Author Topic: Lets see your SOHC bike out on the road!  (Read 1671684 times)
Offline Davez134
« Reply #7750 on: March 25, 2020, 05:23:29 AM »
Wow, poor folks in Las Vegas. Too bad, so many jobs at stake everywhere.
Also, very nice bike, can you post some stuff up about it and how it came to be so nice? How about a thread?
We'd all love the distraction.
Thank you! The thread is in the bottom of my signature "K2 start from scratch." Yeah, we are going to take a hard hit from the strip being shut down. Probably makes up 50% of our economy.
Offline Davez134
« Reply #7751 on: March 25, 2020, 05:27:42 AM »
Nice pic Dave! So are all the casinos closed? They have all been closed here as of today, along with all "non-essential" services, including gyms, theatres, pubs, clubs, and restaurants can only serve "take away" or "home deliveries". The big shopping centres are open though, I'm "working from home" but the system isn't working, so I might wander off to get my Henry Abe wheels blasted  and see if I can buy some sugar somewhere, to make a batch of ginger brew. I've got a freezer full of meat, a fridge full of booze, and the wife's "Clive Cussler" book collection for toilet paper, so I'm making out like a bandit! ;D
All the properties are closed yeah. Sounds like we are doing the same with all the other services you mentioned too. I have been prepared for a while now. Not for this necessarily, but something like a major power outage or natural disaster. I built a gym in my shop, have plenty of food/water. Have solar panels, a generator, propane etc. I still am able to go to work like normal at least.
« Reply #7752 on: March 25, 2020, 06:24:27 AM »
I did it!
Outside the City Hall, in Belfast, N Ireland having ridden 24,000 kms from Belfast, South Africa.  ;D ;D ;D
Congrats!     Anyone who hasnt read his blog, should.  Link is on his sig.
Offline Erny
« Reply #7753 on: March 25, 2020, 07:18:48 AM »
I did it!
Wau, big congratulation!
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
« Reply #7754 on: March 25, 2020, 09:49:16 AM »
I did it!
Wow! What a ride, a real adventure!
-You solved the charging/ battery issue?
My K6 charging LED started to flash overcharging last year. Adjusted regulator screw, still flashing.
I had planned to take the first ride of the year last week on that bike, battery too weak for starter despite charging. Installed new battery a few days later
The ride today, voltage too low now ~13.5V max. I have a LED voltage meter too.
When back home adjusted the regulator back to how it has been since 2014 when I serviced  it. Hopefully hitting 14.4V max next ride. GEL battery.
The sudden overvoltage must have been the battery that started to throw in the towel.
All adjustment/measurement on regulator must have a good and fully charged battery. Before only text in an instruction for me to follow, last year practical experiences.
« Reply #7755 on: March 25, 2020, 09:56:26 AM »
2020 Premiere! Nice weather after work +10C and sunshine. 60 km ride. Stopped at a popular cafeteria in a horse center in a small village called Strömsholm.
Hey PeWe...looked it up, the Palace looks very majestic!
https://www.spottinghistory.com/view/940/stromsholm-palace/
Next time, Swedish girls please!
That is very close to where I took the photo, about 1 km. Nice place with a creek/river flowing beside it.
I'll take a photo there next time.
Plus be prepared for nicely shaped female horse riding trousers. Hopefully riding boots too. Plan B, a horse....
My K6 next time.
EDIT:
I noticed that the ride was 87km.
Stev-o,
Next time happened today!
I was too late to catch the horse when it was close with a female on it behind me.  Too busy to look at my bike :D
A bad photo against the sun. Horse visible. I'll add much better later this year. Total 78km ride.
« Last Edit: March 25, 2020, 10:00:00 AM by PeWe »
Offline Erny
« Reply #7756 on: March 25, 2020, 10:06:06 AM »
I did it!
PeWe - to your overcharging issue - I had the same on my K7 - root cause was drop of voltage on black wire connected to regulator. In my case, drop was bigger than 2.5V (for example battery was 14, on regulator only 11.5). Logically regulator seeing such low volatge was increasing voltage on alternator field coil to charge max. At the end I had more than 15V o battery...
I investigated all possible connection and my conclusion is that there is "cold" junction somewhere inside main wiring loom between headlight shell and point it exists at regulator. If you look inside wiring diagram, you can see several junctions inside on the black "line". I already have similar experience from 550 K1, where I found 2 totally "corroded" junctions inside loom on the black line (http://forums.sohc4.net/index.php/topic,176018.msg2048272.html#msg2048272). This can behave differently under load/temperature... My K7 was working fine for first minutes of ride and the started to overcharge.
