Author Topic: Stuck at side of road bike can't kick over!  (Read 4014 times)
Offline RpBet
« on: July 01, 2011, 05:49:21 PM »
Took my bile out for it's maiden voyage. I may have pooched something. I can't kick her over. She feels stuck. I was running 20 psi at the oil gauge. What should a 78 cb750k have for pressure running and at idle. Help!
78 cb750 Cafe'
Offline sick_seven_fifty
Re: Stuck at side of road bike can't kick over!
« Reply #1 on: July 01, 2011, 06:32:26 PM »
It bothered me that nobody had replied to your thread yet so I decided to look it up for ya.
According to others, oil pressure runs around 10-20 at idle and 55-65 at speed.
Wish I could help ya further....good luck.
« Reply #2 on: July 01, 2011, 06:34:03 PM »
Also, is it possibly just the kick starter that is stuck?  You should try putting it in 5th gear and pushing the bike with the clutch out to see if it will turn over.  Also, did it quit running suddenly?  Make any noises?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: July 01, 2011, 06:38:06 PM »
Maiden voyage? Did you just buy it or did you just finish building it? What work have you done to to it?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: July 01, 2011, 06:49:15 PM »
Was it running OK, then you shut it off, and then a few minutes later you tried to kick it and the kick-starter didn't want to move? This is what happened to me, and I was on my way to meet up with a certain lizard at the time. :o The motor was hot as hell, and after cooling off loosened up.
Offline RpBet
« Reply #5 on: July 01, 2011, 08:23:21 PM »
Had to throw here on the back of a pick-up. A little surprised my self that I had no reply's. Oh well, thanks for checking it out. I ending up pulling the shop manual when I got home. I had no pressure at idle and only 20psi at 4000rpm. I can only assume faulty oil pump.
Yeah I spent the winter putting her together. I picked it up, and the top end was completely disassembled. I took to shop only to have the timing done and carbs synced. My worry is if I had no pressure at idle and the guy tuning my carbs obviously didn't notice it. (I took off the dummy light.....Dummy!) then their was no oil in the top end the whole time he was tuning the carbs.BAD.
However, I did put on about 20km and a little noise. Crack the throttle noise dissipates. BUT when she was hot and I came to a stop she would die. Did this twice then ceased up.
78 cb750 Cafe'
Offline RpBet
« Reply #6 on: July 01, 2011, 08:25:10 PM »
What was your problem??? Or did it never happen again.
78 cb750 Cafe'
Offline RpBet
« Reply #7 on: July 01, 2011, 08:57:18 PM »
Lifted valve cover, as much as I could and discovered the cam chain is off the sprocket. Now I need a Gordon fram kit! And need to check chain for malfunction. Also besides a faulty oil pump what else would cause low oil pressure.
78 cb750 Cafe'
Offline RpBet
Re: Oil pressure issue! Cam chain came off sprocket.
« Reply #8 on: July 01, 2011, 09:00:21 PM »
Tittle change.
78 cb750 Cafe'
« Reply #9 on: July 01, 2011, 09:09:52 PM »
The problem, in my case, was due to jetting for 4500' elevation, then blasting at 70-80 MPH for 100 miles, down to about 1000', then getting stuck at a traffic signal for 5 minutes or more in 90 degree temps. Once it cooled off, it was OK. Never happened before, and hasn't happened since, but I did richen up the jetting before hauling the lizard back up into the mountains.
« Reply #10 on: July 01, 2011, 09:15:29 PM »
:o You might as well resign yourself to pulling the motor, if the cam chain is off the sprocket....
Offline RpBet
« Reply #11 on: July 02, 2011, 04:10:53 AM »
Why? Do you think it will be necessary to lift the entire head. I am hoping there is no need to go past the cylinders. I am going to have to do some research. Really hoping to be riding again before the month is out!
78 cb750 Cafe'
Offline cben750f0
« Reply #12 on: July 02, 2011, 04:17:31 AM »
mate if the chain is off the cam sprocket you are gonna need to see if you have bent a valve, holed a piston, etc...that is not  just a put it back on fix...its a bad bad thing
Offline Gordon
  • 750K1, 550K2
« Reply #13 on: July 02, 2011, 04:46:37 AM »
+1, unfortunately.
Chain comes off the cam sprocket while the engine is running, valves and cylinders smack into each other.
« Reply #14 on: July 02, 2011, 05:06:03 AM »
so you shut it down?or did it go wierd and shut down itself?with the cam chain off the sprocket thats a big bad thing,,umm but the bike was running ok beforehand?
Offline RpBet
« Reply #15 on: July 02, 2011, 12:34:50 PM »
I wasn't thinking it was going to be a quick fix. I guess I will have to pull the top to expose the pistons and see from there.
As for the low oil pressure any guesses besides a faulty oil pump. I was only getting 20psi at 4000rpm 0 at idle.
78 cb750 Cafe'
Offline phil71
« Reply #16 on: July 02, 2011, 02:22:57 PM »
chains don't 'come off' the cam sprocket, unless it broke, or the tensioner was left out during re-assembly. that engine's gotta come out.
« Reply #17 on: July 02, 2011, 02:24:27 PM »
Check this thread for good information on correcting issues with low oil pressure:
http://forums.sohc4.net/index.php?topic=78643.0
I will likely follow the steps shown in that thread just as a preventative/long term maintenance item.
TAMTF...
Wilbur
Projects:
« Reply #18 on: July 02, 2011, 09:37:34 PM »
 If you ran it with low oil pressure there could be a lot of damage.
 Dont worry about a frame kit, the motor will probably be coming out.
 Take off yout tappet covers and see if it looks dry.. then dump oil in the pan or filter..if there is lots of metal.. you may need a motor.
 unless just prior to riding somone inexperienced worked on the top end and gunged up the oil passages, to the topend
 Badly worn main bearings would cause low pressure..
Offline RpBet
« Reply #19 on: July 03, 2011, 05:08:21 AM »
Thanks for the link Madmtn. I will go through all these steps as well as checking the pump to shop speck!
78 cb750 Cafe'
Offline Tintop
« Reply #20 on: July 03, 2011, 09:36:26 AM »
I assume you checked the cam chain by removing the breather cover.  Given you say it is off the sprocket, it is likely now jammed at the bottom.  This would cause an engine lockup, and require a new chain.  It also means you have likely bent some valves.  The low/no oil pressure for the period of time stated running, would easily have damaged cam bearings.
At the very least you should be pulling the engine, and remove / inspect the cam bearings, and valves.  No oil pressure is the least of your problems now.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline RpBet
« Reply #21 on: July 03, 2011, 12:50:57 PM »
Hey Tintop, Have followed your threads. This is exactly what I have to do. I hope the pistons and valves where spared. I will get to this hopefully during the next week or two. Thanks
78 cb750 Cafe'
Offline Tintop
« Reply #22 on: July 03, 2011, 03:34:51 PM »
Keep us posted.
77 CB550 Cafe build
Offline RpBet
« Reply #23 on: July 03, 2011, 05:14:36 PM »
This was in the bottom of the pan. Next step remove the motor.
78 cb750 Cafe'
Offline Tintop
« Reply #24 on: July 03, 2011, 05:20:36 PM »
Not an good omen. :(
77 CB550 Cafe build
