Author Topic: Early Sandcast Found......  (Read 161403 times)
Re: Early Sandcast Found......
« Reply #450 on: October 28, 2021, 12:07:43 AM »
Eastwood internal exhaust coating W/ hose and nozzle, one can will do a set of 4. I tape the end I'm not using and be careful it will pour out of the drain hole or the end you're not using. I roll and rotate to spread it everywhere.
Where did you buy it??
« Reply #451 on: October 28, 2021, 01:05:27 AM »
Eastwood sells it...search for Eastwood on web
« Reply #452 on: October 28, 2021, 09:27:40 AM »
 I have my doubts whether you could get a used exhaust clean enough on the inside for it to stick. I after it's dry I bake it with a hot air gun blowing through the pipe.
https://www.eastwood.com/eastwood-hi-temp-internal-exhaust-coating-w-nozzle.html
« Last Edit: October 28, 2021, 06:41:15 PM by Don R »
« Reply #453 on: October 28, 2021, 01:03:42 PM »
Depending on the length of the pipes, you might be able to sandblast the inside of the pipe first.
« Reply #454 on: October 30, 2021, 12:31:10 AM »
Don't worry about trying to paint the insides of used pipes, just run some premix two stroke fuel through your bike for a tank full or two. The fuel won't hurt your bike, but the oil will mist thru your exhaust system and leave a protective coat. Do it before you park it up for winter and the wet acids in your pipes won't rot your exhausts out. ;D
« Reply #455 on: October 30, 2021, 03:56:08 AM »
Terry..... for this treatment, how much 2 stroke oil would you add to a full cb750 fuel tank?
« Reply #456 on: October 30, 2021, 06:39:59 AM »
I guess while I have the pipes off before installing them, I'll coat them with some oil and let them drain into a bucket.
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #457 on: October 30, 2021, 06:58:09 AM »
For real? That’s cool, never heard of that.
Online PeWe
« Reply #458 on: October 30, 2021, 08:06:38 AM »
That must be the easy way doing it.
I oiled 2 sets of 4-4 when new with oil I hade mixed with naphta to make it flow easier. Around 2 deciliter in each pipe I rotated and flipped so oil could cover everywhere.
I hope it will work.
The climate is not that humid here.
Only late autumn and early spring with colder weather condense will spray a little out of the pipes.
« Reply #459 on: October 30, 2021, 08:33:26 AM »
 I use a half oz to an oz. of Amzoil 2 stroke marine oil or so in a tank re-fill. I do that for the gas tank but figure it won't hurt the pipes either.
   The Eastwood's coating also adds another layer of protection from heat in the head pipes. A local chopper builder used to run the cylinder rich for a while on every new build to coat the inside with carbon to keep them from turning blue.  I'd bet he didn't think of 2 stroke oil.
« Reply #460 on: November 01, 2021, 07:50:43 AM »
Thanks Don. I’ll try this on my “last tank”, in the next few weeks.
« Reply #461 on: November 13, 2021, 02:03:11 PM »
Was at a swap meet last week, in Peterborough, ON. All Harley stuff, but one guy had a box marked “Honda Bits”. Found a really good, early style seat latch (the kind with the metal hook for a safety) and a completely rust free set of instrument straps. $10! It was a nice day to ride the K1 too......
« Reply #462 on: November 13, 2021, 04:55:19 PM »
Nice. And sorry for not answering sooner, but yep, just mix a weak tankful of 2 stroke fuel (50:1 should do it) and run it thru your bike now and then to keep the pipes coated with an oil mist. Don't try to coat them with anything else afterwards, as it probably won't stick. ;D
« Reply #463 on: November 16, 2021, 06:59:37 AM »
Terry.... will do. Thanks.
« Reply #464 on: December 15, 2021, 09:00:47 AM »
Working on my g’son/son’s Z50 this morning (my son leaves his broken toys here and they miraculously heal themselves) and got distracted.....
Finished dismantling the S/C front forks. They definitely need new tubes, seals, gaiters etc. I need to get the lowers out to my local polisher. I’ll include the front hub and then I will have enough stuff to assemble the front end, install a wheel and tire, and get it up on a table. Probably not before Christmas, but moving again.
I was determined not to spend “summer hours” in the shop. Didn’t, so not much got done for the past 6-7 months.
« Reply #465 on: December 15, 2021, 10:08:43 AM »
 I hear you about summer hours. I solved it by dragging stuff outside.
« Reply #466 on: December 16, 2021, 06:00:23 AM »
Don..... started some real “Farming” and still managed 5 X double header endurance races, during the good weather. I’ve decided the projects can just take a bit longer!
« Reply #467 on: December 16, 2021, 09:11:28 AM »
Found a “paintless dent removal “ guy in Toronto, with excellent feedback. Going to let him take a shot at the original wrinkle tank….. Fingers crossed!
« Reply #468 on: December 16, 2021, 04:28:00 PM »
That should be any easy fix John, no real creasing, I'll be interested to see the result. ;D
Offline 34barab
« Reply #469 on: December 16, 2021, 05:28:42 PM »
Don't mean to disrupt this thread, but I have a question.  If John's tank had a crease, how would it affect a repair?
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
« Reply #470 on: December 16, 2021, 05:42:42 PM »
A crease usually implies the paint is cracked or broken. Even a skilled body man will still have the paint/primer pop away and break, as soon as he pulls and pushes the steel. If it’s intact, with a bit of warmth (and skill) it will come back out and polish up nicely. The other side has a “ sharper” ding that may be more of a challenge…….
« Reply #471 on: December 16, 2021, 06:46:01 PM »
PDR generally cannot work out a crease as the metal usually stretches some with a crease.
A really good PDR guy can do magic as can a body man who isn’t a plasterer… Good body work is expensive as is a good PDR guy. Any PDR work is costly, but usually cheaper than repaint work. Finding someone good with vintage tank or tanks in general is tough… many oversell their abilities.
« Reply #472 on: December 22, 2021, 12:14:33 AM »
John,did the dent repairman have a go at your tank ?
« Reply #473 on: December 22, 2021, 07:03:55 AM »
No. He’s in Toronto (I’m 60 miles N.E.). Probably early in the New Year. I want to meet the guy, check out his shop, etc. Will post updates.
« Reply #474 on: December 29, 2021, 08:35:26 AM »
  My replacement K0 fork tubes seem a bit oversize. Watch out for that when tightening the top triple. I can't draw the D washers up tight.
