Author Topic: I cant figure out what this hose connects to  (Read 1688 times)
Offline JamesHeller
« on: June 08, 2021, 11:23:35 AM »
And i feel like something dumb is keeping me from being done and riding this bike already :'(
78 Honda Cb750K
Offline goodtryer
Re: I cant figure out what this hose connects to
« Reply #1 on: June 08, 2021, 11:26:12 AM »
Possibly the overflow drain from the fuel tank.
Or maybe the recycle connection from the valve cover to the airbox.
What bike?
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline Alan F.
« Reply #2 on: June 08, 2021, 11:34:16 AM »
78 750F was in his intro thread. James if you put which bike you have in your profile signature, it'll be included with every post you make.
Are you sure it's a 750F? I thought those had blacked out engines...
Is there already a hose connected here?
« Reply #3 on: June 08, 2021, 12:02:24 PM »
If it’s not long enough to reach the back of the Cam cover, it’s the one to the airbox drain.
« Reply #4 on: June 08, 2021, 12:23:53 PM »
Crankcase breather and connects to oil separator i thik
Online madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: June 08, 2021, 12:52:57 PM »
It appears to be connected to the vapor/moisture separator under the battery. The other end of this hose would connect to the top of the air cleaner. The vapor/moisture separator should also have a hose connected to the valve cover as well as a drain hose that wraps around the front of the swingarm before routing to the rear.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline JamesHeller
« Reply #6 on: June 08, 2021, 01:09:50 PM »
Yes it is
78 Honda Cb750K
Offline JamesHeller
« Reply #7 on: June 08, 2021, 01:10:52 PM »
Thats what i had been thinking but wasn't 100% sure
78 Honda Cb750K
Offline JamesHeller
« Reply #8 on: June 08, 2021, 01:12:35 PM »
What is the best thing to do with it now you think cause
78 Honda Cb750K
Online madmtnmotors
« Reply #9 on: June 08, 2021, 01:20:26 PM »
"cause" what? Because the air cleaner has been jettisoned? If so, then all you can do is stick a filter on the end and vent to atmosphere. DO NOT PLUG THIS BREATHER HOSE. The crankcase pressure must be vented. You could eliminated the breather canister completely and stick the filter on the end of the breather hose from the valve cover would accomplish the same thing.
« Last Edit: June 09, 2021, 04:20:39 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline Alan F.
« Reply #10 on: June 08, 2021, 03:03:08 PM »
Is this your bike?
Why do you think it's a CB750F?
« Reply #11 on: June 08, 2021, 05:40:19 PM »
Should know what bike you have.  F models and K models are both Four cylinder.
Cheers!
Offline JamesHeller
« Reply #12 on: June 22, 2021, 11:25:11 AM »
Is this your bike?
I has cb750f on it and also Cb750K so i was lost and my grandfather had completey for got which one it was but it is a K model
78 Honda Cb750K
« Reply #13 on: June 23, 2021, 06:56:29 AM »
Is this your bike?
78 750 Four is different than the question is it the F model or the K model. F model is the Supersport.
When you ask a question please include the model and year in each new question topic. It avoids confusion.
K model specs and picture
https://www.motorcyclespecs.co.za/model/Honda/honda_cb750k7_77.html
78 F model Supersport in the picture. Notice the differences
