Author Topic: What did you do to your bike today ?  (Read 3727317 times)
« Reply #19825 on: May 22, 2015, 05:17:39 PM »
First, my high/low switch was a little loose where it would shut off if I pressed it to the right. Took it apart and cleaned it, added dielectric grease and assembled. Works like a charm now.
Second, tested out my new Randakks grips to see if that would eliminate my right hand going numb. Didn't do anything (although I love the grips...much more comfortable than my previous ones). I decided to do a new set of foot controls using the passenger pegs and mounting them where the stock location is, but a smidge farther back. Will test it out tomorrow. I can already tell less pressure is on my hands. Hope it does the trick.
1978 Honda CB550K
Hey Dave...the round grips can be the worst for hand issues. even when fat and cushy.  A flat(er) grip will keep pressure on the pads of your hands, and off the nerve and blood supply lines.  If those don't work...go OURY.  ;)
« Reply #19826 on: May 22, 2015, 05:20:47 PM »
Trimmed and repurposed some headlight ears to be my new rear signal mounts....
Offline paul_nz
« Reply #19827 on: May 22, 2015, 05:31:46 PM »
Looked at it, gave it an oil change and used some KROIL on the exhaust clamp bolts. :)
Offline DaveBarbier
« Reply #19828 on: May 22, 2015, 06:07:55 PM »
1978 Honda CB550K
It was between the Randakks and OURY. I've heard good things about both, but more people like OURY from what I've read. But...I just don't like the way they look! If my foot controls being moved forwards don't help, I'll look into OURY for sure. Can't have a numb throttle hand!
Thanks Flybox
1978 Honda CB550K
Offline Tews19
  • I am no
« Reply #19829 on: May 22, 2015, 08:05:13 PM »
Fly is correct on the grip issue. I had the old school ones on my bike. Never had them before but they really killed my left hand. Numb and shooting pain. I cut them off today and will put my favorite grips on tomorrow. I have bought these for every bike I ride regularly.
1970 Honda CB750 survivor.
Offline jonda500
« Reply #19830 on: May 22, 2015, 11:03:37 PM »
Been getting sick of smelling oil burning when I pull up on my cb550F, so today I replaced the o ring in the oil gallery plug that's directly above the four exhaust pipes (below the points cover). Now I gotta get around to doing the gear lever shaft seal and the clutch cover gasket and I'll be fairly close to having a leak free bike!
A starter clutch thread:
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #19831 on: May 23, 2015, 11:34:08 AM »
Was headed out for about a 100 mile round trip, but she died on me 1/2 mile down the road. Blew the main fuse. Hopefully it was just its time, but I suppose I should start troubleshooting. Ugh!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #19832 on: May 23, 2015, 12:14:42 PM »
I'm assuming you use glass fuses. Did it blow in the middle or did it melt on one end?  Blown in the middle, you have a short/overload somewhere.  Melted, your fuse clips need shined up and tightened.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline joeyvans
  • Definitely not a
« Reply #19833 on: May 23, 2015, 03:25:40 PM »
I never changed the fuses when I bought the bike last December. Judging by the looks of things, I should have. The main was pretty ugly looking, so I kind of think it was at the end of its life. What do you think?
1976 CB550 K2
« Reply #19834 on: May 23, 2015, 07:23:31 PM »
It won't hurt to shine up the fuse holders and pinch then tight so that they grip the fuse caps better.  You may also want to look at the back of the fuse holder for any scorching.
If it looks like your fuse holder is toast, Hondaman sells a direct plug-in replacement that will upgrade ur fuses to blade style.
Sure.
Is it hard?
Offline 750cafe
« Reply #19835 on: May 23, 2015, 09:28:20 PM »
Deoxit spray on the fuse box or remove it and soak it in vinigar over-night.  ;)
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
« Reply #19836 on: May 24, 2015, 03:36:16 AM »
I randomly blew a main fuse on my 750 once and replaced it and have not had a problem with it for the last 5 years. No idea how old the old one was ,may have been original. Did learn a reminder lesson though to carry a spare.
Offline Rocky2010
  • Live in Strayla
« Reply #19837 on: May 24, 2015, 04:43:32 AM »
As it is Spring (Fall) time in Australia I thought I would take some photos of my 1971 CB500 down the side of an old pub which has these big tree, these trees are dropping their leaves and would make for a different photo  :)
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline InAquaVeritas
« Reply #19838 on: May 24, 2015, 05:41:43 AM »
Love the two-tone! Great photo as well.
