Author Topic: 1978 cb750f killswitch blows main fuse when turned to on.  (Read 1862 times)
Offline Rydog400f
« on: November 29, 2020, 09:56:36 AM »
Hey all, I've been having trouble tracking down an issue with my killswitch. The main fuse is blown ONLY when the switch is turned to on position. When it's off everything works without blowing the fuse including the starter button. I've checked continuity at the switch and it seems to be working properly. Any help is greatly appreciated!
Offline BenelliSEI
  • 1969 cb750
Re: 1978 cb750f killswitch blows main fuse when turned to on.
« Reply #1 on: November 29, 2020, 10:22:52 AM »
That would suggest there is a dead short somewhere on the down stream side of the switch. I’d start by pulling out the wiring diagram for your bike and follow it along. Test every connection to ground? And see what is bare or grounded. Start with the two power leads to th coils.
« Reply #2 on: November 29, 2020, 07:29:44 PM »
The black wire with the white stripe is the "output" side of the kill switch, and connects to both black/white coil wires. What is the background story? Is this bike new to you, or have you had it for a while and this is a new problem? If it is a new problem, have you been messing with the coils or pulling wires through the handlebars?
Offline Rydog400f
« Reply #3 on: November 30, 2020, 08:30:04 AM »
The bike is at the end of a full rebuild and I just put the original coils back on. The bike ran before I tore it down for the rebuild. I'm not sure if it's the coils or something else. I can't find any bare or touching black/white wires. It has a new wire harness as well. Thanks!
Offline Rydog400f
« Reply #4 on: November 30, 2020, 09:14:11 AM »
No bare wires that I can see. It's a new harness. What should I be looking for at the coils?
« Reply #5 on: November 30, 2020, 09:50:42 AM »
If the aluminum brackets the coils mount to are not orientated correctly, the bracket can touch the coil primary wire. For a quick test, disconnect the blk/wht wire from the coils and see if the fuse still blows; if it does, the problem is somewhere between that point and the switch.
Offline Rydog400f
« Reply #6 on: November 30, 2020, 10:25:57 AM »
I'm at work now but I'm almost positive it blows the fuse when the coils aren't connected.
« Reply #7 on: November 30, 2020, 10:51:06 AM »
If the fuse still blows when the black/white wire is disconnected from the coils, unplug the switch from the main harness and measure the resistance from the blk/wht wire to frame ground; it should be an open. If there is a low resistance, the soldered wire inside the switch may be shorting against the handlebar.
Offline Rydog400f
« Reply #8 on: November 30, 2020, 08:39:49 PM »
Just checked it and there is zero resistance. Also confirmed that the fuse blows with coils disconnected.
Offline BenelliSEI
  • 1969 cb750
« Reply #9 on: December 01, 2020, 05:13:07 AM »
So..... with coils disconnected, ignition key switch “ON”, fuse blows as soon as you switch on the three way “kill switch”? If so, there is something going to ground when you rotate that switch. Anything else hooked up to that power lead to the coils?
Offline Rydog400f
« Reply #10 on: December 01, 2020, 08:06:29 AM »
Correct. I'm wondering if the switch has to be grounded to the handlebar to work? If I remove it from the bar should the switch still work? That might show if something is grounding to the bar.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #11 on: December 01, 2020, 08:45:58 AM »
No. Follow the diagram:
http://manuals.sohc4.net/cb750f/technical_reference/WD750F_78.jpg
I'll wager that when you installed the new harness you got something wrong. I'm guessing a black to green somewhere or there's a black wire pinched and shorted to ground.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #12 on: December 01, 2020, 08:55:33 AM »
Looking at the diagram, the only thing connected to the engine stop switch is the coils. Carefully check the wire from the switch to the point of connection to the coil wire connection in the headlight bucket. Disconnect the engine stop switch completely by disconnecting both the black and the black/white leads and check continuity through the switch in both the on and off positions between those two leads. Then with the switch still disconnected check for continuity between each lead and ground (first the black and then the black/white or vise versa) in both positions for both wires to the switch in order to determine if it's in the wires to the switch or the switch itself. Chasing electrical gremlins often requires determining what it's not.
TAMTF...
Wilbur
Projects:
Offline Rydog400f
« Reply #13 on: December 01, 2020, 09:26:09 AM »
Thanks, I'll check when I get home. The killswitch for the 78 has a plug so I don't think anything is connected wrong. So far I know the continuity for the switch works properly on the plug end. None when it's switched to off and good continuity when its switched on.
« Reply #14 on: December 01, 2020, 10:09:49 AM »
With the plug disconnected check the switch leads for continuity between each lead and ground with the switch in both the on and off position. Since the fuse only blows when switched to "On" I'm guessing the black/white wire between the plug and the switch is pinched and shorted.
TAMTF...
Wilbur
Projects:
« Reply #15 on: December 01, 2020, 10:14:56 AM »
When you disconnected the coils, where did you disconnect at? At the connectors right at the coils? If so, the black/white wire between the engine stop switch connector and the connector at the coil could also be the culprit. It sounds like it's somewhere in the black/white between the switch and the connector you used to disconnect the coil. There's a slim possibility that it's the actual switch, but testing for continuity to ground at the switch connector will help determine whether that is the case.
TAMTF...
Wilbur
Projects:
Offline Rydog400f
« Reply #16 on: December 01, 2020, 10:50:10 AM »
Yes I disconnected the black/white wires at the coils.
« Reply #17 on: December 01, 2020, 11:11:48 AM »
The blk/wht wire is shorting to the handle bars. Remove the switch from the bars and look for where it's touching.
« Reply #18 on: December 01, 2020, 11:12:20 AM »
Offline Rydog400f
« Reply #19 on: December 01, 2020, 11:36:52 AM »
Thanks I'll check again tonight. I've checked once already and didn't see it touching but I may have missed something.
« Reply #20 on: December 01, 2020, 06:51:42 PM »
With the switch removed from the bars, check for continuity from the blk/wht wire to the switch housing; if none, look for any signs of arcing on the bars below where the switch mounts.
I see you're in SLO town. I lived there when I bought my SOHC in 1979. ;D
« Last Edit: December 01, 2020, 06:58:41 PM by scottly »
Offline Rydog400f
« Reply #21 on: December 01, 2020, 08:12:40 PM »
That was it! My horrible soldering job was touching the housing. Bent them off the housing and no more blown fuse! I checked by removing the switch from the bars and checking if it would blow the fuse. It didn't. Thanks SLOCAL!
« Reply #22 on: December 01, 2020, 09:07:22 PM »
 ;D ;D ;D
