Author Topic: Rescuing a '78 CB750F SS  (Read 8287 times)
Offline toomanybikes
« on: April 30, 2025, 05:23:48 AM »
Latest project (my third SOHC/4, umpteenth vintage rescue) is a '78 750F SS, recently posted in the new members forum, even though I'm not a new member ... oops
Low mileage and relatively unmolested, my plan to to make it roadworthy and as original as practical. Aside from the usual tire, tank crud, battery, chain, carbs, brakes, etc. the know issues are:
1. some rattle can touch up paint has locked in the oil filter housing bolt, which was then mangled
2. The RH/taller post in carb#3 is damaged. The float pin is still in place, but there's not much material holding it in. Still too much varnish to determine if it's salvageable.
3. Low beam not working in headlight
4. Muffler has some damage, but still functional
Some pics for fun.
current stable, always subject to change ...
'22 MG V85TT
'19 Triumph Scrambler XC
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
Offline denward17
Re: Rescuing a '78 CB750F SS
« Reply #1 on: April 30, 2025, 05:34:17 AM »
Following for updates....
« Reply #2 on: April 30, 2025, 07:45:40 AM »
Nice find.
On that oil filter bolt, Honda made two sizes, you might want to find the larger one for a replacement.
« Reply #3 on: April 30, 2025, 08:41:51 AM »
Nice find.
Agreed. The aftermarket bolt from 4into1 (and others) looks to have a 17mm bolt head. That's what I ordered.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #4 on: April 30, 2025, 08:46:54 AM »
Nice find.
Good.
BTW - be cautious about cheap parts from 4into1, we're hearing many reports that a lot of the parts are china crap [the bolt will be fine].  Their aftermarket carb kits will make tuning your bike next to impossible.
Online PeWe
« Reply #5 on: April 30, 2025, 08:55:18 AM »
That bike looks like an almost new bike parked and forgotten for decades or a recently restored one ;)
« Reply #6 on: April 30, 2025, 10:29:19 AM »
Thanks. It's not recently restored. The previous owner bought it used in 1980, rode it some (12K miles on the clock), then parked it in ~2015.
The rattle can touch up is a minor bummer, but they did a reasonable job, keeping it away from the exhaust, carbs, etc. You can see traces on the tappet covers, spark plugs, and a few other spots. Not sure how the carb float post was busted. It's not clear if anyone has been inside the carbs before.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #7 on: April 30, 2025, 10:31:55 AM »
Nice find.
Good.
Yep, I'm familiar with questionable quality of cheap carb kits. Biggest challenge on other projects has been the float valves. Jet's are almost always re-usable and quality orings can be sourced. I'll be taking the carbs apart this weekend and will know more then.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #8 on: May 01, 2025, 02:06:53 PM »
Careful when you buy a replacement for the oil filter bolt. A while back people were reporting the relief valve is assembled backwards in some of the cheaper versions. I checked a few I got with a project bike, and they seemed OK.
« Reply #9 on: May 02, 2025, 03:17:23 AM »
Will do. I'm still trying to get the current frozen one off. It's being ... ahem ... stubborn. Dremel in s slot, use my super strong screw driver with 8mm square shaft, vice grips, padded gloves ... still no joy.
I'll probably have to cut a perpendicular groove then try to destroy the bolt's flange to allow the filter housing to pass over it. Not yet sure if the filter housing will be salvageable.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #10 on: May 02, 2025, 03:35:28 AM »
If you have a welder(or know someone with a portable welder), weld a nut to the end of the bolt to put a 6 point socket on to unscrew it. The welding should help loosen the tightness too.
