Author Topic: Dyna Beads thread locked up Now lets all fight over motor oil  (Read 17915 times)
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
Re: Dyna Beads thread locked up Now lets all fight over motor oil
« Reply #50 on: September 18, 2009, 07:32:37 AM »
I'm still searching for an additive that would make the proprietary brand differences less important in our choice.
The additive should reduce engine vibration, increase smoothness, maintain viscosity and protect against loss of clutch-plate friction.................If it already existed, it would probably be named.......dare I say it........dyna-oil.                       ;D
OH NO I can't believe you said that. The doodoo will hit the fan now. ;D ;D :D ;D
People with closed minds cannot learn new things.
Offline BVCB650
  • Too Much Thin Air
« Reply #51 on: September 18, 2009, 07:43:07 AM »
That's it. Time to get out the troll spray.
1979 CB650, 25K miles, recently refurbished
Offline Inigo Montoya
« Reply #52 on: September 18, 2009, 07:52:51 AM »
I use the rotella 5-40 synthetic. Has worked awesome.
Offline w1sa
« Reply #53 on: September 18, 2009, 07:54:35 AM »
I know, I know. Remiss and irresponsible!   ???........I cracked my head on a side cover , while pouring oil, after slipping on some damned beads spread under the wheels of my bike  :o
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #54 on: September 18, 2009, 08:14:25 AM »
I can't believe that I continue to read this... ;D
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline BVCB650
  • Too Much Thin Air
« Reply #55 on: September 18, 2009, 08:17:22 AM »
Good stuff. I use it in my turbo Jeep Liberty.
Offline w1sa
« Reply #56 on: September 18, 2009, 09:11:49 AM »
I have an old Kwaka 650 twin. Separate gearbox/transmission. It is used in warm climate.
The crankshaft is supported by 3" ball bearings at each end. The original oil specified was sae30 motor oil.
I've recently rebuilt the engine and replaced the bearings. I think the bearings get quite a work out from the crank. I'm currently using Castrol 20-50 (mineral) for initial running/run-in, and want to use the best oil protection I can for ongoing use.... :-\
What say you regarding your view/choice of the best type of oil available for this application?     ;) ;D
« Reply #57 on: September 18, 2009, 09:14:49 AM »
When you say you use Rotella 5W 40, and it works awesome..what does that mean ???
 Have you pulled a motor apart after using it for an extended period of time?
 Or do you simply mean, the motor runs & the clutch does not slip?
Offline bistromath
« Reply #58 on: September 18, 2009, 09:18:30 AM »
I can't believe I'm feeding into an oil thread, but I used Rotella 15W40 dino oil for 15000 miles on my 550, and when I pulled it apart recently (at 40000 total miles), the cases looked beautiful. No sludge, next to no film on the cases, no abnormal wear and bearings within tolerances. It's not the same oil as the synthetic 5W40, but just a vote here for Rotella. And, it's cheap!
'75 CB550F
Offline BVCB650
  • Too Much Thin Air
« Reply #59 on: September 18, 2009, 09:31:37 AM »
I can tell you I use it in my turbo diesel, and have had no oil usage, or tubo failure in 175,000 miles. I use the fossil Rotella 15W40 in my bike. Too soon to tell, but it is good oil and a bit cheaper than the full synthetic.
Offline Gordon
  • 750K1, 550K2
« Reply #60 on: September 18, 2009, 12:32:59 PM »
I can't believe this attempt actually worked and people are really getting into the oil thing again!  On the plus side, though, at least we're managing to keep it relatively flame-war free so far.
And another big plus!  I'm finally being ignored by somebody!!!! ;D  I wonder who? ;)
« Reply #61 on: September 18, 2009, 12:47:56 PM »
It's me gordon. Oh wait, I'm not supposed to see what you post! :D
I have not pulled the motor apart, however my shifts are very smooth. I have no clutch slip at all. My gears do not jump and neutral is very easy to get. Engine noise is very low aside from clutch rattle and even that is quite low.
I have been using it for a few years now and it has worked very well for me. I would be willing to bet that if I had to take the engine apart, it would look very good on the inside. I may do that this winter since 33 year old seals do sometimes need to be replaced.
Offline Gordon
  • 750K1, 550K2
« Reply #62 on: September 18, 2009, 01:34:14 PM »
If it ain't broke, don't fix it! ;D
« Reply #63 on: September 18, 2009, 02:04:46 PM »
well the valve cover is leaking, sorta.  ;)
« Reply #64 on: September 18, 2009, 06:24:49 PM »
Put Seafoam in it, it seems to fix everything else.
Qingdao
« Reply #65 on: September 18, 2009, 07:03:17 PM »
Don't think seafoam in the oil is a good idea IMO.
I use GTX 10-40 Its what I have always used in bikes.
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #66 on: September 18, 2009, 09:34:56 PM »
I'd just like to say I use oil also
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #67 on: September 18, 2009, 09:45:27 PM »
ok , it's page 3 where's all the pictures of poop
Offline Frankenkit
  • Industrial Strength
« Reply #68 on: September 18, 2009, 10:14:54 PM »
I strongly suggest a little magnesium citrate.  ANYTHING in your combustion chamber will be rapidly blown out your tail pipe.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #69 on: September 18, 2009, 11:16:34 PM »
On a serious note regarding oil.
While on my recent trip a Honda mechanic said any oil with the "SG" or "SJ" rating would never effect my clutch. I wrote it down and keep it in my wallet now.
Offline 333
  • Time for change
« Reply #70 on: September 19, 2009, 06:55:13 AM »
Okay, try to follow me on this.  If you had a plane, and it was on a runway covered in Dynabeads, could it take off?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Inkscars
  • grumpiness comparable to an
« Reply #71 on: September 19, 2009, 07:01:42 AM »
I used the beads like you guys said to and now my bike is making a funny noise and My oil bag is empty.
 ;D ;D ;D ;D
81 Hardly Davisson
Offline BVCB650
  • Too Much Thin Air
« Reply #72 on: September 19, 2009, 07:16:11 AM »
Interesting how TROLLS keep trying to infect this thread too. Kids kids kids.
Offline Inkscars
« Reply #73 on: September 19, 2009, 07:21:57 AM »
Now I'm a troll? That's interesting. Ignore me, you won't miss me.
81 Hardly Davisson
Offline Damfino
« Reply #74 on: September 19, 2009, 08:39:48 AM »
I usually have that problem after eating at Taco Hell!! :D ;D
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
