Author Topic: Rebuild using two engines (K3 and K8)  (Read 1960 times)
Offline crabbyjay
« on: March 06, 2011, 09:37:21 AM »
We're at a point in our rebuild to start putting things back together, using the best parts from two engines.
Is it possible to use a K3 head with a K8 crankcase?
Thanks
Jill
Offline crabbyjay
Re: Rebuild using two engines (K3 and K8)
« Reply #1 on: March 06, 2011, 09:39:07 AM »
These are both CB750's that we took apart.  Have engines and frames but want to use the best bits from each -- both were seized when we took them apart.
Offline axehole54
  • Who the heck decided to call me a
  • #169 North
« Reply #2 on: March 06, 2011, 09:44:51 AM »
Someone else please jump in but I believe the oil passages (or something to that effect) don't line up between k3 and k8 but I think there's a way to remedy that... oddly enough I have both of those bikes too
73 750k, 78 750k, 69 c10, 87 r1500 (c10), 94 fzr1000
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: March 06, 2011, 10:57:47 AM »
It's the 77-78 F model engine that has the oil passage concerns.
K3 head should bolt right on, no problems. Be aware that the the K8 valves, springs, and retainers are different than those on the K3 head. Not sure if you will run into any fitment problems if you try and mix and match these parts. Cam towers, rockers, and cam should be ok to swap between heads.
Offline crabbyjay
« Reply #4 on: March 06, 2011, 11:09:04 AM »
Thank you so much, that's great information, especially on the rockers.  We managed to keep the valves altogether without any mixing of parts, but we've mixed up the rockers.
Offline scondon
« Reply #5 on: March 06, 2011, 11:36:04 AM »
When disassembling it is suggested to keep the rockers, and shafts together as they came apart. If everything is now in a jumble, then using the parts with the least amount of wear is the next best option I suppose.
At some point in their development Honda changed the cam towers and rocker shafts to use two small bolts to keep the shafts from rotating. Do all your rocker shafts have two small threaded holes in them? Through some close inspection of parts you may at least be able to determine which rockers and shafts came from which head.
Also, the cam bearing caps that bolt on the cam towers should have letters stamped on them which correspond to letters stamped on the towers themselves. These caps cannot be mixed and matched between towers.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: March 06, 2011, 12:23:17 PM »
Be careful with the clutch case covers. If you are using the later (78') clutch with the earlier (73') case cover you may have an issue. I used an earlier clutch case cover on my 78' 750. The earlier clutch case cover (the aluminum clutch case cover, not the tin outer linkage cover) has a 1/4" more material at one of the outer cover screw bosses that will "Pin" the clutch basket in place to the point that you would swear the engine is siezed.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Old Scrambler
« Reply #7 on: March 06, 2011, 02:38:33 PM »
According to others on this site........the k8 tranny and clutch are improvements over the k6 and earlier models. The K8 pistons have a slight dome to add about 0.2 compression.  I have no idea why they have a gear indicator on the cover, but if you are using the K3 frame I would use the older cover.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline GammaFlat
« Reply #8 on: March 06, 2011, 02:44:11 PM »
The K8 output shaft is set up for a 630 sprocket.  You can mount a 530 sprocket to it (same spline) but the attache method is different.  Also, the K8 sprocket is 3/8" more outboard.
K6
85 Goldwing
