Author Topic: 1978 CB750K — Post 836 OIL PRESSURE - Seems bad :(  (Read 312268 times)
Offline fastbroshi
  • Puppet
Re: 1978 CB750K resto-mod - on wheels
« Reply #250 on: October 16, 2012, 12:45:59 PM »
Should I polish them with rouge and a cloth wheel?
I've never heard anyone ask that question, but I'd lean towards NO, for the same reasons you wouldn't want to polish the roof of the combustion chamber.
Just call me Timmaaaaay!!!
Offline SKTP
« Reply #251 on: October 18, 2012, 01:24:09 PM »
Why wouldn't you want to polish the combustion camber, just out of curiosity?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #252 on: October 18, 2012, 01:45:52 PM »
Imo, and according to Hondaman, you do...the smoother tou get the combustion chamber and piston tops, less tooth for carbon to build up and no hot spots to cause detonation/pre-ignition
Offline SKTP
« Reply #253 on: October 18, 2012, 01:58:53 PM »
That's what I was thinking?!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline the technological J
  • deliciouso!
« Reply #254 on: October 27, 2012, 07:49:45 AM »
i was under the impression(i dont know where from) that you polish the ports and the dome but only smooth the piston
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline SKTP
« Reply #255 on: October 27, 2012, 03:54:02 PM »
Now on to the combustion chambers
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #256 on: October 28, 2012, 09:47:17 PM »
Cleaning, cleaning, cleaning...
That gasket residue is not coming off it seems....is that normal?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #257 on: November 03, 2012, 10:38:32 AM »
Hitting the garage shortly....A few updates made during the week;
Honda Dream 305 Toyo mirrors test fit
New speedo bezel in the works
Cylinders honed. Pistons cleaned and ringed
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #258 on: November 19, 2012, 05:04:28 PM »
Renthal ultra-low road bars installed. Bar clamp filed down to ensure a rock solid fit
Renthal Kevlar grips. Will have to get a shorter throttle sleeve
I hope to get the motor together this week. Can the neutral switch be removed when the engine is in the frame?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline knowsnothing
« Reply #259 on: November 19, 2012, 05:09:58 PM »
Looking good!  I really dig those bars.
1978 CB750k Blue - for sale
Offline fastbroshi
  • Puppet
« Reply #260 on: November 19, 2012, 10:31:49 PM »
Couldn't you just cut a bit off the end of the stocker?
Offline racinchase
« Reply #261 on: November 21, 2012, 08:27:56 AM »
Love the bars!!!!!!
“The right bike, the right day, the right road, I just pretty much feel at one with the universe. When I feel like I don’t fit anywhere or I’m lonely or I’m all screwed up in the head, I get on my bike and go for a ride and it’s like all of the sudden, I’m fixed.” – Indian Larry
1975 CB750 K
2009 R1
Offline SKTP
« Reply #262 on: November 21, 2012, 07:21:11 PM »
Cut down the throttle sleeve and set up the controls. Mocked up the fender very loosely. Still so much to do, but I'm getting excited
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #263 on: November 23, 2012, 07:36:52 PM »
This engine is going together finally....dropping in the donor tranny. It's confusing....I think I got it right?
Here's the visible issue with the old dogs (right? Those are dogs?)
Not confusing at all! :/
I have four manuals, but all tips welcome. I have a bearing in the freezer now (the lower case one) and I know that hole has to line up with that ring hole on the tranny spindle....but all tips and hints welcome
« Last Edit: November 23, 2012, 07:39:18 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
Re: 1978 CB750K resto-mod - transmission action
« Reply #264 on: November 24, 2012, 03:08:30 PM »
Progress!
Never take this bearing out. It barely has a load on it (edit: maybe it does?) and it took me about an hour to pound it back in even after freezing it over night and leaving the lower case in the hit sun for hours...why did I remove it?
How do you remove the clutch basket? I'm guessing some weird Honda tool?
Have not assembled the shifter mechanism but I think I have all the main tranny parts in the right place...
http://i297.photobucket.com/albums/mm202/ChristopherBywater/1E183694-DD4E-4CD6-80C8-9B87F526AC41-48270-0000236E4290DAD5.mp4
http://i297.photobucket.com/albums/mm202/ChristopherBywater/A2DADCB5-AF8F-46A5-9D5F-90A20BDDED4C-48270-0000236E5D073E22.mp4
Need to clean a bunch of internal parts. Man, the PO must have never changed the oil...I guess new clutch plates might be a good idea as they are dirty, dirty
« Last Edit: November 25, 2012, 04:54:07 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: 1978 CB750K resto-mod - transmission action - now with video
« Reply #265 on: November 24, 2012, 03:50:56 PM »
That is a worn shift fork; the dogs are on the gears. Make sure the snap rings are properly installed. Read this:
http://forums.sohc4.net/index.php?topic=86429.0
Offline SKTP
« Reply #266 on: November 25, 2012, 04:50:36 PM »
Clutch basket just slides off...cleaned a bunch of internal parts today. Really happy with how it's going. Slow, but it's really cool to finally understand how all this stuff works...
Hopefully get the shifter together and working tonight. Going to order a new clutch and other bits this week
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #267 on: December 03, 2012, 09:25:31 AM »
My friend made me an acrylic bezel to replace the pitted dented original. Turned out amazing
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Tintop
« Reply #268 on: December 03, 2012, 01:22:51 PM »
Your right, that is amazing. 8) 8) 8) 8) 8)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline racinchase
« Reply #269 on: December 03, 2012, 09:39:40 PM »
Thats not amazing thats EPIC!!!!
1975 CB750 K
2009 R1
Offline SKTP
« Reply #270 on: December 29, 2012, 12:53:25 PM »
Test fit....the going has been slow lately but this test fit is very motivating!
Note the Indy skateboard truck bushings for spacers!!!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #271 on: January 03, 2013, 05:01:23 PM »
I think I figured out how the shift mechanism goes back together. Now I just need to figure out how to sync it to be in the right gear. It's just at a mock-up stage as it stands
Edit: is there only one way this can go interns of how it's rotated when initially installed?
« Last Edit: January 03, 2013, 07:21:18 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
Re: 1978 CB750K resto-mod - transmission shifter, is there a right way?
« Reply #272 on: January 06, 2013, 06:17:59 PM »
Crank shaft clean! Think I figured out the tranny, seems to shift through all the gears.
Ordered parts and won Triple A spaghetti pipes on eBay.
Need to research gasket sealer and get this thing together.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #273 on: January 11, 2013, 10:33:02 AM »
Another good experience with Bikebandit.com
New airbox innards and fasteners; neutral switch and that "castle" clutch socket
hooray new parts!
bookmark:
http://www.fastfromthepast.com/servlet/the-503/Fork-Brace-Honda-CB750F1/Detail
« Last Edit: January 11, 2013, 07:09:06 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #274 on: January 16, 2013, 08:00:39 AM »
Triple A pipes acquired
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
