #1 on: October 15, 2020, 06:23:39 AM »
Go to cmsnl.com and look up your particular year bike from cc and year.
You will find the microswitch probably listed with the master cylinder and get a part number for the switch and tiny screw.
I could do it for you but there are going to be more parts you need.
There should be two swall wires with small spade connectors on hanging from the rh switch that go to the micro switch
Offline Ohio
« Reply #2 on: October 15, 2020, 10:33:25 AM »
Thanks, I was on that site and found a switch but have no idea what else I need to install it. My handbrake lever has nothing on it. The wire for the brake inside the headlamp is sheered off
I guess I'll order the part and figure it out from there
Their diagram lists a clutch switch #9 and nothing on the brake lever
https://images.cmsnl.com/img/partslists/honda-cb750k8-four-1978-usa-handle-leverswitch-cables_bighu0057f5703_0806.gif
« Last Edit: October 15, 2020, 10:39:40 AM by Ohio »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Online bryanj
« Reply #4 on: October 15, 2020, 12:29:03 PM »
On that picture part 1 is the brake light switch and the screw is just below it.
The clutch switch is totally different and associated with the starter safety circuit
« Reply #5 on: October 15, 2020, 04:45:02 PM »
78 was the first year to use that, if it was a 77 build it may not take that, and can use the older style parts, which had a junction on the lower triple tree.  77 and earlier had a notch on front of tree and a bolt hole.
 So check  if your master cyl is switch type, and if your triple tree is notched or not.