« Last Edit: May 02, 2025, 03:36:59 AM by newday777 »
« Reply #11 on: May 04, 2025, 06:53:32 AM »
Didn't have welding skills or friends with said skills, so I opted for the brute force/destructive maintenance approach. Now to source a replacement filter cover.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #12 on: May 04, 2025, 07:46:26 AM »
Whatever works!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #13 on: May 04, 2025, 08:01:53 AM »
You are spot on with the rubber tipped float needles being one of the weakest links. Honda float needles are the best, although I have had very good results with K&L float needles as far as their resistance to ethanol laced fuel. I had 4 into 1 carb kit rubber bits begin to swell and disintegrate within a week of exposure to ethanol laced fuel. Sitting at a stop light I started to smell fuel only to look down at the increasing puddle of fuel beneath the bike threatening to invoke my best impression of "Ghost Rider"! Pulling the carbs back apart revealed all of the rubber bits (including bowl seals) were swollen and distorted from ethanol exposure.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #14 on: May 04, 2025, 10:38:21 AM »
You know to watch for the thin washer that sticks to the filter and the spring on the backside of the filter?
Online PeWe
« Reply #15 on: May 04, 2025, 11:49:01 AM »
That washer can follow the old filter into the bin.  Don't ask me how I know ;D
« Reply #16 on: May 04, 2025, 12:45:33 PM »
I do know to look for them, but alas, there was neither washer nor spring. Maybe that's why the bloody thing was stuck in the first place and maybe that means the filter wasn't fully doing it's job. We'll see.
And looking at the filter, I don't see how a a spring would have fit, just not enough space. Maybe the PO used the wrong filter and tossed the spring&washer. I'll check tomorrow.
« Last Edit: May 04, 2025, 03:13:49 PM by toomanybikes »
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #17 on: May 05, 2025, 06:49:53 AM »
I may have a spare...
Offline Dime
« Reply #18 on: May 05, 2025, 01:20:37 PM »
If you are stuck for a cover and bolt let me know. I am going with a spin on filter and have no need for either. Just pay postage. Pm works best as I don't get notifications easily. Cheers
Sent from my SM-S721W using Tapatalk
« Reply #19 on: May 05, 2025, 03:54:33 PM »
Thanks, I'll keep that in mind. I'm planning to meet a guy on Friday for some carbs. He also has multiple spare engines, so I'm sure a filter cover can be found. I already bought the bolt from 4into1.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #20 on: May 24, 2025, 06:20:49 AM »
Be very careful of what you buy from 4into1.com.
They sell cheap replicas that aren't correct in thread sizes and quality materials. I bought stainless steel brake hose kit from them and the banjo bolts are cheap pot metal that broke way to easy. The same thing with their cables, the lock nuts on the adjusters had too big thread diameter and stripped out tightening them.
They have poor customer service when things go wrong with their products blaming the customer.
Online PeWe
« Reply #21 on: May 24, 2025, 06:47:22 AM »
4-1 pilot jets for CB750 are wrong too. Too tight and brake inside. I had to pull carbs and drill the brass debris out with a 2.0mm drill. 2 snapped, drilled all holes so all are equal. Hole might have been very little smaller. Maybe alu oxide thick only.
« Reply #22 on: May 24, 2025, 11:14:52 AM »
+1 on the K&L aftermarket float valves with ethanol (and butane) in the gas.
Does yours still have the "oil cooler plate" behind the oil filter? I can't quite tell from the pix. That version requires the extra-long oil filter bolt, and often weeps, so many get tossed.
If the O-ring in the filter housing isn't Honda's own, it barely seals (or weeps). You can get Honda's version from them, still. It is 1mm thicker than the ones found in oil filter 'kits', most of which have the thinner O-rings used in Kawis and Suzys. Many of these bolts got too tight because of owners trying to stop the weeps that are caused by the too-skinny big O-ring in the kits.
« Last Edit: May 24, 2025, 11:20:21 AM by HondaMan »
« Reply #23 on: May 25, 2025, 03:50:39 AM »
No weeping so far. The design on the SS is weird, with an oil filter base between the filter cap and the engine. Means you need two of those large orings.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #24 on: May 25, 2025, 06:28:59 AM »
The filter base, is actually a mini oil cooler extension.
Yes you need 2 of thr big Honda orings for the filter and the base.
I got inspired by this thread to get going on my 78 F3, it's been setting up on the lift, so I took apart the rear brakes for a rebuild as both the master cylinder and the caliper have leaked in the past. I've had to order a mc kit and a caliper piston(pitted...). I had the seals already knowing the brakes needed attention.
