Author Topic: Front sprocket question  (Read 414 times)
Offline jmd10259
« on: December 28, 2024, 06:46:53 PM »
On my 1977 Honda CB 750F, I've noticed the front sprocket being held by a single bolt with correct flat washer has some play on the output shaft. Enough I can wiggle it around a bit and rotate the sprocket on the the shaft backwards and forwards a small amount. The sprocket is brand new 15 tooth. The original 14 tooth was the same as far as play goes. Should I worry about this or is it considered normal? 18k miles on bike with 630 chain. Thanks for the knowledge and help.
Re: Front sprocket question
« Reply #1 on: December 28, 2024, 07:06:26 PM »
I think 15 teeth was stock? The new sprocket should be flat on one side, and raised on the other side. What does yours look like?
« Reply #2 on: December 28, 2024, 07:39:34 PM »
New Honda one are usually tighter than new aftermarket ones..
Some used Honda’s are still tighter than aftermarket’s…🤪
« Reply #3 on: December 28, 2024, 08:08:05 PM »
This is what the correct 15 tooth 630 sprocket looks like on the counter shaft; notice that the end of the shaft is about flush with the surface of the sprocket; if the end of the shaft sticks out past the sprocket, the sprocket is too thin. NOTE: the raised side of the sprocket is supposed to face inwards, not outwards like in the pic.
« Last Edit: December 28, 2024, 08:10:29 PM by scottly »
Offline jmd10259
« Reply #4 on: December 28, 2024, 08:27:33 PM »
Oh damn the raised portion of my sprocket has been facing outwards since I've owned it. 3 years now and about 3k miles put on. But if the correct way is inwards I'll flip it around and try that. But should I have any play? I had a very thin washer made up that allows the sprocket to fit tight and it does, it's just that it's on backwards haha. Thanks for the heads up!
Offline jmd10259
« Reply #5 on: December 28, 2024, 08:35:38 PM »
Actually Scottly, stock front sprocket is 14 teeth, rear is 43. Going to a 15 dropped my hwy rpm about 500. I've been to 80mph once on this bike lol. I'm an older guy and have no need for speed any more.
« Reply #6 on: December 28, 2024, 09:08:23 PM »
I stand corrected. ;D
« Reply #7 on: December 29, 2024, 03:54:17 AM »
As to the play, that is normal to have a bit of play.
You asked that on fb?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #8 on: December 29, 2024, 02:47:35 PM »
A little bit of freeplay is normal. Raised shoulder facing in.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