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
Offline joeyvans
  • Definitely not a
« Reply #19839 on: May 24, 2015, 06:05:04 AM »
I'm actually thinking that might be the case here, Eric. I bought a bunch of 15A and threw them under the seat in case it isn't. Couldn't get it to blow again yesterday, and the holder looks really good. Will limit her to short trips for awhile. Thanks for the input guys!
Kyle
1976 CB550 K2
Offline MoMo
  • Ride like you're invisible
« Reply #19840 on: May 24, 2015, 07:05:42 AM »
Kyle
I had the same one time fuse blowing on one of my 400fours.  Happened first test ride after resurrecting the bike from a rest of many moons...Larry
Offline 750cafe
« Reply #19841 on: May 24, 2015, 08:08:25 AM »
Your bike looks fantastic. Great pic.
Eric
Offline Cqyqte
« Reply #19842 on: May 24, 2015, 11:58:45 AM »
Okay let me set this situation up.  Yesterday was extremely windy in my area but that did stop me and a mate from going for a rip on the bikes.  My CB750 hardtail has keyhole '77 carbs and pods and have yet to display less than perfect performance, except for yesterday!  The wind gust created a flutter at 1/2 to 3/4 throttle range, which was controllable but being anal I cannot live with it.  On the way out as well as the return trip heavy winds showed that the set up was not perfect.  I didn't sleep well last night as thoughts of dismantling and fussing with needle position plagued me until I finally managed to drift off.  About 3 o'clock I woke and had one of those light bulb moments sparked by something I had read in a thread on a forum, something about someone running pods with a tube/sleave arrangement.  A few more hours of hashing out how to's and I woke with and idea to make an aluminum oblong shroud that work protect the filters from cross wind and turbulence coming off the engine cases at speed.
After breakfast I ran to the hardware store and purchased a small roll of flashing aluminum and started to fab up the image I had in my mind.  Two hours of measuring cutting, folding and bending I fitted my idea around the carb pods, looks were high on the must haves.
Once anchored and checked for secureness I fired her up, and yes today is just as windy if not worse.  I have a test circuit that heads in all the compass points with flats, confined areas and those nasty open spots that harbour those killer side blasts that sometimes feel as if they can extinguish the internal combustion spark by themselves.  From 0 to 150kph not a flutter, not even when I open my knees to the breeze which the day before would have cause the bike to fall flat on its face if I didn't shift and find a different rev range to compensate.  I can't say it is perfect yet as I have to do some further testing in several conditions and perform the all important plug chops to say FIXED!
But as of now, it out for more riding... the sun is shining  8)
« Last Edit: May 24, 2015, 12:02:30 PM by Cqyqte »
« Reply #19843 on: May 24, 2015, 02:44:34 PM »
have testet a Yamaha dt handel on my 400 four..i have problems in low back.disc colaps..so the low handel vas a pain to drive...had the Yamaha standing ,,so steal it ,,for a test ride.. still it are a bit to breit....nov i vill fine a thomaseli they have a fine crome..and finish
« Last Edit: May 24, 2015, 02:46:09 PM by strynboen »
Offline JeffM
« Reply #19844 on: May 25, 2015, 06:57:40 AM »
Went for a 70+ mile ride with my family and their stable of BMWs. The little 550 was the smallest of the group but she held her own in the corners. Desperately needs a new chain and sprockets so I'll be doing that today.
1976 CB550K
Offline lajos
« Reply #19845 on: May 26, 2015, 06:14:50 AM »
Hello all, first post-
Bought a '73 cb500 two weeks ago that is in need of a fair bit of TLC. This weekend with the help of my son we took most everything off the bike, broke down the engine and found two  broken off valve heads in the cylinders (probably why it wasn't turning all the way over). A 550 engine will go into the bike, also broken down and waiting for 600cc big bore kit because the cylinder walls have too much pitting.
Sonny boy is now proficient picking the right size sockets for the impact wrench, but has a basket full of oily clothes ;)
'73 CB500 frame with '76 CB550 engine build in progress http://forums.sohc4.net/index.php/topic,148166.0.html
'09 Ducati M696
« Reply #19846 on: May 26, 2015, 06:29:56 AM »
Welcome, nice pictures!
You can start a built thread in Projects to track your progress.
« Reply #19847 on: May 26, 2015, 06:43:44 AM »
I need a little helper like that. My Son is 27 now and has a live in girlfriend, never see him much anymore   :o
« Reply #19848 on: May 26, 2015, 07:12:27 AM »
+1  My daughter was just never that good at being a "son"!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19849 on: May 26, 2015, 07:19:09 AM »
My daughter is only 20 months old... but she loves to "help" around the house. She heads straight for the garage when we go outside, too!
--Evan
1975 CB750K "Rhonda"