So what I did was to run a dedicated new "black" line (via relay) that is connected to regulator and also dedicated line to feed headlight to offload black line.
Now it works fine (but tested only for few km)
Replacement of whole loom would be ideal, but I prefer to keep stock original on the bike than any aftermarket alternative
« Reply #7757 on: March 25, 2020, 11:09:39 AM »
There is no overcharging now.
That connectivity issue with too low voltage to regulator is good to know, though.
Main harness is old but all plugs recrimped 2014. Charging harness new from Yamiya 3 years ago.
Offline Erny
« Reply #7758 on: March 25, 2020, 11:52:59 AM »
This is the point - issue is inside wiring loom - junctions... There are 5 in my K7!
« Last Edit: March 25, 2020, 12:05:16 PM by Erny »
« Reply #7759 on: March 25, 2020, 12:35:00 PM »
Stev-o,
Palace looks majestic!  Thanks
« Reply #7760 on: March 25, 2020, 07:10:32 PM »
I did it!
Good job! ; D
Offline scunny
  • don't call me expert
« Reply #7761 on: March 25, 2020, 08:02:49 PM »
I did it!
Congrats on an epic ride. enjoyed reading your blog.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #7762 on: March 26, 2020, 04:19:19 PM »
My 750F on The Dragon last June
I've been there, but no pics.  :(
Looks like fun.   :D
« Reply #7763 on: March 26, 2020, 06:19:15 PM »
I did it!
CONGRATULATIONS!!!! Epic ride and I also thoroughly enjoyed your blog. How did the bike make it in the end after all your charging issues!?? Well done also on YOU making it!  8)
Now how are you getting home!!??
cheers
Andy
« Reply #7764 on: March 27, 2020, 09:08:34 AM »
Did you post anything up for the last leg? I think I missed it, I'm subscribed.
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #7765 on: March 28, 2020, 07:35:13 AM »
I did it!
I had replaced the innards of the regulator and rectifier with electronic bits from Horst on the German site. The first problem was that the wiring in his regulator plug didn’t match the wiring on mine on the bike; only two of the yellow wires were connected. When I found this and fixed it, there were no more charging issues.
Then one of the transistors on the board in the regulator blew itself to bits. I had to sit for 2 weeks waiting on a replacement to come from Germany - the local guys could have replaced it but they didn’t have the right transistor. That was in Sudan and so far all is well. Horst also sent me an unadulterated unit In case the replacement electronic on packed up, so I now have 3 regulators! I’m sure once things settle down I can get the transistor replaced locally.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
« Reply #7766 on: March 28, 2020, 07:41:46 AM »
Not yet. It’s written but I going to get a few pics of The bike - warts and all - to post. Just to illustrate the wear and tear.
I’m also trying to sort customs out so I can get my deposit from the Carnet people back; since it came from here originally, in theory no customs duties should be due.🤞
The plan now is for the bike to stay here until things settle down, and I decide where to go next. Did you know there are 16 places called Belfast across N America and Canada? 🤪 Watch this space.
CB450 K1 - Stalled.
« Reply #7767 on: March 28, 2020, 09:21:22 AM »
Uh oh, I think I see a North America tour in the works.
Keep us posted, too bad I'm over here on Maui or I'd join in for a leg with my K3.
Offline zthrower
« Reply #7768 on: March 28, 2020, 12:12:05 PM »
Purchased this 1975 cb400f for my girlfriend in 2019. The cam chain is bad and there are some electrical issues, so we will be taking it apart soon.
« Last Edit: March 28, 2020, 12:14:56 PM by zthrower »
Offline Old Moe Toe
« Reply #7769 on: March 28, 2020, 11:40:12 PM »
This morning, Franklin,Tasmania.
Offline scunny
« Reply #7770 on: March 29, 2020, 12:17:43 AM »
That's a good looking bike zthrower, I like the paint scheme.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline zthrower
« Reply #7771 on: March 29, 2020, 10:00:36 AM »
Thanks, Scunny!
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #7772 on: March 29, 2020, 01:27:01 PM »
the neighborhood had a social distancing parade to help cheer folks up.  lots of people waved from their front porches wearing smiles.  glad the parade kept a decent speed of about 15 mph so my sohc didn't overheat.
cb750 k6 - ugly
Offline bluezboy
« Reply #7773 on: March 29, 2020, 03:43:46 PM »
The updated CDC guidelines recommended 750cc’s or more to remedy the Cov-19 Stuck in The House Blues, I complied today :)!
« Reply #7774 on: March 29, 2020, 03:59:46 PM »
What's the story on the old building, Vern? Was it a jail?
